HMG 3.0.0 + IDE + HFCL (Forum Test IX)
Re: HMG 3.0.0 + IDE + HFCL (Forum Test IX)
esgici wrote:Hi Maestro
Please don't take as pedantry, and probably you have read it.
This post interested me :
This way like me better than using redir.
It isn't for you ?
Again, sorry for pedantry :(
Redir has nothing to do with hbmk2 configuration. It only redirects standard output and standard error to a text file. Please, read redir docs.
Regarding the other thing, if you use build.bat, how it calls hbmk2 is not relevant for you.
Moreover the result is exactly the same, but with the advantage that build.bat is self-contained and not needs any external configuration file.
Roberto.
Roberto.
Anyway, you can use hbmk2 directly if you prefer.
Roberto.
Hi Maestro
Thanks to clarifications
Sorry, but including never used nor needed libs into my application is relevant to me, I think.
Best Reagards
I've uploaded a fixed 3.0 IX IDE: ide_30_test_09b.rar
Roberto.
Best Reagards
Sorry, I don't understand.
What are you talking about?
Roberto.
Hi Maestro
Sorry, please forgot it;
I'm only an end user and sometimes talks nonsense :(
I guess that you misunderstood the Harbour list message that you've posted.
Please, read docs, make tests and analyze the results and if you have a proposal for a better build.bat please post here. I'll consider it.
Roberto.
All right Maestro
Best regards
Nobody gets more syntax errors than me! That's for sure. In the previous versions of IDE, errors were listed line by line. Now, all the errors are listed in a single line, which makes debugging hard. :(
Can that be made again to be listed line by line?
Best Reagards
What you are saying is right Esgici.
As Roberto rightly mentioned, the build procedure has to be fine tuned. For this, we need the database of all the functions and related libraries. Whenever there is at least a call for a function from a library, that library shall be added in the build process. Others need not be linked at all. This would definitely save hard disk space. This is the ideal situation. To achieve this, if you ask me what to do, I don't know. May be, Roberto adds another tab in IDE with the default libraries added in the build process and we can untick whatever we don't want to link.
FYI, libxhb.a had been linked in the previous versions default. Now we have to link it manually.
