HMGSCRIPT R42
Re: HMGSCRIPT R42
Jair,
Cannot test while missing themes/desktop.css and lib/hmgscript.js
jairpinho
Re: HMGSCRIPT R42
Post by jairpinho »
serge_girard wrote: Tue Feb 19, 2019 10:09 am Jair,
I used the hmgscript42 folder, use this folder as reference and add the uploaded files
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: HMGSCRIPT R42
Jair,
Missing /php/mysql.php AND themes/desktop.css !
jairpinho
Re: HMGSCRIPT R42
Post by jairpinho »
serge_girard wrote: Tue Feb 19, 2019 3:43 pm Jair,
So I need an example with mariadb I do not use php, how to connect to mysql with mariadb ?, can I create the php file manually and add in my application does it work or not?
Jair Pinho
Re: HMGSCRIPT R42
Jair,
In function MySQLBrowse you use: xmlHttp.open( "POST" , "/php/mysql.php" , false ) ;
This PHP file will do all the work. You will have to create it yourself!
It will be something like this:
<?php
	$db = mysqli_connect( '127.0.0.1', 'root', '');  // your parameters!!
	if( ! $db ) :
		die( mysql_error() )	;
	endif;
	if( ! mysqli_select_db($db, 'bk')):
		die( mysql_error() );
	endif;
	$query = mysqli_query( $db, "select * from " );  / your parameters!!
	if( !$query ) :
		die("error SQL");
	endif;
	$table = array();
	while( $row = mysqli_fetch_array( $query, MYSQLI_NUM ) ):
		$table[] = $row;
	endwhile;
	$string	= json_encode( $table );
	mysqli_free_result( $query );
	mysqli_close($db);
	echo $string;
