Crear DB de MariaDB
jorge.posadas
Crear DB de MariaDB
Grupo
¿Cómo puedo crear, desde mi aplicación, una base de datos en MariaDB, PEROOO en un directorio que yo desee?
De antemano muchas gracias
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
POSADAS SOFTWARE
Jorge Posadas Ch.
Morelia, Mich.
M é x i c o .
- dragancesu
Re: Crear DB de MariaDB
Easy or hard, it depends how you think
Best from some database management program, I use HeidiSQL
The principle is to create a database and tables that you use from the application
CREATE DATABASE [IF NOT EXISTS] database_name
[CHARACTER SET charset_name]
[COLLATE collation_name]
http://www.mysqltutorial.org/mysql-create-database/
CREATE TABLE [IF NOT EXISTS] table_name(
column_1_definition,
column_2_definition,
table_constraints
) ENGINE=storage_engine;
http://www.mysqltutorial.org/mysql-create-table/
And forget the folder, the data is written to the database, and it is somewhere in the installation, like \ProgramData\MySQL\MYSQL Server x.x\data
and folders is database nama with data definition, but all data is in file ibdata1 if use InnoDB storage engine, recommanded
x.x = mysql version
table_constraints
x.x = mysql version
- dragancesu
The first step is to install the database software
The second step is to create a database and tables
Data is transmitted through export (result is file like dbname.sql), import is start export file ( dbname.sql )
- Ismach
Bueno crearlo es facil pero no podras levantarlo como servidor tan facilmente
porque necesitas reinciar y orientar el que es DATADIR al servidor, NO funciona como en DBFs
aqui hay un servidor o servicio que usa LOCATION --> DATADIR, mas alla de los privilegios de los usuarios
solo accede a las bases de datos que levante o se pase por parametros a "mysqld.exe"
Para cada servidor necesitas otientar DATADIR
Enel caso de que tengas varias Bases de Datos en distintos DATADIR solo tendras acceso a las Bases que esten en el directorio DATADIR
1) levantar elservidor y orientar aldirectorio donde quieras...:
2) ejecutar elscript .sql
Espero te Sirva
"datadir=C:/Mariadb/data" --> my.ini1) levantar elservidor y orientar aldirectorio donde quieras...:
ccSQL :="C:/Mariadb/bin/mysqld --basedir=C:/Mariadb/" --datadir=C:/IsmaCh/dbLaNena/"
RUN (ccSQL)Code: Select all
ccSQL :="C:/Mariadb/bin/mysql -h localhost -u root -p < C:/IsmaCh/dbLaNena/CreateMaridb.sql"
RUN (ccSQL)
- dragancesu
I see you know MySQL and how it works, i dont do that
I view MySQL as a server I access from the program, I don't care where the data is physically located (which can be easily seen)
For data preparation I use something simple, like Uniserver, create database and tables, then export and upload to server (thru HeidiSQL)
Uniserver is wapm server, https://www.uniformserver.com/, start only MySQL service and work only like localhost
- Ismach
El directorio default de MySQL Y Mariadb es \data\
pero eso se puede cambiar definitivamente o temporalmente
para ello solo hay que orientar el DATADIR
en mysql my.Ini en c:\mysql\bin\
en mariadb my.Ini pero en el directorio DATADIR default c:\mysql\data\
para reorientar el DATADIR se parametriza al momento de levantar o arrancar
el servidor mysqld.exe
en Mariadb es mas completo porque hay separacion de herramientas
INSTALLDB
INITDB
CREATEDB
STARTDB
en mysql es casi todo junto
INSTALLDB
INITDB
CREATEDB
STARTDB
- Ismach
Start Server Mariadb in other data dir:
1) Create Start.inOther.Dir.bat with
SET PATH=c:\Mariadb\bin\
mysqld -h localhost -u root -p --datadir=c:\Desarrollo\NuevaData\Code: Select all
C:\Desarrollo>dir Start.inOther.Dir.bat
Volume in drive C is Windows
Volume Serial Number is AE19-0440
Directory of C:\Desarrollo
07/11/2019 17:52 687 Start.inOther.Dir.bat
1 File(s) 687 bytes
0 Dir(s) 183.461.584.896 bytes free
C:\Desarrollo>Code: Select all
C:\Desarrollo>Start.inOther.Dir.bat
2019-11-07 17:52:43 0 [Note] mysqld (mysqld 10.3.9-MariaDB) starting as process 29648 ...3) Verificar
C:\Desarrollo>cd NuevaData
C:\Desarrollo\NuevaData>dir
Directory of C:\Desarrollo\NuevaData
07/11/2019 17:52 <DIR> .
07/11/2019 17:52 <DIR> ..
07/11/2019 17:52 16.384 aria_log.00000001
07/11/2019 17:52 52 aria_log_control
07/11/2019 17:52 2.397 ELNW00005558.err
07/11/2019 17:52 12.582.912 ibdata1
07/11/2019 17:52 1.010 ib_buffer_pool
07/11/2019 17:52 50.331.648 ib_logfile0
07/11/2019 17:52 50.331.648 ib_logfile1
7 File(s) 113.266.051 bytes
2 Dir(s) 183.461.371.904 bytes free
C:\Desarrollo\NuevaData>Re: Crear DB de MariaDB
Is it possible to create portable installation of MariaDB?
- Ismach
La verdad nunca se me habia ocurrido, pero creeria que si, no se si las ultimas versiones y en win10
poque ahi el censado del window defender y herrameientas de seguridad son muy estricto con los ports...
Pero me pondre en campaña a probarlo, no deberia ser problema en win7
- dragancesu
@mol
I don't know for MariaDB, for MySQL is https://www.uniformserver.com/. It's variant WAMP server, I use and start only MySQL. Posssible make zip and unzip at another location. I don't try but be possible delete other programs apache, php, if not need
This is simple and useful for testing
@Ismach
You know mysql/mariadb but think about localhost and windows. MySQL/MariaDB is better, what if install on Linux? if the installation is on linux then forget about the folders and access to the files
Database management program is a better solution and works everywhere
@Ismach
