LIBhmg-64.a / LibLibPq-64.a
i try HMG 64 bit and have download 3 Files
HMG.3.4.4.Setup.exe
HMG.3.4.4.Setup.exe "HARBOUR-64 (nightly 2016-04-20).rar"
MinGW-64_ver.5.3.0.rar
after install HMG.3.4.4.Setup.exe i have copy *.RAR file into c:\hmg.3.4.4\
than i run _BuildAllLib64.bat -> OK
now i start IDE and try c:\hmg.3.4.4\hmg64.hbp but it fail with
Harbour 3.2.0dev (r1604201603)
C:/hmg.3.4.4/mingw-64/bin/../lib/gcc/x86_64-w64-mingw32/5.3.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lhmg-64
under c:\hmg.3.4.4\LIB-64\ i did not LIBhmg-64.a ... where do i get it :?:
p.s. what about LibLibPq.a ... is there a LibLibPq-64.a :?:
jairpinho
Re: LIBhmg-64.a / LibLibPq-64.a
Post by jairpinho »
AUGE_OHR wrote: Sat Aug 31, 2019 5:34 am hi,
HMG.3.4.4.Setup.exe
Follow
viewtopic.php?f=43&t=5198
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
jairpinho wrote: Sat Aug 31, 2019 6:55 pm Follow
thx for Link.
i have download these 3 files an search in that Thread for "Libpq" but there is nothing.
also search in Forum does not give any result :?:
i have read about DLLTOOL.EXE (c:\hmg.3.4.4\MinGW-64\x86_64-w64-mingw32\bin\dlltool.exe) but there is not help how to use it. :|
with BCC and 32 Bit i can use this
In cmd, type:
implib -a libpq.lib libpq.dll.
the libpq.lib is generate.
how to do it with Ming64 :?:
jairpinho
Post by jairpinho »
AUGE_OHR wrote: Sat Aug 31, 2019 9:09 pm hi,
thx for Link.
In cmd, type:
hello, at 64 bits we don't have much support because hmg is stuck in your 32 bit update and was starting at 64bits, i couldn't use mysql at 64bits, we are trying to solve our problems here on the forum and sometimes we have the masters that They have already worked on this project to help us according to their available time.
viewtopic.php?f=5&t=5362&p=52182&hilit= ... bit#p52182
Jair Pinho
Try Unicode
2019-08-31 18_56_47-Window.png (7.56 KiB) Viewed 32972 times
jairpinho
Post by jairpinho »
Jair Pinho
Builds Harbour library hbpgsql.lib and converts original POstgreSQL libpq.lib (COFF) to OMF format (for Borland) in Minigui Extended
HbPgSql.rar
(152.78 KiB) Downloaded 644 times
danielmaximiliano wrote: Sat Aug 31, 2019 10:26 pm Builds Harbour library hbpgsql.lib and converts original POstgreSQL libpq.lib (COFF) to OMF format (for Borland) in Minigui Extended
HbPgSql.rar
THX for CLASS TPQServer
thx all for your Answer.
i have use c:\hmg.3.4.4\_BuildAllLib64.bat but it does not include
c:\hmg.3.4.4\SOURCE\HMGSQL\
to build HMG_SQL_Bridge libhmgpgsql.a
file LIB-64.ZIP*** include libhmgpgsql-64.a so i will try that.
*** hmgforum.com/viewtopic.php?f=46&t=5479&p=53574
AUGE_OHR wrote: Sun Sep 01, 2019 3:43 am file LIB-64.ZIP*** include libhmgpgsql-64.a so i will try that.
does not help when have no LibLibPg-64.a :cry:
i have 32 Bit
c:\hmg.3.4.4\HARBOUR\lib\win\mingw\liblibpq.a
i search for 64 Bit Version but not find under
c:\hmg.3.4.4\HARBOUR-64\lib\win\mingw64\
or somewhere else (Everything Search)
my *.HBC
libpaths=c:\hmg.3.4.4\LIB-64
libs=hmgpgsql-64
libpaths=c:\hmg.3.4.4\HARBOUR\lib\win\mingw
libs=libpq
mt=yes
i and i got this
C:/hmg.3.4.4/mingw-64/bin/../lib/gcc/x86_64-w64-mingw32/5.3.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible c:/hmg.3.4.4/HARBOUR/lib/win/mingw\liblibpq.a when searching for -llibpq
C:/hmg.3.4.4/mingw-64/bin/../lib/gcc/x86_64-w64-mingw32/5.3.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -llibpq
hbmk2[DBF2PG3]: Error: Running linker. 1
gcc.exe R:/Temp/hbmk_ofj64e.dir/DBF2PG2.o R:/Temp/hbmk_ofj64e.dir/PGRDD.o R:/Temp/hbmk_ofj64e.dir/tpostgre.o R:/Temp/hbmk_ofj64e.dir/hbmk_6xeh0k.o D:/ALASKA/_hrb_dev/HB3/DBF2PG/64/_temp.o -pthread -static-libgcc -static-libstdc++ -static -lpthread -mwindows -Wl,--start-group -l"hmg-64" -l"crypt-64" -l"edit-64" -l"editex-64" -l"graph-64" -l"ini-64" -l"report-64" -l"hfcl-64" -lmsvfw32 -lvfw32 -l"hbvpdf-64" -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -l"hmgpgsql-64" -llibpq -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oDBF2PG3.exe -L"C:/hmg.3.4.4/harbour-64/lib/win/mingw64" -L"C:/hmg.3.4.4/lib-64" -L"c:/hmg.3.4.4/LIB-64" -Lc:/hmg.3.4.4/HARBOUR/lib/win/mingw
