Harbour MiniGUI Extended Edition build 19.03 is published
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
It is a regularly scheduled maintenance and bugfix release.
Here's a breakdown of some of the modifications in the build 19.03.
For the full list, please see the changelog.
* Misc bugfixes for the memory leaks in the ToolBar[Ex] control.
It was an ugly mistake with missed release of the bitmaps at a
destroying of a Tool Button.
* Fixed processing of the 'Item' property in a Grid when 'Value'
property equal a zero (problem was introduced in the build 18.08).
* Added a ban on an editing in a Browse control for databases that
were opened with the READONLY clause. Otherwise, an error "Write
not allowed" will occur.
* Added the following useful network functions:
- NetRecLock( nSeconds );
- NetFileLock( nSeconds );
- NetAppend( nSeconds, lReleaseLocks );
- NetDelete();
- NetRecall();
- IsLocked( nRecId );
- NetError().
The above network functions were used in a BROWSE control.
* Necessity of a lock's setting at the BROWSE editing will be
defined automatically for a database that opened in a shared mode.
* Added 'FIELD' clause (optional) to CHECKLABEL and SWITCHER
controls. They supports the 'Refresh' and 'Save' methods now.
* The functions SetProperty() and DoMethod() will detect a typo
in a name of the properties or methods.
* The function HMG_Alert() supports an optional 7-th parameter
for an array of colors for the buttons which will defined with the
BACKCOLOR and HANDCURSOR clauses.
Syntax:
HMG_Alert( cText, [<aOptions>], [<cTitle>], [<nType>], ;
[<cIcoName>], [<nIcoSize>], [<aBtnColors>] )
Added an optional possibility for colors tuning with the following
new commands:
- SET MSGALERT BACKCOLOR TO <aBackColor> [STOREIN <aBackColors>]
- SET MSGALERT FONTCOLOR TO <aFontColor> [STOREIN <aBackColors>]
* The unneeded clauses in the command GRAPH BITMAP may be omitted:
- TITLECOLOR (default is BLACK);
- SHOWGRID .T. supersede SHOWXGRID .T. and SHOWYGRID .T.;
- SEPARATION is NIL by default;
- NOBORDER is .F. by default.
* Added the following PROGRESSBAR MARQUEE commands for compatibility
with Official HMG:
SET PROGRESSBAR <name> OF <parent> ENABLE MARQUEE ;
[ UPDATED <milliseconds> ]
SET PROGRESSBAR <name> OF <parent> DISABLE MARQUEE
* Updated the TSBrowse, RDDLeto and Sqlite3 libraries.
* Added the new interesting samples and updated some Advanced samples.
A setup of the build 19.03 for Borland C++ 5.5.1 is published at
the following URL:
The upgrade to this build is highly recommended.
Thanks for your attention and support!
Best Regards,
[MiniGUI Team]
- NetDelete();
- NetRecall();
- NetError().
Syntax:
new commands:
with Official HMG:
the following URL:
Best Regards,
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 19.03 is published
Thanks Grigory.
I've uploaded the updated build 19.03 with the latest fixes for the problems which are introduced for CheckLabel control etc.
Please be so kind to upgrade your installation for a stable build
Thanks for your attention.
Nascimento
Thanks Grigory.
Many thanks Grigory!
Leopoldo Blancas
Many thanks Grigory!!!
- luisvasquezcl
congratulation for new release.
best regards
best regards
Thank you Grigory!
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
