help with syntax
dragancesu
DBs Used: DBF, MySQL, Oracle
help with syntax
Post by dragancesu »
I use long hmg and some things still bother me, i don't like it
I prefer to use @ row, col CONTROL... instead of DEFINITON CONTROL...
that's why I don't use IDE, but many times I need help with syntax
I tried to create a program that will help me with the syntax for the controls, the parameters should be entered and you will see OK what you need to type in the text editor, but that text is in the clipboard so it is enough to press Ctrl-V or select Paste
The order of parameters at @ row, col CONTROL... and DEFINE CONTROL... is different, I don't know why but it bothers me
Pleasa write if you like it or don't like it and why
source soon
controls.zip
(1.46 MiB) Downloaded 215 times
huiyi_ch
Re: help with syntax
Post by huiyi_ch »
I like DEFINE CONTROL...
This software is so useful that adding it as a tool, such as XEDIT, will greatly facilitate coding.
Me too I sometimes have problems with these things.
When I need some comtrol I copy/paste it from one of my working programs and then I'm sure it work work fine for the first time.
dragancesu
New version with source
controls_source.zip
(30.05 KiB) Downloaded 174 times
controls_exe.zip
(1.48 MiB) Downloaded 186 times
Google Translation
Hello friend Dragancesu :
Congratulations for this interesting Tool
I do not understand why the BUTTON is giving Error?
it is only for the chronological order of the mandates
I do not understand ?
I found it !!! ---> Syntax Error
Error --> HEIGTH --> ok ---> HEIGHT
Error ---> TOOLDTIP '' -> ok ---> TOOLTIP
dragancesu
   @ 150, 100 BUTTON button_1 ;
      CAPTION 'caption_1'            ;
      PICTURE 'button.bmp' RIGHT ;
      ACTION nil ;
      WIDTH 80 HEIGTH 25 ;   -------->  Error  -->   HEIGTH    --> ok  ---> HEIGHT
      FONT 'Arial' SIZE 10
     Error ---> TOOLDTIP ''     ok --->   TOOLTIP
         FONT "Arial" SIZE 10          ;
         ACTION nil   ;
         WIDTH 80  HEIGHT 25
dragancesu
Hello Mustafa, try this
start CONTROL.EXE, clik on button WINDOW than OK, window definition is on display
open in yout editor, on example, test.prg and Ctrl-V and see like this
PROCEDURE main
   DEFINE WINDOW window_1 ;
      AT 100, 100 ;
      WIDTH 800 ;
      HEIGHT 600 ;
      MAIN ;
      *** insert your code here
   ACTIVATE WINDOW window_1
create next control and insert code by ctrl-v
all work but generate control BUTTON causes error during compile
It is not giving me any error
Did you modify the syntax error?
----> HEIGTH ----> OK HEIGHT
PROCEDURE main
      AT 100, 100 ;
      WIDTH 800 ;
      HEIGHT 600 ;
      MAIN ;
   @ 100, 100 BUTTON button_1 ;
      ACTION nil ;
      WIDTH 80 HEIGHT 25 ;
      FONT 'Arial' SIZE 10 ;
gfilatov
Post by gfilatov »
dragancesu wrote: Wed Oct 02, 2019 10:54 am generate control BUTTON causes error during compile
Hello Dragan,
Please be so kind to replace your typo
HEIGTH
with a correct
HEIGHT
as it was suggested by Mustafa :arrow:
dragancesu
Thank you
p.s. it may be time for retirement
dragancesu
New version
controls_exe.zip
(1.49 MiB) Downloaded 221 times
controls_source.zip
(44.93 KiB) Downloaded 198 times
