HMG 3.0.0 + IDE + HFCL (Forum Test VIII)
- HMG 3.0.0 (Forum Test VIII) Changelog:
English:
- Modified: HMG installation is portable now, so it could be installed
in a different folder than c:\hmg and work without need to reconfigure.
- Updated: Harbour compiler to 2.0 (Created from SVN 2009.10.14).
HMG IDE 2.9.4 and earlier versions ARE NOT COMPATIBLE with this
HMG version.
- Updated: MingW compiler to 4.4.1
- Modified: Samples.
Removed: ADORDD samples (adordd not working on
current Harbour release)
Added:
-\HMG\SAMPLES\RDD.SQL\MYSQL
-\HMG\SAMPLES\RDD.SQL\ODBC
-\HMG\SAMPLES\RDD.SQL\ARRAY
-\HMG\SAMPLES\MEMORY.TABLES
-\HMG\SAMPLES\MULTI.WIN
-\HMG\SAMPLES\SQLITE
-\HMG\SAMPLES\POSTGRESQL
-\HMG\SAMPLES\NETIO.CLIENT
-\HMG\SAMPLES\NETIO.SERVER
Modified:
-\HMG\SAMPLES\MULTI.PRG
New: 'Build.bat' (it replaces 'compile.bat').
Build [/i|/r|/d|/cs|/ci/cr] <PrgFile> | <filelist.hbp> [config.hbc]
[/i] : incremental build
[/r] : incremental build (rebuild all)
[/cs] : Console/mixed mode (std build)
[/ci] : Console/mixed mode (incremental build)
[/cr] : Console/mixed mode (incremental rebuild all)
[/d] : Debug mode (gui and console)
<filelist.hbm> : A text file with .hbp extension containing a source list
<configfile.hbc>: A text file with configuration parameters as additional
libs, include paths and lib paths.
<configfile.hbc> Syntax:
incpaths = incpath1 incpath2 ... incpathn
libpaths = libpath1 libpath2 ... libpathn
libs = lib1 lib2 ... libn
- library names must not include 'lib' prefix nor '.a' extension.
- 'build.bat' will create an 'error.log' file in the app folder when build
process ends with an error condition.
Sample: \HMG\SAMPLES\MULTI.PRG
Español:
- Modificado: La instalación de HMG es portable desde esta versión.
Por lo tanto, puede ser instalado en cualquier carpeta (diferente de
c:\hmg).
- Actualizado: Harbour compiler a 2.0 (SVN 2009.10.12)
HMG-IDE versión 2.9.4 y anteriores no es compatible con esta versión
de HMG.
- Actualizado: MingW compiler a 4.4.1
- Modificado: Samples.
Eliminado: Ejemplos ADORDD (adordd no funciona en la
versión actual de Harbour)
Agregados:
Modificado:
Nuevo:'Build.bat' (reemplaza a 'compile.bat').
<filelist.hbp> : Un archivo de texto con la lista de programas del proyecto.
<configfile.hbc>: Un archivo de texto con información de configuración
(librerías adicionales y paths de include y librerías adicionales).
- Los nombres de librería no deben incluir el prefijo 'lib' ni la
extensión '.a'
- 'build.bat' creará un archivo llamado 'error.log' en la carpeta de la
aplicaci'ón cuando el proceso de compilación falle.
Ejemplo: \HMG\SAMPLES\MULTI.PRG
Download/Descarga: hmg300_Test_08.exe
Saludos/Regards,
Roberto.
Vanguarda
Re: HMG 3.0.0 + IDE + HFCL (Forum Test VIII)
Post by Vanguarda »
Thank´s Master,
I´ll test it.
My best regards,
luisvasquezcl
Post by luisvasquezcl »
excelente ... descargando para testear, gracias.
saludos cordiales,
Luis Vasquez
luisvasquezcl
Hi Roberto,
i try to build one application and i can't.
this is the errorlog
windres: _temp.rc:43: syntax error
hbmk2: Processing: Socios.hbc
hbmk2: Compiling Harbour sources...
