How to adopt function DeleteUrlCacheEntry in HMG
That removes the file associated with the source name from the cache, if the file exists.
Syntax C++:
BOOLAPI DeleteUrlCacheEntry(
_In_ LPCTSTR lpszUrlName
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
Re: How to adopt function DeleteUrlCacheEntry in HMG
For example, in this way:
MEMVAR _HMG_SYSDATA
FUNCTION Main()
LOCAL cURL := "http://myURL"
LOCAL nError
IF DeleteUrlCacheEntry(cURL, @nError)
MsgBox("Deleted!")
//System Error Codes: https://msdn.microsoft.com/en-us/library/windows/desktop/ms681381(v=vs.85).aspx
MsgBox("Error code: " + HB_NtoS(nError))
#pragma BEGINDUMP
#include <windows.h>
#include <Wininet.h>
#include "hbapi.h"
#include "HMG_UNICODE.h"
// DeleteUrlCacheEntry(cURL[, @nError])
HB_FUNC( DELETEURLCACHEENTRY )
BOOL bRetVal = DeleteUrlCacheEntry((LPCTSTR) HMG_parc(1));
DWORD nError = GetLastError();
if (HB_ISBYREF(2))
hb_stornl(nError, 2);
hb_retl(bRetVal);
#pragma ENDDUMP
- srvet_claudio
A comment:
these header files should always go first
#include "SET_COMPILE_HMG_UNICODE.ch" #include "HMG_UNICODE.h"
because they activate / deactivate compilation in Unicode in the other header files
Thank you Krzysztof
Thank you Dr. Claudio
