xMate to HMG IDE
xMate to HMG IDE
i have a old harbour Project with xMate and try to run it with HMG IDE
it use Codejock Calendar ActiveX and GTWVG compiled with BCC32
i have include LIBS= and INCPATHS= but still got some Error Msg
hbmk2: Processing local make script: hbmk.hbm
R:/Temp/hbmk_kb8qip.dir/HBXBASE.o:HBXBASE.c:(.data+0x1e48): undefined reference to `HB_FUN_WIN_DESTROYMENU'
R:/Temp/hbmk_kb8qip.dir/HBXBASE.o:HBXBASE.c:(.data+0x1fa8): undefined reference to `HB_FUN_OLERELEASEOBJECT'
R:/Temp/hbmk_kb8qip.dir/HBXBASE.o:HBXBASE.c:(.data+0x2448): undefined reference to `HB_FUN_WIN_GETDESKTOPWINDOW'
R:/Temp/hbmk_kb8qip.dir/HBXBASE.o:HBXBASE.c:(.data+0x2488): undefined reference to `HB_FUN_DATEASDOUBLE'
R:/Temp/hbmk_kb8qip.dir/HBXBASE.o:HBXBASE.c:(.data+0x24c8): undefined reference to `HB_FUN_WIN_MESSAGEBOX'
hbmk2[HBXBASE]: Error: Running linker. 1
hbmk2: Error: Referenced, missing, but unknown function(s): WIN_DESTROYMENU(),
OLERELEASEOBJECT(), WIN_GETDESKTOPWINDOW(), DATEASDOUBLE(),
WIN_MESSAGEBOX()
what is missing ... :(
need help please
xMate have a *.ENV File and i have read about "MingwHbHMGnew"
is this the Way to use old xMate Project with HMG :?:
PeteWG
Re: xMate to HMG IDE
Post by PeteWG »
xMate is an old [x]Harbour IDE masterpiece! the later attempts to create Harbour dedicated IDEs, despite the good intention and enormous effort, can't even come close to it, in my humble opinion.
HMG IDEs (both, official and extended) are quite good as form designers but due to lack of an integrated editor can't be consider as real IDEs.
The good thing is one can automate the use of HMG form designers and call them from the xMate, which is the best combination for
doing programming with Harbour. (Other, most modern option could be `visual studio code` accompanied by the Antonino Perricone's extension)
Bottom line: if you have no particular reason, keep working with xMate!
regards,
Pete
thx for Answer about xMate.
can someone help me with those Error.
i don't understand where they come from while it work in old Version.
does it have to do with BCC32 vs. MinGW :?:
seems i have a Problem when using BCC32 vs. MinGW
i found in c:\hmg.3.4.4\SOURCE\h_windows.prg where Value of Constant are change
#define LVN_FIRST      (-100)        // ok
// #define LVN_BEGINDRAG   (LVN_FIRST-9)   // ok  (MinGW)
#define LVN_BEGINDRAG   (-109)    // ok
in my Code i have this
so do i need to check my Windows Constant when use with MinGW :?:
it is not a HMG Question sorry.
i have now use HbIDE and import *.ENV from my old xMate Project.
now i try my Xbase++ Video Player (using WMP) and got a lot of Error ... all from Main Modul :o
i have all *.PRG in *.HBP and it seem to compile / link all. need help please
Project [ WM9 ] Launch [ Yes ] Rebuild [ Yes ] Started [ 05:08:35 ]
Batch File Exists => R:\Temp\rz5s71.bat
Batch File Contents =>
C:\harbour\bin\hbmk2.exe e:\harbour\WMP\WM9.hbp -q -trace -info -lang=en -width=512 -rebuild
Command => C:\WINDOWS\system32\cmd.exe
Arguments => /C R:\Temp\rz5s71.bat
CurDir() => Users\a\Desktop Starting in => e:\harbour\WMP\
e:\harbour\WMP>C:\harbour\bin\hbmk2.exe e:\harbour\WMP\WM9.hbp -q -trace -info -lang=en -width=512 -rebuild
hbmk2: Autodetected platform: win
hbmk2: Autodetected C compiler: bcc
hbmk2: Using Harbour: C:\harbour\bin C:\harbour\include C:\harbour\lib\win\bcc C:\harbour\bin
hbmk2: Using C compiler: C:\bcc55\bin\bcc32.exe
hbmk2: Processing: hbxpp.hbc
hbmk2: Processing: gtwvg.hbc
hbmk2: Processing: C:\harbour\contrib\hbwin\hbwin.hbc
hbmk2: Compiling Harbour sources...
