HMG Extended Edition version 18.11 (Update 1)
I've uploaded the updated setup of the build 18.11 for Borland C++ 5.5.1 at
Whatsnew:
* Enhanced: The optimized ON SIZE event detects now the mouse state.
You can use the variable _HMG_MouseState for accepting of
a left mouse button down (=1) or up (=0) state.
Suggested and contributed by Sergej Kiselev.
Revised by Grigory Filatov <gfilatov@inbox.ru>
(see demo in folder \Utils\mgDBU)
* New: Added the Harbour HbCurl contrib library compiled with the latest
Curl and libcurl 32-bit package version 7.62.0 (30 Oct 2018).
Contributed by Grigory Filatov <gfilatov@inbox.ru>
(look at ReadMe.txt in folder \harbour)
* Updated: Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- added the new method OnReSize( nWidth, nHeight, lTop );
- the improved method SetNoHoles().
Contributed by SergKis
(see demo in folder \samples\Advanced\Tsb_Export)
* Updated: MySql library source code (see in folder \Source\HbMySql):
- added the new method affected_rows() in the class TMySQLQuery.
Contributed by Attila Szabo.
* Updated: 'Print Pie Graph' sample: the updated data for November 2018.
(see demo.prg in folder \samples\Basic\GraphPrint)
* Updated: 'Internet Explorer ActiveX' sample:
- updated the events processing routine for proper 64-bit handling.
(see in folder \samples\Advanced\ActiveX)
* Updated: 'HMG_HPDF library usage' sample.
Based upon a contribution of HMG user Edward.
(see demo3.prg in folder \samples\Advanced\PDF_PRINT_3)
The upgrade to this build is optional.
Thanks for your attention.
Merry Christmas and Happy Holidays!
Best Regards,
[MiniGUI Team]
Whatsnew:
Best Regards,
[MiniGUI Team]
Re: HMG Extended Edition version 18.11 (Update 1)
Thanks Grigory and Merry Christmas and Happy Holidays to you and your family!
Dear Serge,serge_girard wrote: ↑Wed Dec 12, 2018 8:19 am Thanks Grigory and Merry Christmas and Happy Holidays to you and your family!
Thanks a lot for your kind words and support
Thanks a lot Grigory for the update.
I was thinking of Edward's HMG_HPDF and thanks to both of you for the same.
Merry Christmas and Happy Holidays.
Anand
Anand
Thank you Grigory!
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
I've uploaded the updated setup of the build 18.11 (Update 2) for Borland C++ 5.5.1 at
Whatsnew:
* Enhanced: Added the events support for ActiveX control.
Syntax:
@ <nRow>,<nCol> ACTIVEX <ControlName> ;
[ OF | PARENT <ParentWindowName> ] ;
WIDTH <nWidth> ;
HEIGHT <nWidth> ;
PROGID <cProgId> ;
[ EVENTMAP <aEvents> ] ;
[ CLIENTEDGE ]
Or
DEFINE ACTIVEX <ControlName>
EVENTMAP { { nEvent, [bAction | cFuncName] }, { ... } }
CLIENTEDGE .T.
END ACTIVEX
Requested by Carlos Vargas <cvargaz[at]donboscocorp.com>.
Based on a contribution of Oscar Lira <oscarlira78@hotmail.com>.
(see demo in folder \samples\Advanced\VLC)
* Modified: A StatusBar with KEYBOARD clause look was improved with using
of an ownerdraw color for the status items.
* Updated: Minor correction of StatusItem refresh at modifying of FontColor,
BackColor and Align properties at runtime.
(see demo4.prg in folder \samples\Basic\Status)
* Updated: 'Internet Explorer ActiveX' sample.
* Updated: 'My Player' sample is based upon the VLC ActiveX Control at
http://www.videolan.org/.
(see in folder \samples\Advanced\VLC)
* Updated: 'MiniGUI DataBase Utility' sample.
(see in folder \Utils\mgDBU)
Best Regards,
[MiniGUI Team]
Whatsnew:
Syntax:
WIDTH <nWidth> ;
HEIGHT <nWidth> ;
PROGID <cProgId> ;
[ CLIENTEDGE ]
Or
CLIENTEDGE .T.
END ACTIVEX
Best Regards,
[MiniGUI Team]
Thx !
Thanks Grigory for the update.
Anand
Anand
