Debugger
Debugger
i have Problem with Debugger on Tab "Variables" ... it crash often.
to be more exact : ONKEYPRESS make Problem with GRID
when have many Variables i have to wait until it is "stable", else when move Mouse it crash.
HbIde_Error.ZIP
(4.2 KiB) Downloaded 325 times
does GRID use LVS_OWNERDATA / LVN_GETDISPINFO :?:
i had that Problem with my own native Control.
it was the LVN_KEYDOWN Event where "quick" Keystoke crash.
i saw c:\hmg.3.4.4\SOURCE\Debugger\
will this Source include when re-build HMG LIB :?:
Question : how to debug Thread :?:
Re: Debugger
have modify c:\hmg.3.4.4\SOURCE\Debugger\DBGHB.PRG
CLASS HMGDebugger
METHOD GetNextValidStopLineEx( cFileName, nLine )
   METHOD GUIDoEvents()                         // here New
   VAR bGUIDoEvents            INIT {|| NIL }   // this code block is initiali
*   METHOD GUIDoEvents()             INLINE   EVAL( ::bGUIDoEvents ) // do crash often when using many Events
i have disable INLINE and wrote a "normal" Method with Errorblock
METHOD GUIDoEvents() CLASS HMGDebugger
LOCAL bOldError
   bOldError := Errorblock( {||Break()} )
   BEGIN SEQUENCE
      EVAL( ::bGUIDoEvents )   // here safe
   END SEQUENCE
   Errorblock( bOldError )
RETURN Self
now it seems me more stable :D
p.s. run c:\hmg.3.4.4\BuildLib32.bat to rebuild HMG LIB
to "open" a Member VAR Window i have to use K_RETURN
Question : how to use Double-Click on Grid Item :?:
Re: Debugger
i have found "ON DBLCLICK" in c:\hmg.3.4.4\INCLUDE\i_grid.ch
so i have modify 2 Procedure in DBGGUI.PRG
PROCEDURE ProcInitGUIDebugger( lCreate )
         @ 0,0 BUTTON Button_Refresh CAPTION "Refresh" PI
                  @ 0,0 GRID &cGrid_SourceCode;
                     ON DBLCLICK OnKeyPress( VK_RETURN );
               @ 0,0 GRID Grid_CallStack;
               @ 0,0 GRID Grid_Watch;
               @ 0,0 GRID Grid_Calc;
               @ 0,0 GRID Grid_Vars;
               @ 0,0 GRID Grid_Areas;
               @ 0,0 GRID Grid_Rec;
PROCEDURE DisplayVars ( cVarName, xVarValue, aColor )
         @ nHEIGHT() , nWIDTH() GRID &cGridName;
            ON DBLCLICK OnKeyPress_DisplayVars( VK_RETURN, cFormName, cGridName, xVarValue, aObjRawValue, aColor ) ;
now a DblClick work same as VK_RETURN
Re: Debugger
have work with it and it seems stable so i can upload it
! Note : make a Backup FIRST !
HMG_Debugger_1.zip
(23.88 KiB) Downloaded 333 times
copy both files to c:\hmg.3.4.4\SOURCE\Debugger\
rebuild HMG Lib with c:\hmg.3.4.4\BuildLib32.bat
vagblad
DBs Used: MySQL,DBF
Re: Debugger
Post by vagblad »
Thank you.
Vagelis Prodromidis
quartz565
Re: Debugger
Post by quartz565 »
Thank you !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Steed
Re: Debugger
Post by Steed »
thanks