hbmk2: Harbour compiler command (embedded):
(C:\harbour\bin\harbour.exe) -n2 e:\harbour\WMP\WM9.PRG e:\harbour\WMP\ALERTBOX.PRG e:\harbour\WMP\CHECKAPP.PRG e:\harbour\WMP\CUTBBMP.PRG e:\harbour\WMP\CUTPLAY.PRG e:\harbour\WMP\cuttrans.prg e:\harbour\WMP\CUTWM6.PRG e:\harbour\WMP\IMAGEPB.PRG e:\harbour\WMP\MENUS.PRG e:\harbour\WMP\MOUSEDLG.PRG e:\harbour\WMP\REGCLASS.PRG e:\harbour\WMP\scLEVI.prg e:\harbour\WMP\SCMANAGE.PRG e:\harbour\WMP\SLEPIC.PRG e:\harbour\WMP\STATBAR.PRG e:\harbour\WMP\TITLEBAR.PRG e:\harbour\WMP\TRANSPAR.PRG e:\harbour\WMP\TRENNER.PRG e:\harbour\WMP\WERTTYPE.PRG e:\harbour\WMP\WM9CLASS.PRG e:\harbour\WMP\WM9COLOR.PRG e:\harbour\WMP\WM9DBF.PRG e:\harbour\WMP\WM9DLLFU.PRG e:\harbour\WMP\WM9EDIT.PRG e:\harbour\WMP\WM9FILTE.PRG e:\harbour\WMP\WM9INOUT.PRG e:\harbour\WMP\WM9M3U.PRG e:\harbour\WMP\WM9MENU.PRG e:\harbour\WMP\WM9PANEL.PRG e:\harbour\WMP\WM9PLBOX.PRG e:\harbour\WMP\WM9STACK.PRG e:\harbour\WMP\WM9TOOLS.PRG e:\harbour\WMP\WMTHREAD.PRG e:\harbour\WMP\xbplayer.prg e:\harbour\WMP\XbpPBar.prg e:\harbour\WMP\YBPPUSH.PRG -w1 -es0 -q -o.hbmk\win\bcc\ -iC:\bcc55\Include -iC:\harbour\include -ic:\hmg.3.4.4\HARBOUR\contrib\hbxpp -ic:\hmg.3.4.4\HARBOUR\contrib\gtwvg -iC:\harbour\contrib\hbwin -ie:\harbour\include -ic:\hmg.3.4.4\bcc55\Include -undef:.ARCH. -D__PLATFORM__WINDOWS -D__LITTLE_ENDIAN__ -D__ARCH32BIT__
Harbour 3.0.0 (Rev. 16951)
hbmk2: Compiling...
