Harbour MiniGUI Extended Edition build 19.01 is published
gfilatov
Post by gfilatov »
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
It is a regularly scheduled maintenance and bugfix release.
Here's a breakdown of some of the modifications in the build 19.01.
For the full list, please see the changelog.
* Fixed a problem with AUTOSIZE property handling in the CHECKLABEL
control.
* Added 'VCENTERALIGN' clause (optional) for vertical aligning of
a text in CHECKLABEL control.
* New: Switcher control for logical variables.
Syntax:
@ <row>,<col> SWITCHER <name> [ OF <parent> ] ;
HEIGHT 46 ;
IMAGE { 'MINIGUI_SWITCH_ON', 'MINIGUI_SWITCH_OFF' } ;
[ VALUE <cValue> ] ;
[ FONT <fontname> SIZE <fontsize> ] ;
[ LEFTCHECK ] [ CHECKED ] ;
[ ON MOUSEHOVER <bMouseHover> ] ;
[ ON MOUSELEAVE <bMouseLeave> ] ;
[ ON CLICK <bMouseClick> ]
* A Switcher control was used for managing of the logical variables
in the function InputWindow().
* Added an auxiliary conversion function
HMG_ClrToHTML( nClr ) --> cHtmlClr ( format "#rrggbb" )
* Updated the TSBrowse and Sqlite3 libraries.
* Updated HMGS-IDE to version 1.4.3.5.
* Updated Harbour Compiler 3.2.0dev to a recent Git-version.
(ChangeLog Last Entry: 2019-01-15 12:50)
* Added the new interesting samples and updated some Advanced samples.
A setup of the build 19.01 for Borland C++ 5.5.1 is published at
the following URL:
There are also an extra xHarbour.org-based archive for this build and
Minigui Ex build for the free Embarcadero C++ 10.1 Berlin compiler at
the Minigui's download page.
Thanks for your attention and support!
Best Regards,
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 19.01 is published
As always: Thanks Grigory !
Anand
Post by Anand »
Thank you for new update with the new SWITCHER command :)
Anand
Anand
Thanks Grigory !
Nascimento
Post by Nascimento »
Thanks Grigory !
Nascimento
gfilatov
Post by gfilatov »
I've uploaded the updated setup of the build 19.01 for Borland C++ 5.5.1 at
Whatsnew:
* Enhanced: Added an alternative syntax for the new SWITCHER control
with the default values for 'Height', 'Image', 'Autosize' and
'Vertical Aligning' properties.
Sample code:
DEFINE SWITCHER Label_1
PARENT <FormName>
ROW 150
COL 30
VALUE 'On / Off switcher'
CHECKED .T.
FONTNAME 'Arial'
FONTSIZE 12
ONMOUSEHOVER RC_CURSOR( "MINIGUI_FINGER" )
END SWITCHER
Requested by Sylvain Larche.
Contributed by Grigory Filatov <gfilatov@inbox.ru>
(see demo in folder \samples\Basic\CheckLabel_3)
* Updated: HbZeeGrid library:
- pacified a warning for 64-bit compatibility (was passed
MinGW 8.2.0 64-bit).
(see source in folder \Source\HbZeeGrid).
* Updated: 'TSBrowse Export data to a XLS/XML file' sample:
- added using of the new function HMG_ClrToHTML().
Contributed by Sergej Kiselev
(see Tsb4xml.prg in folder \samples\Advanced\Tsb_Brw2xml)
The upgrade to this build is optional.
Thanks for your attention.
Best Regards,
[MiniGUI Team]
quartz565
Post by quartz565 »
Thank you again Grigory !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Anand
Post by Anand »
Thank you, Grigory.
As you must be aware, we sincerely hope you will take HMG forward too, as and when you get free time, if possible.
The difference is HMG is Unicode.
Anand
Anand
tonton2
Post by tonton2 »
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
