I made an application based on GRID2EXCEL that XLSXClass applies. It works without problem but, when I run it, a black window appears behind the application.
Possibly Alzheimer's does not allow me to discover what I did wrong.
Any ideas ?
Thanks since now.
Best Regards
Attach Screenshot
Black Window Background
- HGMForum-01.jpg (74.01 KiB) Viewed 12937 times
- dragancesu
Re: Black Window Background
grandma: who keeps hiding my stuff?
grandson: Alzheimer's grandmother
remind him to give you a code and put it here, or send him a crystal ball
When you're right ... you're right ... LOL
These are my little steps that brought me to this place ..
1º Write XLS with pure Harbour Class
viewtopic.php?f=11&t=5629&p=54969&hilit=xlsx#p54969
2º Harbour Users › Read/write XLS without OLE
https://groups.google.com/forum/#!topic ... RtLzf_1E
3º Implementing class in a excel example Grid2Excel
https://groups.google.com/d/msg/harbour ... 87mw8EwAJ
To create apps console/mixed mode, you only need to add this followinq command (red color):
REQUEST HB_GT_WIN_DEFAULT (at top of your main prg file).
See example:
Function Main()
SetMode(25,80)
Cls
@ 10,10 Say 'Hello'
Alert('Hello')
Si , eso era , ahora recuerdo cuando recien comencé con Harbour y aun usaba el modo consola terminal .
Muchisimas Gracias por refrescar mi memoria.
Mi Alzheimer te lo agradece . Puede que algun dia me gradue del Kindergarden.
Yes, that was it, now I remember when I just started with Harbour and still used the terminal console mode.
Thank you so much for refresh my memory.
danielmaximiliano wrote: ↑Thu Aug 15, 2019 4:32 pmTo create apps console/mixed mode, you only need to add this followinq command (red color):
See example:
Function Main()
SetMode(25,80)
Cls
@ 10,10 Say 'Hello'
Alert('Hello')
