HMG-IDE 3.0.0 (Forum test VI)
- Roberto Lopez
- HMG Founder
Here is ide 3.0.0 forum test VI.
It requires HMG 3.0.0 forum test VI.
The only change is that it is compatible with HMG 3
IDE_30_TEST_06_A.RAR (INCLUDE BUILD.BAT PATCH)
Enjoy!
Enjoy!
Re: HMG-IDE 3.0.0 (Forum test VI)
WOW
Thank once again master.
with best regards,
with best regards,
Hello Master,
Sorry, but i dont be able for compile my project using this version of HMG-IDE.
When i click on compile button, show me a window "building" and it is closed. And my resource file not opened in this IDE.
Where i miss?
with best regards,
Where i miss?
with best regards,
I am sure it is 'Diwali' gift.
I've tried to recompile my project with version 3.0 (hmg & ide).
I've reset incremental data, deleted manually all *.o files, but compiler didn't start.
I can see "BUILD" window for a while and nothing else happens.
What's going on?
Marek
What's going on?
Marek
Maestro te lo estás currando (expresión andaluza que quiere decir "trabajando" y que le da más dramatismo).
Es una maravilla lo que está haciendo.
Rafael Pérez
Rafael Pérez
- Roberto Lopez
- HMG Founder
I've forgot something....mol wrote:I've tried to recompile my project with version 3.0 (hmg & ide).
What's going on?
Marek
Please, replace \hmg\batch\build.bat with the following and re-test:
@echo off
rem ***************************************************************************
rem HMG 3.0 Build batch
rem Roberto Lopez (2009.10.16)
rem Syntax:
rem
rem Build [/i|/r|/d|/cs|/ci/cr] <PrgFile> | <filelist.hbp> [config.hbc]
rem
rem [/i] : incremental build
rem [/r] : incremental build (rebuild all)
rem
rem [/cs] : Console/mixed mode (std build)
rem [/ci] : Console/mixed mode (incremental build)
rem [/cr] : Console/mixed mode (incremental rebuild all)
rem
rem [/d] : Debug mode (gui and console)
rem
rem
rem <filelist.hbm> : A text file with .hbp extension containing a source list
rem <configfile.hbc>: A text file with configuration parameters as additional
rem libs, include paths and lib paths.
rem
rem <configfile.hbc> Syntax:
rem
rem incpaths = incpath1 incpath2 ... incpathn
rem
rem libpaths = libpath1 libpath2 ... libpathn
rem
rem libs = lib1 lib2 ... libn
rem
rem - library names must not include 'lib' prefix nor '.a' extension.
rem
rem - build.bat will create an 'error.log' file in the app folder when build
rem process ends with an error condition.
rem
rem
cls
echo building...
if exist hbmk.log del hbmk.log
if exist hbmk.so.log del hbmk.so.log
if exist windres.log del windres.log
if exist error.log del error.log
rem Set variables
Set Path=c:\hmg\util;c:\hmg\mingw\bin;c:\hmg\harbour\bin;%PATH%
if "%Resources%"=="" Set Resources=c:\hmg\resources\minigui.o
if "%HmgPath%" =="" Set HmgPath=c:\hmg
set GT=-gtgui
set DEBUG=""
set BUILDTYPE=""
set REBUILDALL=""
set RUN=.T.
rem ---------------------------------------------------------------------------
rem Parameters Processing
rem No run after build
if "%1"=="/n" goto norun
if "%1"=="/N" goto norun
:continue0
rem Console Incremental Rebuild
if "%1"=="/cr" goto consoleincrebuild
if "%1"=="/CR" goto consoleincrebuild
if "%1"=="/ci" goto consoleincremental
if "%1"=="/CI" goto consoleincremental
rem GUI Incremental Rebuild
if "%1"=="/r" goto increbuild
if "%1"=="/R" goto increbuild
rem Console Standard Build
if "%1"=="/cs" goto console
if "%1"=="/CS" goto console
rem If debug mode specified, use GTWIN and pass -b parameter
if "%1"=="/d" goto debug
if "%1"=="/D" goto debug
rem If /i parameter rceived set BUILDTYPE to incremental
if "%1"=="/i" goto incremental
if "%1"=="/I" goto incremental
:continue
if exist %~n1.exe del %~n1.exe
if exist %~n1.exe goto error
rem If a resource with the same base name as the first parameter exist compile it
if exist %~n1.rc copy /b %HmgPath%\resources\minigui.rc+%~n1.rc+%HmgPath%\resources\filler _temp.rc >NUL
if exist %~n1.rc redir -e windres.log windres -i _temp.rc -o _temp.o
if exist %~n1.rc Set Resources=_temp.o
rem invoke HBMK2
redir -eo hbmk2 -nohbc -o%~n1.exe %GT% %DEBUG% -head=real %BUILDTYPE% %REBUILDALL% -incpath=%HmgPath%\include -incpath=%CD% -L%HmgPath%\lib -lminigui -lhbmysql -lmysql -lcrypt -ledit -leditex -lgraph -lini -lreport -lhbwin -lhbziparc -lhbmzip -lmsvfw32 -lvfw32 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbvpdf -lhbmemio -lhbsqlit3 -lsqlite3 -lhbfimage.a -lhbpgsql -lpq -prgflag=/q %1 %2 %3 %4 %5 %6 %7 %8 %9 %Resources% >hbmk.log
goto end
rem Procedure increbuild
:increbuild
set BUILDTYPE=-inc
set REBUILDALL=-rebuild
shift
goto continue
rem Procedure Console
:console
set GT=-gtwin
shift
goto continue
rem Procedure Debug
:debug
set GT=-gtwin
set DEBUG=-b
echo Options NoRunAtStartup > Init.cld
shift
goto continue
rem Procedure Incremental
:Incremental
set BUILDTYPE=-inc
shift
goto continue
rem Procedure IncConsole
:consoleincremental
set BUILDTYPE=-inc
set GT=-gtwin
shift
goto continue
:consoleincrebuild
set BUILDTYPE=-inc
set GT=-gtwin
shift
goto continue
rem Procedure NoRun
:norun
set RUN=.F.
shift
goto continue0
rem Procedure Error
:error
echo Can't delete previous %~n1.exe version (still running?) > error.log
goto showlog
:end
rem Cleanup
rem If build error, create 'error.log' ----------------------------------------
if errorlevel 1 if exist windres.log copy /b windres.log+hbmk.log error.log >nul
if errorlevel 1 if not exist windres.log copy /b hbmk.log error.log >nul
rem If no error run the exe ---------------------------------------------------
if "%RUN%"==".T." if not errorlevel 1 if exist %~n1.exe %~n1.exe
rem Delete temporary files ----------------------------------------------------
if exist _temp.rc del _temp.rc
if exist _temp.o del _temp.o
rem if exist delete debugger file ---------------------------------------------
if exist init.cld del init.cld
:showlog
if exist error.log type error.log
Roberto.
- Roberto Lopez
- HMG Founder
Please, replace build.bat with the one included in the previous message and re-test.Vanguarda wrote:Hello Master,
Where i miss?
with best regards,
Roberto.
- Roberto Lopez
- HMG Founder
Apparently, resource compiler in MingW 4 is working different.Vanguarda wrote:Hello Master,
Where i miss?
with best regards,
Some resource names are not accepted now, ie: BUTTON resource from resource demo causes an error.
Roberto.