hbmk2: C/C++ compiler command:
bcc32.exe -c -q -d -6 -O2 -OS -Ov -Oi -Oc -tW -tWM -w -Q -w-sig- -n.hbmk\win\bcc -IC:\bcc55\Include -IC:\harbour\include -Ic:\hmg.3.4.4\HARBOUR\contrib\hbxpp -Ic:\hmg.3.4.4\HARBOUR\contrib\gtwvg -IC:\harbour\contrib\hbwin -Ie:\harbour\include -Ic:\hmg.3.4.4\bcc55\Include .hbmk\win\bcc\WM9.c .hbmk\win\bcc\ALERTBOX.c .hbmk\win\bcc\CHECKAPP.c .hbmk\win\bcc\CUTBBMP.c .hbmk\win\bcc\CUTPLAY.c .hbmk\win\bcc\cuttrans.c .hbmk\win\bcc\CUTWM6.c .hbmk\win\bcc\IMAGEPB.c .hbmk\win\bcc\MENUS.c .hbmk\win\bcc\MOUSEDLG.c .hbmk\win\bcc\REGCLASS.c .hbmk\win\bcc\scLEVI.c .hbmk\win\bcc\SCMANAGE.c .hbmk\win\bcc\SLEPIC.c .hbmk\win\bcc\STATBAR.c .hbmk\win\bcc\TITLEBAR.c .hbmk\win\bcc\TRANSPAR.c .hbmk\win\bcc\TRENNER.c .hbmk\win\bcc\WERTTYPE.c .hbmk\win\bcc\WM9CLASS.c .hbmk\win\bcc\WM9COLOR.c .hbmk\win\bcc\WM9DBF.c .hbmk\win\bcc\WM9DLLFU.c .hbmk\win\bcc\WM9EDIT.c .hbmk\win\bcc\WM9FILTE.c .hbmk\win\bcc\WM9INOUT.c .hbmk\win\bcc\WM9M3U.c .hbmk\win\bcc\WM9MENU.c .hbmk\win\bcc\WM9PANEL.c .hbmk\win\bcc\WM9PLBOX.c .hbmk\win\bcc\WM9STACK.c .hbmk\win\bcc\WM9TOOLS.c .hbmk\win\bcc\WMTHREAD.c .hbmk\win\bcc\xbplayer.c .hbmk\win\bcc\XbpPBar.c .hbmk\win\bcc\YBPPUSH.c .hbmk\win\bcc\_hbmkaut_WM9.c
.hbmk\win\bcc\WM9.c:
Warning W8065 e:\\harbour\\WMP\\HBXBASE.CH 46: Call to function 'hb_itemGetDD' with no prototype in function HB_FUN_DATEASDOUBLE
.hbmk\win\bcc\ALERTBOX.c:
.hbmk\win\bcc\CHECKAPP.c:
.hbmk\win\bcc\CUTBBMP.c:
.hbmk\win\bcc\CUTPLAY.c:
.hbmk\win\bcc\cuttrans.c:
.hbmk\win\bcc\CUTWM6.c:
.hbmk\win\bcc\IMAGEPB.c:
.hbmk\win\bcc\MENUS.c:
.hbmk\win\bcc\MOUSEDLG.c:
.hbmk\win\bcc\REGCLASS.c:
.hbmk\win\bcc\scLEVI.c:
.hbmk\win\bcc\SCMANAGE.c:
.hbmk\win\bcc\SLEPIC.c:
.hbmk\win\bcc\STATBAR.c:
.hbmk\win\bcc\TITLEBAR.c:
.hbmk\win\bcc\TRANSPAR.c:
.hbmk\win\bcc\TRENNER.c:
.hbmk\win\bcc\WERTTYPE.c:
.hbmk\win\bcc\WM9CLASS.c:
.hbmk\win\bcc\WM9COLOR.c:
.hbmk\win\bcc\WM9DBF.c:
.hbmk\win\bcc\WM9DLLFU.c:
.hbmk\win\bcc\WM9EDIT.c:
.hbmk\win\bcc\WM9FILTE.c:
.hbmk\win\bcc\WM9INOUT.c:
.hbmk\win\bcc\WM9M3U.c:
.hbmk\win\bcc\WM9MENU.c:
.hbmk\win\bcc\WM9PANEL.c:
.hbmk\win\bcc\WM9PLBOX.c:
.hbmk\win\bcc\WM9STACK.c:
.hbmk\win\bcc\WM9TOOLS.c:
.hbmk\win\bcc\WMTHREAD.c:
.hbmk\win\bcc\xbplayer.c:
.hbmk\win\bcc\XbpPBar.c:
.hbmk\win\bcc\YBPPUSH.c:
.hbmk\win\bcc\_hbmkaut_WM9.c:
hbmk2: Linking... WM9.exe
hbmk2: Linker command:
ilink32.exe @R:\Temp\c5wmi0.lnk
hbmk2: Linker script:
-Gn -Tpe -LC:\bcc55\Lib;C:\bcc55\Lib\PSDK;C:\harbour\lib\win\bcc;C:\harbour\bin;e:\harbour\lib\win\bcc -aa c0w32.obj .hbmk\win\bcc\WM9.obj .hbmk\win\bcc\ALERTBOX.obj .hbmk\win\bcc\CHECKAPP.obj .hbmk\win\bcc\CUTBBMP.obj .hbmk\win\bcc\CUTPLAY.obj .hbmk\win\bcc\cuttrans.obj .hbmk\win\bcc\CUTWM6.obj .hbmk\win\bcc\IMAGEPB.obj .hbmk\win\bcc\MENUS.obj .hbmk\win\bcc\MOUSEDLG.obj .hbmk\win\bcc\REGCLASS.obj .hbmk\win\bcc\scLEVI.obj .hbmk\win\bcc\SCMANAGE.obj .hbmk\win\bcc\SLEPIC.obj .hbmk\win\bcc\STATBAR.obj .hbmk\win\bcc\TITLEBAR.obj .hbmk\win\bcc\TRANSPAR.obj .hbmk\win\bcc\TRENNER.obj .hbmk\win\bcc\WERTTYPE.obj .hbmk\win\bcc\WM9CLASS.obj .hbmk\win\bcc\WM9COLOR.obj .hbmk\win\bcc\WM9DBF.obj .hbmk\win\bcc\WM9DLLFU.obj .hbmk\win\bcc\WM9EDIT.obj .hbmk\win\bcc\WM9FILTE.obj .hbmk\win\bcc\WM9INOUT.obj .hbmk\win\bcc\WM9M3U.obj .hbmk\win\bcc\WM9MENU.obj .hbmk\win\bcc\WM9PANEL.obj .hbmk\win\bcc\WM9PLBOX.obj .hbmk\win\bcc\WM9STACK.obj .hbmk\win\bcc\WM9TOOLS.obj .hbmk\win\bcc\WMTHREAD.obj .hbmk\win\bcc\xbplayer.obj .hbmk\win\bcc\XbpPBar.obj .hbmk\win\bcc\YBPPUSH.obj .hbmk\win\bcc\_hbmkaut_WM9.obj, WM9.exe, nul, gtwvg.lib hbxpp.lib hbwin.lib png.lib hbextern.lib hbdebug.lib hbvmmt.lib hbrtl.lib hblang.lib hbcpage.lib gtcgi.lib gtpca.lib gtstd.lib gtwin.lib gtwvt.lib gtgui.lib hbrdd.lib hbuddall.lib hbusrrdd.lib rddntx.lib rddcdx.lib rddnsx.lib rddfpt.lib hbrdd.lib hbhsx.lib hbsix.lib hbmacro.lib hbcplr.lib hbpp.lib hbcommon.lib kernel32.lib user32.lib gdi32.lib advapi32.lib ws2_32.lib winspool.lib comctl32.lib comdlg32.lib shell32.lib uuid.lib ole32.lib oleaut32.lib mpr.lib winmm.lib mapi32.lib imm32.lib msimg32.lib wininet.lib hbpcre.lib hbzlib.lib cw32mt.lib import32.lib, ,
Turbo Incremental Link 5.00 Copyright (c) 1997, 2000 Borland
