i need to test if status bar is defined.
Do anybody know how to do it?
How to test if StatusBar is defined in current window?
Re: How to test if StatusBar is defined in current window?
Hi,mol wrote:i need to test if status bar is defined.
Please be so kind to try the following working sample:
#include "minigui.ch"
SET DATE GERMAN
WIDTH 640 ;
HEIGHT 400 ;
TITLE 'Statusbar Keyboard Demo' ;
DEFINE STATUSBAR FONT 'Arial' SIZE 9
STATUSITEM "Statusbar Demo"
KEYBOARD
DATE
CLOCK
END STATUSBAR
msginfo( Iif(IsControldefined( Statusbar, Form_1 ), "TRUE", "FALSE") )
CENTER WINDOW Form_1
I've tried to go this way earlier, but I always got information that statusbar is not defined.
So, Grigori, your sample doesn't work
Hi Marek,mol wrote:I've tried to go this way earlier, but I always got information that statusbar is not defined.
Sorry but try an aboved sample
It works fine with HMG 3.0 Test VI:
- modified sample demo3.prg at your folder hmg\samples\statusbar;
- compiled by command build.bat demo3
- look for message "TRUE"
I must excuse you!
It works!
I've tried
but a trick relys on cWindowName - it was variable containing name of window
I've changed in my program for:
and it starts to work!
Many thanks, Grigori
It works!
I've tried
IsControlDefined (cWindowName, "StatusBar")
IsControlDefined (&cWindowName, StatusBar)
