Directorio y descarga mediante SFTP
edufloriv
Post by edufloriv »
Saludos amigos,
¿ Alguien tiene código fuente para obtener el directorio y descargar archivos mediante SFTP usando key (SSH) ? Ya puedo subir archivos, pero he buscado en la red y no encuentro los comandos para obtener el directorio y descargar.
Agradeceré su ayuda por favor. Mil gracias anticipadas.
Greetings, friends
Does anyone have source code to get the directory and download files using SFTP using key (SSH)? I can upload files, but I searched the network and can not find the commands to obtain the directory and download.
I will appreciate your help please. Many thanks in advance.
Att.
Eduardo Flores Rivas
LIMA - PERU
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: Directorio y descarga mediante SFTP
Post by dragancesu »
Windows has a built-in ftp client that is not for serious use
In applications that need to send / receive data via ftp companies we use the program ncftp as an external solution, it is not perfect, but it has everything
there are several programs, one is ncftpls that serves to output the contents of a folder, then it is easy to redirect it to a file, this is our solution
Try
https://www.ncftp.com/ncftp/
or
https://winscp.net/eng/docs/commandline
edufloriv
Post by edufloriv »
Thank you very much, I will try both, thanks for your answer.
Muchas gracias, probaré ambos, gracias por tu respuesta.
Att.
LIMA - PERU
edk
Post by edk »
edufloriv wrote: Thu Oct 11, 2018 5:52 pm Greetings, friends
Hola Eduardo Flores.
Check out this sample simple application to navigate on an SFTP server.
It only supports basic functions:
- listing of folders / files of local disks and a remote host
- navigating local and remote folders
- copying files (one at a time) from a local disk to a remote folder (upload)
- copying files (one at a time) from a remote folder to a local drive (download)
- renaming files / folders on local disks and on a remote host
- creating folders on local disks and on a remote host
- deleting files and folders from local drives and from a remote host
I tested with a local SFTP server (Bitvise SSH Server 7.46) and with a demo public sftp server: sftp://demo.wftpserver.com/
Authorization with a username and password. I can not authorize using a Public / Private key pair (maybe I have generated it incorrectly or I can not configure it properly, I have no experience with this).
Cheers.
SFTP_Navigator.7z
(1.23 MiB) Downloaded 542 times
edk
Post by edk »
Small improvements:
- when changing the folder to the parent, the active row is set to the name of the folder that you left.
- when adding a new folder, the active row is set on the created folder
- when deleting a file or folder, the active row remains in the nearest position of the deleted item.
- go to the parent folder with the BACKSPACE key.
sftp.7z
(6.63 KiB) Downloaded 373 times
vientopamperosur
DBs Used: DBF, SQLite, MySQL, MariaDB, PostgreSQL
Post by vientopamperosur »
Buenas compañeros, estoy interesado en probar este ejemplo, pero no puedo compilarlo para estudiarlo, me falta hbcurl.ch, Donde puedo conseguir este archivo?
edk
Post by edk »
To properly compile you should have the HMG 3.4.4 version installed
Then, from this package: http://hmgforum.com/download/file.php?id=8685 copy all files from the "lib" folder to "c:\hmg.3.4.4\HARBOUR\lib\win\mingw"
You compile by running "build_SFTP.bat" (we compile sftp.hbp not sftp.prg)
The hbcurl.ch file should be in "c:\hmg.3.4.4\HARBOUR\contrib\hbcurl\"
PeteWG
Post by PeteWG »
edk wrote: Fri Oct 26, 2018 9:34 am Small improvements:
sftp.7z
excellent sample! 8-)
thanks for sharing
regards,
Pete
vientopamperosur
Muchas gracias, voy a probarlo!
vientopamperosur
Buen día. Sigo teniendo problemas...
C:/Users/ale/AppData/Local/Temp/hbmk_zigy1s.dir/sftp.o:sftp.c:(.data+0x3d8): undefined reference to `HB_FUN_CURL_EASY_INIT'
C:/Users/ale/AppData/Local/Temp/hbmk_zigy1s.dir/sftp.o:sftp.c:(.data+0x3f8): undefined reference to `HB_FUN_CURL_EASY_RESET'
C:/Users/ale/AppData/Local/Temp/hbmk_zigy1s.dir/sftp.o:sftp.c:(.data+0x418): undefined reference to `HB_FUN_CURL_EASY_PERFORM'
C:/Users/ale/AppData/Local/Temp/hbmk_zigy1s.dir/sftp.o:sftp.c:(.data+0x438): undefined reference to `HB_FUN_CURL_EASY_STRERROR'
C:/Users/ale/AppData/Local/Temp/hbmk_zigy1s.dir/sftp.o:sftp.c:(.data+0x488): undefined reference to `HB_FUN_CURL_GLOBAL_CLEANUP'
C:/Users/ale/AppData/Local/Temp/hbmk_zigy1s.dir/sftp.o:sftp.c:(.data+0x498): undefined reference to `HB_FUN_CURL_EASY_ESCAPE'
C:/Users/ale/AppData/Local/Temp/hbmk_zigy1s.dir/sftp.o:sftp.c:(.data+0x4a8): undefined reference to `HB_FUN_CURL_EASY_SETOPT'
hbmk2[sftp]: Error: Ejecutando enlazador. 1
gcc.exe C:/Users/ale/AppData/Local/Temp/hbmk_zigy1s.dir/sftp.o C:/Users/ale/AppData/Local/Temp/hbmk_zigy1s.dir/hbmk_3nzs0n.o C:/HMGSQL/Ejemplos/sftp/SFTP_Navigator/_temp.o -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbmysql -lmysql -lhbfimage -lhbpgsql -lsddmy -lhbvpdf -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -o"SFTP Navigator.exe" -Lc:/hmg.3.4.4/harbour/lib/win/mingw -Lc:/hmg.3.4.4/lib
hbmk2: Sugerencia: A¤ade la opci¢n 'hbcurl.hbc' para las funciones que faltan:
curl_easy_setopt(), curl_easy_escape(), curl_global_cleanup(),
curl_easy_strerror(), curl_easy_perform(), curl_easy_reset(),
curl_easy_init()
he hecho todo lo indicado y me aparece este texto en build.log. Que estoy haciendo mal???
