Ismach
Post
by Ismach »
En el caso de que no funcionara hay que cambiar asi
oRs := TOleAuto():New("adodb.recordset")
// oRs:ActiveConnection(oOra)[b][/b]
// oRs:CursorLocation(3)
// oRs:CursorType := adOpenStatic
// oRs:CursorLocation := adUseClient
// oRs:LockType := adLockOptimistic
oRs:Open(cSQL, oOra)
IF oRs:RecordCount = 0
MsgInfo( "Producto Caja de Seguridad Inexistente", SISTEMA )
fmCajas.txtA0090.Setfocus
Ismach
Post
by Ismach »
obvio que el esta demas
Ismach
Post
by Ismach »
en el caso de que no funcione se ebe cambiar a:
oRs:Open(cSQL, oOra )
aguardo sus comentarios
dragancesu
Post
by dragancesu »
Thank you, I will try
Have you version with OCI?
Ismach
Post
by Ismach »
Nop! I don't use OCI,
I'm using WINOLE via ADODB ( conector nativo de windows )
provider="MSDAORA.1"
Ismach
Post
by Ismach »
more info : "
Microsoft OLE DB Provider for Oracle Overview"
https://docs.microsoft.com/en-us/sql/ad ... erver-2017
Ismach
Post
by Ismach »
Lo que si se necesita es compilar las libs
c:\MiniGUI\SOURCE\HbOLE\
y
c:\MiniGUI\SOURCE\AdoRDD\
dragancesu
Post
by dragancesu »
I was try and work
Litlle problem is how solver NULL values from table
This is for MiniGUI !!! not for HMG
- orademo.zip
- (1.95 KiB) Downloaded 295 times
luisvasquezcl
Post
by luisvasquezcl »
Estimados,
Como aporte al demo de dragancesu, para cargar datos más rápido que recorrer un bucle pueden hacerlo de la siguiente forma:
Dear,
As a contribution to the demo of dragancesu, to load data faster than going through a loop can do it in the following way:
oRs := Openrecordset(oConexion, "Select * from customer")
aDatos := {}
if oRs:RecordCount > 0
aDatos := oRs:getRows()
oRs:close()
Luis Vasquez
dragancesu
Post
by dragancesu »
Hello luisvasquezcl,
can you send all program
I was try your way, but not work
