Using 2 DB in SQLITE (ATTACH)
jorge.posadas
Post by jorge.posadas »
Grupo
He visto que se puede usar 2 bases de datos SQLite en una aplicación y es precisamente lo que estoy necesitando, he visto documentación al respecto, pero me gustaría si alguien ya ha hecho eso y si me puede indicar con un ejemplo el CÓMO se puede hacer.
De antemano agradezco la ayuda al respecto.
First of all, I'm sorry 4 my bad English
I need to use two SQLITE DB , are you have a example I meen I have CatalogDB and TransactionDB I need Attach a SQLITE DB and then use it in sentence like next:
Select c.Country_Id, c. Country_Name, t.Distributor_id, d.Distributor_Name
FROM CatalogDB AS C
INNER JOIN TransactionDB AS t on t.Country_Id = c.Country_Id
BUT I don't know how use ATTACH DATABASE and then how use the two database in muy prg
Thks for some LIGHT (luz in spanish)
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
Anand
Re: Using 2 DB in SQLITE (ATTACH)
Post by Anand »
https://stackoverflow.com/questions/569 ... -databases gives an example of similar request. You may try it. I have not used same in HMG but.
Anand
Anand
jorge.posadas
Anand
Thanks but my problem is with SQLITE and using two different databases (SQLITE) and also I do not know how to use ATTACH
But I appreciate your help
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Morelia, Mich.
M é x i c o .
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
I do not know the structure of the database and tables,
Is it possible to put both tables in one base?
I do not use it but in MySQL you can
FROM base1.CatalogDB AS C
INNER JOIN base2.TransactionDB AS t on t.Country_Id = c.Country_Id
Try putting all tables in one base
In this link you can have the Encrypt SQLite source code. I have used Attach Database in that.
http://hmgforum.com/download/file.php?id=2455
