Anand
I agree, when Claudio left the development teamMinigui is developing - Minigui the advantage
I do not know why but Grigory prefers Borland, but it is perfectly possible to use MinGW. For example you can find a bundle for older versions over here:HMG uses a MinGW compiler that Minigui use old Borland compiler - HMG advantage
Hi Dragan,dragancesu wrote: ↑Sun Mar 03, 2019 10:49 pm HMG and Minigui are similar
I usually use HMG but i tried and Minigui
HMG is practically complete development, Minigui is developing - Minigui the advantage
Looking at what's new and developing, it's good to have the Minigui with MinGW compiler
Is that possible?
call c:\MiniGUI_1602_64\buildapp.bat < name file prg> Code: Select all
@echo off
set OLDPATH=%PATH%
set HMGPATH=c:\MiniGUI_1602_64
set PATH=%HMGPATH%\harbour\bin;%HMGPATH%\mingw64\bin;%PATH%
set HMGRPATH=c:\MiniGUI_1602_64
echo #define HMGRPATH %HMGRPATH%\RESOURCES > _hmg_resconfig.h
copy /b %HMGRPATH%\resources\hmg.rc+%1.rc+%HMGRPATH%\resources\filler _temp.rc >>nul
windres -i _temp.rc -o _temp.o
hbmk2 %1 %2 %3 %4 %5 %6 %7 %8 %HMGRPATH%\minigui.hbc -D__CALLDLL__ -q -run >build.log 2>&1
del _hmg_resconfig.h
del _temp.*
set HMGPATH=
set HMGRPATH=
set PATH=%OLDPATH%
This is what Rathinagiri Sir was doing. But since he is not answering the queries, who will take it up ?
Agree, but he is not answering now, so we are requesting Grigory for help.
