How can I change backcolor of selected node of tree when it's not focused?
Source code related resources
When the tree is not focused, select node/item has grey backcolor. I want it to stay blue or other more contrast.
Is it simple way to do it?
Re: How can I change selected node of tree when it's not focused?
Quizá con...
Maybe with ...
<ParentWindowName>.<TreeControlName>.FullRowSelect := lBoolean
It does not help...
By the way, what FullRowSelect does? There is nothing about it in documentation.
Se supone que te debe de señalar todo el renglón en el que estás,
no solo el texto del nodo.
It's supposed to point you to the whole line you're on,
not just the text of the node.
Aquí hice algo, pero no recuerdo si utilizé el FullRowSelect...
Here I did something, but I do not remember if I used the FullRowSelect ...
http://www.hmgforum.com/viewtopic.php?f=35&t=3886
I've used dynamicbackcolor and it works as I want.
I had to set value to first node abd set focus. After loosing focus last selected node stays coloured as I need.
Thanks Andy!
Re: How can I change backcolor of selected node of tree when it's not focused?
mol wrote: Sun Dec 30, 2018 4:56 pm Did someone realised drag and drop technic within tree control?
http://www.hmgforum.com/viewtopic.php?f ... rop#p53777
