Quick Browse Form
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: Quick Browse Form
Post by dragancesu »
Hi Leopoldo
It's not easy to make a program that will satisfy everyone, but if I'm looking for an idea, it's possible to do what needs to be done
Look for HMGCASE, it's probably an older version but there are many useful tools, from data dictionaries, forms, reports, menus and more
There is also a version that works with MySQL
The model is oracle, forms is a great tool, it's really possible to make a form in minutes to work with all the possibilities of entering, editing, deleting, searching
The basic form with all functions can be done in a minute
p.s. program contacts was a program where I learned how the HMG program works, ie how to write programs for the windows environment
Now, write it for a minute you have to attachment
contact.zip
(20.51 KiB) Downloaded 380 times
Leopoldo Blancas
Post by Leopoldo Blancas »
Hello Dragancesu,
Does not compile your file, in which version should it be compiled?
You can share me in EXE, Thanks.
dragancesu
For compile just BUILD demo.prg
or use attachment
demoexe.zip
(1.47 MiB) Downloaded 399 times
Leopoldo Blancas
Thanks Dragancesu,
But I do not understand the mechanics to be able to create the forms quickly. Could you explain me in detail how you achieve it?
Greetings.
dragancesu
Leopoldo Blancas
Ok Dragancesu,
I think I need time to test your application, it looks like it does interesting things. I thought of a simpler application of just a few steps.
Although the relationship between tables is good to include it.
Like this:
dragancesu
Look hmgcase, it contain create master-detail form, two tables with relation
Leopoldo Blancas
dragancesu wrote: Thu Apr 04, 2019 4:48 pm Look hmgcase, it contain create master-detail form, two tables with relation
Yes, I am going to review it and make tests these days, today a little hurried in another type of work.
Greetings.
