Pregunta técnica
jorge.posadas
Pregunta técnica
Post by jorge.posadas »
Grupo
¿Qué es mejor usar?
1- IF .NOT. MyFunction()
o esta
2. IF !MyFunction
es decir es mejor usar .NOT. o !
De antemano agraezco el comentario, y la pregunta surge porque en SQL cuando se valora una variable es mejor usar IF LEN(cvariable) = 0 a usar IF(cVariable) = '''
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
Re: Pregunta técnica
There is a problem with such a construction for testing empty string:
IF(cVariable) = ''
In my opinion, it should look like this:
IF cVariable = ''
but, this statement always return .t.
It's better to use
if len(cVariable) == 0
or
if !(cVariable=="")
Anand
Post by Anand »
Agree with Mol.
better use 'If Empty(cVariable)' code to check if a variable is empty.
Using '=' is a mistake as the logic of it is to stop checking after reaching end of 'right side' text.
So, 'abcd' = 'ab' is true
but 'abcd' == 'ab' is false
So 'abcd' = '' will be always true
but 'abcd' == '' will be false.
Anand
Anand
EMPTY function can be problematic in some cases, too.
If your string consists only from space characters (chr(32)), this function return .T.
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
The main thing is to write a function
1. if you are using: IF myfunc()
then the function should be written to return TRUE or FALSE,
It's better for me because it's solved in one place
2. if you are using: _variable = myfunc()
then
IF _variable ...
see http://www.oohg.org/cl53/ng11d14f.html