Error: Unresolved external '_HB_FUN_APPNAME' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_INIT_STACK' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NCOLOR1' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NCOLOR2' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NCOLOR3' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NCOLOR4' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NCOLOR5' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NCOLOR6' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NCOLOR7' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NCOLOR8' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NCOLOR13' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NCOLOR14' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_DARKMODE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_ISW98RUN' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_MSGBOX' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_RATEPLAY' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_XHB_COPYFILE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_CHKPREVAPP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_C_WM9PQUEU' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_FANO' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_C_SETUPCUE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_EDITDTOOL' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_C_WM9CAT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_C_WMPSETUP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_CHECKDBFSETUP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_CENTERPOS' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_APPDESKTOP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_FANOKEY' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_ENDLESS' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_PLAYALL' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_SCHRINK' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_PLAYFULL' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_ISUIMODE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_STRETCHFIT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_DLGEVENT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_DLGPLIST' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_DLGPANEL' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_MAUSSNAP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_DLGMINFO' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_VOLUME' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_SHUFFLE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_LOOP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_MARKBOX' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_MUTE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_EDITBOX' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_MARKONLY' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_RESID' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_LSTPLIST' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_XHB_TRIM' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_NOLOGO' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_BMPPATH' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_BMPXSIZE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_BMPYSIZE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_SKINPATH' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_FONTINFO' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_XBPDIALOGEX' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_HANDLEDRAGENTER' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_HANDLEDRAGLEAVE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_HANDLEDRAGDROP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_DLGWHEEL' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_DLGMAINRESIZE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_APPQUIT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SETAPPFOCUS' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_ACTIVEWIN' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_MAINONTOP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_STATUSBAR' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_HIDKEYS' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_MAKEFULL' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_EXXBPBITMAP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_ISTHEMEACTIVE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_LOGOBMP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_BMP2BMP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_LOGOVOLUME' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_LOVERWMP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_POSTAPPEVENT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SETNWAIT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_DLGEVENT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_DLGMINFO' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_DLGPANEL' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_MARKEDIT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_DLGPLAYLIST' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_XBPSCROLLBARWHEEL' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_SCOLLTIME' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_XBPSPINBUTTON' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_GETNWAIT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_C_WM9CDX' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_C_WM