My application (DBF's) in ONEDRIVE
Hola a todos
Leí acerca de que se puede asignar una letra (Z:) a una carpeta creada en ONEDRIVE en la NUBE.
Seguí los pasos indicados en https://answers.microsoft.com/es-es/win ... 2304b1a126 y https://answers.microsoft.com/es-es/mso ... 8aa1b71ec8 , y vaya sorpresa, FUNCIONO !!!.
Ejecute mi aplicación (con DBF´s) desde la NUBE. (Estas son mis primeras pruebas)
Hello everyone
I read that you can assign a letter (Z:) to a folder created in ONEDRIVE in the CLOUD.
I followed the steps indicated in https://answers.microsoft.com/es-es/win ... 2304b1a126 and https://answers.microsoft.com/es-es/mso ... 8aa1b71ec8 , and what a surprise, IT WORKED !!!
Run my application (with DBF's) from the CLOUD. (These are my first tests)
Anand
Re: My application (DBF's) in ONEDRIVE
Post by Anand »
WOW !! What a possibility you have shown, Andrés.
I was ignoring OneDrive and using GDrive till now. But now I will check it and try the cloud-dbf thing. This will help in many situations.
Thanks a lot.
I found this too https://www.thewindowsclub.com/map-oned ... windows-10, may help those with English and do not need to translate above link.
Anand
Anand
Did you tested record blocking in OneDrive disk?
mol wrote: Sat Sep 28, 2019 10:38 am Did you tested record blocking in OneDrive disk?
Hola Mol
No lo he hecho aún, solo quería probar lo de la asignación de la carpeta a una unidad de la PC
y copie una sencilla aplicación.
Hello mol
I haven't done it yet, I just wanted to try the assignment of the folder to a PC drive
and copy a simple application.
Anand
Post by Anand »
Tell us after you have checked add/edit etc. Records of the dbf .
Even if only reading and filter works, it is a good opportunity.
Anand
Anand
ASESORMIX
Post by ASESORMIX »
Gracias por esta información.
Amplia grandemente las posibilidades de nuestras aplicaciones.
Pues al parecer todo funciona igual, (Añadir, Borrar, Cambios) !!!
Los archivos involucrados fueron actualizados. (DBF, DBT, NTX, )
Faltaría probar:
* Velocidad de captura
* Velocidad de Consultas
* Multiusuario
* Etc.
Well, apparently everything works the same, (Add, Delete, Changes) !!!
The files involved were updated. (DBF, DBT, NTX,)
It would be necessary to prove:
* Capture speed
* Query Speed
* Multiuser
* Etc.
DBF's Modificados OK.png (181.18 KiB) Viewed 5387 times
La Configuración de mi PC, ejecutando la aplicación desde ONEDRIVE
Primer problema :(
No he podido pasar a ONEDRIVE un archivo DBF que pesa 206 MB (1 Millon de registros), se queda en 99%
para hacer una prueba de CONSULTAS.
Anand
Post by Anand »
Hi Andrés,
Thanks for so much information.
Now can you confirm that all the dbf activity is happening at OnDrive, i.e. no dbf/ntx is changed in any folder in your machine ?
To be sure, you can run your app from another machine which do not have the said data and check.
Anand
Anand
