sudip
Post
by sudip »
Hi Friends,
This is one of the simplest and funniest programs I did!
- BmiCalc.jpg (17.96 KiB) Viewed 21847 times
Please download the source code
, compile and run
Some points: Height in Ft and Inch is optional. BMI will be calculated automatically, no need to click on "Calculate" button!!!
Please don't forget to send your comments
and
don't forget to calculate your BMI
With best regards.
Post
by Rathinagiri »
Oh! Thanks Sudip.
I think I am fit.
Post
by Rathinagiri »
You can add Pounds also for entering weight.
Post
by esgici »
Thanks Sudip
Really funny
You may thing validate extreme faulty input values. Such as .185 cm instead of 185. and/or .90 instead of 90. kg.
Viva
INTERNATIONAL HMG
sudip
Post
by sudip »
Hi Esgici, Rathi,
Thanks a lot for your suggestions
BTW, I am taking a break for exercise!
With best regards.
- HMG Founder
Post
by Roberto Lopez »
sudip wrote:Hi Friends,
BMICalc.zip
, compile and run
and
With best regards.
I'm not sure if I want to test it
Roberto.
Post
by mol »
So! less time for HMG, more for excercises!
sudip
Post
by sudip »
Hi Rathi, Esgici,
Here is an update as per your suggestion
Please download, compile, test and send your comments.
And don't forget to spend at least 15 minutes a day for exercise!!!
With best regards.
Post
by Rathinagiri »
Nice.
Thanks Sudip.
apais
Post
by apais »
I got a blue screen with this message: "weight overflow" (G)
Angel Pais