Harbour 2.0.0beta3 (Rev. 12700)
Copyright (c) 1999-2009, http://www.harbour-project.org/
hbmk2: Compiling...
hbmk2: Linking... Socios.exe
gcc.exe: _temp.o: No such file or directory
gcc.exe .hbmk\win\mingw\main.o .hbmk\win\mingw\dbutil.o .hbmk\win\mingw\form101.o .hbmk\win\mingw\form102.o .hbmk\win\mingw\form103.o .hbmk\win\mingw\form104.o .hbmk\win\mingw\form105.o .hbmk\win\mingw\form106.o .hbmk\win\mingw\form107.o .hbmk\win\mingw\form201.o .hbmk\win\mingw\form202.o .hbmk\win\mingw\form301.o .hbmk\win\mingw\form302.o .hbmk\win\mingw\form401.o .hbmk\win\mingw\struc.o .hbmk\win\mingw\_hbmkaut.o _temp.o -mwindows -Wl,--start-group -lminigui -lhbmysql -lmysql -lcrypt -ledit -leditex -lgraph -lini -lreport -lhbwin -lhbziparc -lhbmzip -lmsvfw32 -lvfw32 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbvpdf -lhbmemio -lhbsqlit3 -lsqlite3 -lhbfimage -lhbpgsql -lpq -lhbtip -lhbct -lhbmisc -lhbnetio -lhbextern -lhbdebug -lhbvm -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oSocios.exe -Lc:/hmg_test8/harbour/lib -Lc:/hmg_test8//lib
i compile from ide.
best regards,
Luis Vasquez
Vanguarda
Post by Vanguarda »
Hello Master,
At first congratulations for your amazing work. I like very much the new structure of folders in new HMG version.
I´ve a little doubt about HMG-IDE. I did the download and opened the IDE, open the sample in "C:\hmg\IDE\samples\REPORT" and when i click in icone "New Report" and i click in "Cancel" button, the IDE was very slow for return. Please see the picture bellow. It could be a bug?
My Windows version is : Windows XP SP/2, with default theme. My computer is a Celeron(R) D 3.6Ghz with 1GB RAM.
Thanks for your attention.
With Best Regards,
luisvasquezcl
I create a build.bat and socios.hbp and i can't to compiler.
error
gcc.exe Main.o DBUTIL.o form101.o form102.o form103.o form104.o form105.o form106.o form107.o form201.o form202.o form301.o form302.o form401.o STRUC.o hbmk_b9g3us.o _temp.o -mwindows -Wl,--start-group -lminigui -lhbmysql -lmysql -lcrypt -ledit -leditex -lgraph -lini -lreport -lhbwin -lhbziparc -lhbmzip -lmsvfw32 -lvfw32 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbvpdf -lhbmemio -lhbsqlit3 -lsqlite3 -lhbfimage -lhbpgsql -lpq -lhbtip -lhbct -lhbmisc -lhbnetio -lhbextern -lhbdebug -lhbvm -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -osocios.exe -Lc:/hmg_test8/harbour/lib -Lc:/hmg_test8//lib
best regards and good night.
Luis Vasquez.
luisvasquezcl wrote:Hi Roberto,
hbmk2: Compiling...
i compile from ide.
best regards,
Luis Vasquez
Your error is at line 43 of your resource file.
The new resource compiler give errors when (ie) resource name is the same as resource type ie: if you use 'button' as resource name it will generate an error in the new version and not in the prior.
Roberto.
Vanguarda wrote:Hello Master,
Thanks!
Vanguarda wrote: I´ve a little doubt about HMG-IDE. I did the download and opened the IDE, open the sample in "C:\hmg\IDE\samples\REPORT" and when i click in icone "New Report" and i click in "Cancel" button, the IDE was very slow for return. Please see the picture bellow. It could be a bug?
Yes. I've verified.
I try to find the cause.
Thanks for reporting.
Roberto.
Fantastic.
Thanks a lot Roberto.
With Best Regards,
Please, test:
ide_30_test_08_vanguarda_bug.rar
It has debugger support too.
Roberto.
