OOP programming
ROBROS
OOP programming
Post by ROBROS »
Dear friends,
as you know I'm not a professional coder, but with your help, now I am able to write hmg programs (gui), and I am very proud of that. But, when asked if hmg was OOP programming, I had to admit, that to my knowledge, hmg is not. So I had to learn that hmg is obsolete, not worth spending time to develop apps with hmg.
Up to now I had to accept these point of views.
But I stumbled across this link and that made me calm:
https://www.youtube.com/watch?v=QM1iUe6IofM
For the kind of apps I am creating, OOP gives me no advantage. I can keep my procedural programming.
Maybe it's worth to view.
Thank you
Robert
Re: OOP programming
Who said Habour is not having OOP?
Clipper is Result Oriented or Purpose Oriented.
gfilatov
Re: OOP programming
Post by gfilatov »
ROBROS wrote: Sun Apr 21, 2019 9:57 pm Dear friends,
Hello Robert,
If you interested in OOP programming (I'm not sure), then Minigui Extended Edition offers the OOP programming with the command
SET OOP ON
Please take a look for a small sample below:
#include "minigui.ch"
MEMVAR oMain, oWnd
	LOCAL hSplitHandle, nY, nH
	SET OOP ON
	SET CENTURY ON
	SET DATE AMERICAN
		WIDTH 800 HEIGHT 600 ;
		TITLE 'MiniGUI SplitBox Demo' ;
		MAIN ;
		FONT 'Arial' SIZE 10
		PUBLIC oMain := ThisWindow.Object
		DEFINE MAIN MENU
			POPUP '&File'
				ITEM 'Exit'	ACTION Form_1.Release
			END POPUP
			POPUP '&Help'
				ITEM 'About'	ACTION MsgInfo (MiniGUIVersion(), "MiniGUI SplitBox Demo")
			END POPUP
		END MENU
		DEFINE SPLITBOX HANDLE hSplitHandle
			DEFINE TOOLBAR ToolBar_1 BUTTONSIZE 85,85 FLAT
				BUTTON Button_1 CAPTION '&More ToolBars...' PICTURE 'res\button1.bmp' ACTION MsgInfo('Click! 1')  TOOLTIP 'ONE'
				BUTTON Button_2 CAPTION '&Button 2' PICTURE 'res\button2.bmp' ACTION MsgInfo('Click! 2')  TOOLTIP 'TWO'
				BUTTON Button_3 CAPTION 'Button &3' PICTURE 'res\button3.bmp' ACTION MsgInfo('Click! 3')  TOOLTIP 'THREE'
			END TOOLBAR
		END SPLITBOX
		DEFINE STATUSBAR
			STATUSITEM 'HMG Power Ready'
			STATUSITEM ''
			DATE
			IF "/" $ Set( 4 )
				CLOCK AMPM
				CLOCK
		END STATUSBAR
		PRIVATE oWnd := oMain
		IF oWnd:HasStatusBar
			SetStatusbarProperties()
		nY := GetWindowHeight( hSplitHandle )
		nH := oWnd:ClientHeight - iif( oWnd:HasStatusBar, oWnd:StatusBar:Height, 0 ) - nY
		@nY +  5, 10 LABEL lblClientH VALUE "Client Area Height = " + hb_ntos( nH ) + " pixels" AUTOSIZE
		@nY + 25, 10 LABEL lblClientW VALUE "Client Area Width = " + hb_ntos( oWnd:ClientWidth ) + " pixels" AUTOSIZE
	CENTER WINDOW Form_1
Procedure SetStatusbarProperties
	LOCAL nItem := 2
	WITH OBJECT oWnd:StatusBar
		:Icon("res\smile.ico")
		:Icon("res\smile.ico", nItem)
		:Say(MiniGUIVersion(), nItem)
		:Width(nItem, 300)
		:Action(nItem, {|| MsgInfo('Status Item Click!')})
	END WITH
ROBROS
Re: OOP programming
Post by ROBROS »
Thank you for your replies, but indeed, I am not interested in OOP. As for me, I can't see any advantages to use OOP.
Robert
Anand
Re: OOP programming
Post by Anand »
My main development is in XBase++ ( OOP oriented) along with procedural language. The linked video gives advantage and disadvantage of both. We have to use advantage ones as per project in hand. We can not use gun to kill a mosquito.
HMG and HMG MiniGUI both allows you to code in OOP and procedural manner. It should depend on your job requirement.
And HMG is NOT obsolete. It allows you to develop for 64 bit OS in simple codes.
Anand
Anand
Re: OOP programming
ROBROS wrote: Sun Apr 21, 2019 9:57 pm ...
Hi Robert
First: OOP not a programming way, simply a "style"; so we can't talk any programming language if it is OOP or not. A language may or may not support OOP. And in programming using or not OOP never mains it is modern or obsolete.
Second: HMG isn't a compiler; a Graphical User Interface library for Harbour compiler. So we can't talk about "HMG programming" but Harbour Programming with HMG Library.
Third: If you inspect carefully Harbour documentation you will see OOP statements and functions, such as METHOD, CLASS, HBClass etc. So, Harbour fully supplying OOP,
In result everybody who using HMG for programming purpose should use Harbour compiler; and everybody who use Harbour freely use or not OOP.
Some OOP addicts claim OOP is good, so it is an advanced ( even last ) gradation in programming. This is personal and group point of view; and OOP is old than HMG, Harbour even Clipper.
Happy programming :)
Re: OOP programming
For the time being everything I programmed this far was based on the old fashioned way, which works fine, for me!
franco
Re: OOP programming
Post by franco »
Franco
All The Best,
Franco
Canada
ROBROS
Re: OOP programming
Post by ROBROS »
Dear friends,
many thanks for all replies, and of course I didn't have in mind hmg is not a compiler but a user interface (harbour mini graphical user interface). Though I don't know the difference oop vs procedural really, as Serge said, when the old fashioned way works, why leave it.
Another last question: a professional programmer, who knows how to program oop, would he be able to to find out (not having the source code) whether it was coded the oop-way or the "old way"? I suppose he will not be able to find out.
Kind regards
Robert
hmg is great and so is this forum.
apais
Re: OOP programming
Post by apais »
See this:
Procedural way:
procedure Main
step(1)
Step(2)
Steo(3)
return
OOP way
procedure Main // this pattern is usually seen in object javascript libs like ANGULAR,VUE, etc and Java
local app := AppNew()
app:var1 := whatever
app:step1 := {||step1()}
app:step1 := {||step2()}
app:step1 := {||step3()}
app:exec()
return
Angel Pais
