LIBhmg-64.a / LibLibPq-64.a
- AUGE_OHR
Re: LIBhmg-64.a / LibLibPq-64.a
as i now know that is working that Way i like to ask how build a LIB instead of EXE
how to integrate it into HMG IDE so i need only to press F5
- AUGE_OHR
i try to build LIB and i got some LIB.a ... but still get PQ* Error when use them
i have in *.HBC
both Version create LIB.a but both with same Error
c:\hmg.3.4.4\HARBOUR-64\bin\hbmk2.exe -oLibpq-64 -hblib -Id:\PG\include\ -Ld:\ALASKA\_hrb_dev\HB3\64BIT\LIB -llibpq postgres.c rddcopy.c tpostgre.c
or
c:\hmg.3.4.4\MinGW-64\bin\ar rc .\liblibpQ-64.a postgres.o rddcopy.o tpostgre.o d:\ALASKA\_hrb_dev\HB3\64BIT\LIB\libpq.LIB
libpaths=c:\hmg.3.4.4\LIB-64
libs=Libpq-64
mt=yes
so what are missing as it work when link files direct to EXE...
C:/hmg.3.4.4/lib-64\libLibpq-64.a(postgres.o):postgres.c:(.text+0x2857): undefined reference to `PQuntrace'
hbmk2[DBF2PG3]: Error: Running linker. 1
gcc.exe R:/Temp/hbmk_0h8zda.dir/DBF2PG2.o R:/Temp/hbmk_0h8zda.dir/PGRDD.o R:/Temp/hbmk_0h8zda.dir/hbmk_h7aqw3.o D:/ALASKA/_hrb_dev/HB3/DBF2PG/64/_temp.o -pthread -static-libgcc -static-libstdc++ -static -lpthread -mwindows -Wl,--start-group -l"hmg-64" -l"crypt-64" -l"edit-64" -l"editex-64" -l"graph-64" -l"ini-64" -l"report-64" -l"hfcl-64" -lmsvfw32 -lvfw32 -l"hbvpdf-64" -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -l"Libpq-64" -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oDBF2PG3.exe -L"C:/hmg.3.4.4/harbour-64/lib/win/mingw64" -L"C:/hmg.3.4.4/lib-64" -L"c:/hmg.3.4.4/LIB-64"
- AUGE_OHR
i'm a harbour Newbiew so forgive my Question
i have compile 3 PRG where 1nd PRG contain CLASS TPQserver this Way
now when compile DBF2PG2.PRG, where i call TPQserver:New(), it does not compile ... missing TPQserver
CLASS TPQserver is in tpostgre.prg which have "transpile" before.
so what to include in DBF2PG2.PRG to get rid of Error
harbour.exe tpostgre.prg -n -m -w -es2 -gc0 -ic:\hmg.3.4.4\INCLUDE -ic:\hmg.3.4.4\HARBOUR-64\include
harbour.exe PGRDD.PRG -n -m -w -es2 -gc0 -iC:\hmg.3.4.4\include -ic:\hmg.3.4.4\HARBOUR-64\include
harbour.exe DBF2PG2.PRG -n -m -w -es2 -gc0 -iC:\hmg.3.4.4\include -ic:\hmg.3.4.4\HARBOUR-64\include
Try using .hbp 'project' file and write app prgs names in it, like .xpj or Xbase++.
This will get rid of Error.
Anand
- AUGE_OHR
thx for Answer
i have try different Way to create a LibLibPQ-64.a and got some *.a ... but they all fail.
so i made all on Command line and i got working 64 Bit EXE.
i can work with it but it is not a Solution for all other using HMG IDE so i ask again how to build a 64 Bit Lib.a
thx for Answer
my Problem is that how to include LibPQ.LIB of PostgreSQL into Project *.HBP
also Hintskipping incompatible C:/hmg.3.4.4/lib-64\liblibpq-64.a when searching for -llibpq-64
does not work while it point to 32 Bit LIBHint: Install package hbpgsql and add option 'hbpgsql.hbc' for missing
- AUGE_OHR
i got a Tip to use DLLTOOL of MING to create a "Import LIB"
http://www.mingw.org/wiki/CreateImportLibraries
Problem : i fail to create a *.DEF
i have a *.DEF from LIB2A Tool so i try thatliblibpq-64.a was create ... but after press F5 i still got PQ* Error
i also try this Waybut again PQ* Error
only when link 64 Bit LibPQ.LIB work ... but i can't use it this Way with HMG IDE.
does someone have a Idea
c:\hmg.3.4.4\MinGW-64\bin\dlltool.exe: libpq.DLL: no symbolsCode: Select all
c:\hmg.3.4.4\MinGW-64\bin\dlltool.exe -z libpq.def --export-all-symbol libpq.DLL
c:\hmg.3.4.4\MinGW-64\bin\dlltool -d libpq.def -l liblibpq-64.a
i also try this Way
hbmk2.exe TEST.PRG c:\hmg.3.4.4\LIB-64\Liblibpq-64.a
- AUGE_OHR
i ask while DLL / LIB seem from v11.5 and LibLibPQ.a seem not to work in my Environment with Postgre v9.5.
do every Postgre Version need "own" Import LIBdanielmaximiliano wrote: ↑Tue Sep 03, 2019 1:14 pm Download and copy folder c:\hmg.3.4.4\LIB-64
liblibpq-64.rar
rename liblibpq-64.rar to liblibpq-64.a
- AUGE_OHR
i'm still struggle with 64 Bit LibLibPQ.a ...
now i found a Blog about
they point to a Tool called MSYS which is include in this Distribution
https://sourceforge.net/projects/mingw/files/
but again it seem me 32 Bit and i don't find MSYS in 64 Bit Version of MinGW.
can somebody tell me where i find 64 Bit Version of MSYS
did someone use BCC v7.x 64 Bit with harbour / HMG how to include it
Ok it is XP (32 Bit ?) and LibPQ.DLL v8.3.5 but the Problem seem me the same with 64 Bit."Building PostgreSQL client library using MinGW under WinXP SP3"
https://pgolub.wordpress.com/2008/12/15 ... winxp-sp3/
