Harbour MiniGUI Extended Edition build 18.10 is published
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
It is a regularly scheduled maintenance and bugfix release.
Here's a breakdown of some of the modifications in the build 18.10.
For the full list, please see the changelog.
* Fixed a problem with a translating of the SetFocus and others methods
for 'This' object reference (introduced in the build 16.08).
* Fixed a wrong row position of a WHOLEDROPDOWN menu of a ToolButton
which was placed into a HORIZONTAL SplitBox control.
* Fixed a missed TabPage's hotkeys management in the functions
_AddTabPage() and _DeleteTabPage() in a TAB control.
It exists in the official version too.
* Fixed problem with a ToolButton's hotkey assigning after
a changing of the ToolButton 'Caption' property at runtime.
* Added the set/get 'Visible' property for the forms:
ThisWindow|<FormName>.Visible [ := | --> ] lBoolean
* The new Harbour function __mvGetDef() was used instead of the
combination of the __mvExist()/__mvGet() in the MiniGUI core.
Note: The compatibility with xHarbour compiler and Harbour
version 3.4 is provided.
* New: Draw GRAPH in Bitmap is based upon the BosTaurus library.
Added the new command GRAPH BITMAP for PIE|BARS|LINES|POINTS
graph (synchronized with Official HMG).
Note: An algorithm of 'Graph Bitmap' was updated for compatibility
with a graphic module in the MiniGUI core.
* Updated and improved the TSBrowse library.
* Added the new interesting samples and updated some Basic and
Advanced samples.
A setup of the build 18.10 for Borland C++ 5.5.1 is published at
the following URL:
There are also an extra xHarbour.org-based archive for this build and
Minigui Ex build for the free Embarcadero C++ 10.1 Berlin compiler at
the Minigui's download page.
Thanks for your attention and support!
Best Regards,
[MiniGUI Team]
Advanced samples.
the following URL:
Best Regards,
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 18.10 is published
Many thanks, Grigory !
- luisvasquezcl
Thanks Grigory
Best regards
Best regards
Many thanks, Filatov
Thanks a lot for the new version.
Anand
Anand
- srvet_claudio
Nice work!
Thanks for the info:
gfilatov wrote: ↑Tue Oct 30, 2018 7:58 pm * Fixed a missed TabPage's hotkeys management in the functions
Thanks Grigory!
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
Hi Friends,
I've uploaded the updated setup of the build 18.10 for Borland C++ 5.5.1 at
Whatsnew:
* Fixed: Program crash at releasing of a Tab control with imbedded Slider
(introduced in the build 18.10).
Bug was reported by Richard Rylko.
Contributed by Grigory Filatov <gfilatov@inbox.ru>
* Fixed: Problem with assigning of the 'Caption' property in the ButtonEx
control (introduced in the build 18.10).
Bug was reported by Grzegorz Wojnarowski.
* Modified: The function HMG_Alert() respects now the Minigui command
SET CENTERWINDOW RELATIVE PARENT.
* Updated: Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- improved the method GotoRec( nRec [, lLastPos | nRowPos ] )
in the TSBrowse class.
The second parameter may have a logical value for the cursor
setting into a last position on a screen.
Contributed by Sergej Kiselev
(see demo in folder \samples\Advanced\Tsb_addrecord)
Thanks for your attention!
Best Regards,
[MiniGUI Team]
Whatsnew:
Best Regards,
[MiniGUI Team]