9DBF' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_C_MARK_CDX' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_C_WM9MARK' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_CREATEMENUSYSTEM' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_RMENU1' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_MARKBROW' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_PARA2MAIN' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_ISRUN' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SETAPPWINDOW' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_MAINEXIT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_MAUS2OBJ' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_APPEVENT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_NEWWINSIZE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_ONDUMMY' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_IMGSIZE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_POPABSPOS' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_INFOFONTMENU' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_FILEINFO' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_LISTBOX' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_ISRATED' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_FILETYPE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_RATEFILE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_HIBUTTON' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_PLAYPREV' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_LSCROLLON' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_WM9REWIND' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_PPSNIP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_PPNEXT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_PPSTOP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_WM9STOP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_XHB__KEYBOARD' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_WM9PLAY' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_WM9PAUSE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_WMPPSDEF' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_WM9STEP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_WM9SLOW' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_WM9FORWARD' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_PLAYNEXT' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SEC2HMS' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SCROLL2BAR' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_DURATION' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_ENDF5' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_REFRESH' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_MARKREFESH' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_MARKREC' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_USELASTRATE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_BINRATERECORD' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_WORM' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_WORMSTART' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_STOPPLAY' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_BROWMARK' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SAVEPLIST' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_THREADWRK' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SAVEVIEW' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SMPSETCPU' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_THREADINFO' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_VAR2CHAR' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_WM9OPLS' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_NDVDTIME' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_DBSCOPE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SNAPMARK' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_PLAYSNIP' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SHOWBROWMP3' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_RATECHOICE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_DUPENAME' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_MOREMUTE' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_SP_MOUSEPOS' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_GETCURSORPOS' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_ISMETHOD' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_CALCFONTDIM' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_HB_FUN_XHB_LIB' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
Error: Unresolved external '_hb_itemGetDD' referenced from E:\HARBOUR\WMP\.HBMK\WIN\BCC\WM9.OBJ
hbmk2: Error: Running linker. 2
Exit Code [ 7 ] Exit Status [ 0 ] Finished at [ 05:08:37 ] Done in [ 1.13 Secs ]
Detected executable => e:\harbour\WMP\WM9.exe
Sorry, cannot launch project because of errors...
