Working on a JSON Project
sudip
Re: Working on a JSON Project
Post by sudip »
Hello Rathi,
Thanks a ton. I have a few days to work for my own. Your codes will be helpful for me.
sudip
Post by sudip »
Hello,
When I am trying to compile, getting a blank error screen and following error.log:
hbmk2: Linking... json.exe
C:/hmg/mingw/bin/../lib/gcc/i686-w64-mingw32/5.3.0/../../../../i686-w64-mingw32/bin/ld.exe: cannot find -lhmgsqlite
hbmk2[json]: Error: Running linker. 1
gcc.exe .hbmk/win/mingw/Main.o .hbmk/win/mingw/about.o .hbmk/win/mingw/htmlcreate.o .hbmk/win/mingw/htmlreport.o .hbmk/win/mingw/htmlviewer.o .hbmk/win/mingw/xlexport.o .hbmk/win/mingw/xmlcreate.o .hbmk/win/mingw/_hbmkaut_Main.o C:/HMGProjects/HBJSON3.0/_temp.o -pthread -static-libgcc -static-libstdc++ -static -lpthread -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbmysql -lmysql -lhbfimage -lhbpgsql -lsddmy -lhbvpdf -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhmgsqlite -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -ojson.exe -LC:/hmg/harbour/lib/win/mingw -LC:/hmg/lib
Here is the build.log:
As I'm using HMG after a long time, I couldn't solve it now. Can anyone please help me.
Thanks in advance ;-)
RPC
Post by RPC »
Hi Rathinagiri
I am trying to use HBJson/UniJsonViewer to convert Json file to Excel file. I am getting following errors.
When I try to convert to Excel(Flattened)
HMG Error UniJason2XL(Flattened).png (564.84 KiB) Viewed 5965 times
When I try to convert to Excel(Ref Tables)
HMG Error UniJason2XL(RefTable).png (571.84 KiB) Viewed 5965 times
When I try to convert to XML
HMG Error UniJason2XML.png (558.89 KiB) Viewed 5965 times
Finally I tried to compile json.hbp and got following blank screen.
HMG Error HBJason.png (22.95 KiB) Viewed 5965 times
I think Sudip has reported the same blank screen in immediate above post.
Can you please look into it whenever you get time.
Thanks
Rajeev
Please give me some sample json file. Let me check up.
RPC
Post by RPC »
Enclosing the json file which I was trying to process.
I have downloaded it from Income tax website as prefilled return.
ABGPB3678J.zip
(1.79 KiB) Downloaded 200 times
Please update the source with this:
HBJSON3.0.zip
(122.63 KiB) Downloaded 285 times
jayadevu
Post by jayadevu »
Hi Rathinagiri,
Thanks for the new Update. Just downloaded the same and compiled. It gives syntax error as seen in the attachement. This is the same json file which you had used in version 2. I had the same difficulty in Version 2 also. Please check.
RPC
Post by RPC »
Hi Rathinagiri sir
I am still getting blank screen on compilation as shown in my post earlier.
I am using HMG 3.4.4 my os is win 10 x64
thanks
