Date-Type textbox problem
ROBROS
Post by ROBROS »
Hi friends,
I played around with a date-type textbox and need help. See the code:
set century on
set date to german
set date format to "DD.MM.YYYY"
FUNCTION Main()
local cDat, cDatum
 DEFINE WINDOW Date_1 ;
 AT 120,120 ;
 WIDTH 400 ;
 HEIGHT 150 ;
 TITLE "Textbox Date" ;
 On Key F10 of date_1 action showdat()
 @ 50,50 LABEL datum ;
 PARENT Date_1 ;
 VALUE "Datum" ;
 @ 50,160 TEXTBOX date ;
   PARENT Date_1 ;
   WIDTH 120 ;
   HEIGHT 30 ;
   date
   inputmask "99.99.9999"
   VALUE Date()
 ACTIVATE WINDOW Date_1
 function showdat
 cDat:=dtoc(Date_1.date.value)
 cDatum:=right(cDat,4)+substr(cDat,4,2)+left(cDat,2)
 MsgInfo(cDat)
 MsgInfo(cDatum)
return
It seems inputmask does not work with date-textbox, and the date format setting is ignored too.
Btw: Why do I not get a syntax error because of the semicolon at value of label datum and why do I get a syntax error at the date statement in textbox?
Thank you for your help
Robert
PS: How can I append a screenshot to show you the result of my code?
ROBROS
Re: Date-Type textbox problem
Post by ROBROS »
As you can see from the attached screen shot, the typed in date is not validated, but the MsgInfo shows nothing (blank).
The sequence of the attached files is wrong. Sorry for that.
Hello Friend ROBROS :
write with this order and it works
FUNCTION Main()
local cDat, cDatum
set century on
set date to german
 AT 120,120 ;
 WIDTH 400 ;
 HEIGHT 150 ;
 PARENT Date_1 ;
 VALUE "Datum" ;
   PARENT Date_1 ;
   WIDTH 120 ;
   HEIGHT 30 ;
   VALUE dtoc( Date() ) ;
 function showdat
  cDat:= (Date_1.date.value)    //dtoc(Date_1.date.value)
 MsgInfo(cDat)
 MsgInfo(cDatum)
return
edk
Post by edk »
ROBROS wrote: Thu May 10, 2018 11:57 am Hi friends,
set century on
set date to german
FUNCTION Main()
local cDat, cDatum
 AT 120,120 ;
 WIDTH 400 ;
 HEIGHT 150 ;
 PARENT Date_1 ;
 VALUE "Datum" ;
   PARENT Date_1 ;
   WIDTH 120 ;
   HEIGHT 30 ;
   date
   VALUE Date()
 function showdat
 MsgInfo(cDat)
 MsgInfo(cDatum)
return
Robert
Wrong syntax of TextBox. When you define a TextBox with the DATE option, you can not use INPUTMASK.
Also, you must set century and date format locate in to FUNCTION Main(), not before.
FUNCTION Main()
local cDat, cDatum
set century on
set date to german
 AT 120,120 ;
 WIDTH 400 ;
 HEIGHT 150 ;
 PARENT Date_1 ;
 VALUE "Datum" ;
   PARENT Date_1 ;
   WIDTH 120 ;
   HEIGHT 30 ;
   VALUE Date();
   DATE
 function showdat
 MsgInfo(cDat)
 MsgInfo(cDatum)
return
ROBROS
Post by ROBROS »
Hi friend Mustafa,
I compiled and of course it works, thank you, but I have not yet found the difference to my code.;)
Anyway: Thank you
Robert
your code with arrangement
FUNCTION Main()
local cDat, cDatum
set century on
set date to german
 AT 120,120 ;
 WIDTH 400 ;
 HEIGHT 150 ;
 PARENT Date_1 ;
 VALUE "Datum" ;
   PARENT Date_1 ;
   WIDTH 120 ;
   HEIGHT 30 ;
   date
   VALUE Date()
 function showdat
 MsgInfo(cDat)
 MsgInfo(cDatum)
return
*------------------ Your code -------------------*
set century on
set date to german
FUNCTION Main()
local cDat, cDatum
*----------------- My code ------------------------*
FUNCTION Main()
local cDat, cDatum
set century on
set date to german
ROBROS
Post by ROBROS »
One of my replies got lost on the way to the board,
I always looked for the error inside the main function.
@ edk: Thank you.
@ Mustafa: edk's reply showed me the difference.
Thx again.
Robert
ROBROS
Post by ROBROS »
This post should be removed, the following post is identical, the only difference is, that bbcode is ok. :lol:
Hi friends,
still playing around with dates, once again I found a strange behaviour (at least in my opinion) of the compiler: I use IDE "RUN" to compile. It has to do with the semicolon, telling the compiler, that the following line is not a new line, but the previous one is continued.
How do I know, if a new line in source code is requested? Please see attached source code.
[code)#include "hmg.ch"
FUNCTION Main()
local cDat, cDatum
cName:=GetComputerName()
set language to german
set century on
set date to german
set navigation extended
//MsgInfo('Computer-Name: '+ cName)
AT 120,120 ;
WIDTH 600 ;
HEIGHT 400 ;
FONT 'ARIAL' Size 14 ;
TITLE "Wochentag eines Datums" ;
//Why no semicolons necessary in the followin labels?
DEFINE LABEL datum_0
PARENT Date_1
ROW 40
COL 10
width 300
height 50
FONTNAME 'ARIAL'
FONTSIZE 12
autosize .T.
VALUE "Find out the CDOW() of a date"
END LABEL
DEFINE LABEL datum
PARENT Date_1
ROW 150
COL 10
width 300
height 50
FONTNAME 'ARIAL'
FONTSIZE 12
autosize .T.
VALUE "Enter date,go on with RETURN or F-10"
END LABEL
@ 200,10 TEXTBOX date ;
PARENT Date_1 ;
WIDTH 120 ;
HEIGHT 30 ;
Font 'ARIAL' SIZE 14 ;
value nil ;
date ;
On Enter showdat()
DEFINE BUTTON showdat
PARENT date_1
ROW 200
COL 140
CAPTION 'F-10'
ONCLICK showdat()
Fontname 'ARIAL'
FontSize 14
WIDTH 60
HEIGHT 30
END BUTTON
//CDOW() is shown in German. :-)
function showdat
cDat:=dtos(Date_1.date.value)
cDatum:=dtoc(Date_1.date.value)
if empty(cDat)
MsgInfo('No valid date')
// MsgInfo(cDat)
// MsgInfo(cDatum)
MsgInfo(cDatum+' = '+cdow(Date_1.date.value))
Date_1.release
return [/code]
Maybe someone can explain that to me (retiring in 2 weeks) but working on with hmg to keep my brains alive.
Robert
ROBROS
Post by ROBROS »
Hi friends,
FUNCTION Main()
local cDat, cDatum
set century on
set date to german
  AT 120,120 ;
  WIDTH 600 ;
  HEIGHT 400 ;
//Why no semicolons necessary in the following labels?
  PARENT Date_1
  ROW 40
  COL 10
  width 300
  height 50
  FONTNAME 'ARIAL'
  FONTSIZE 12
  autosize .T.
 END LABEL
 DEFINE LABEL datum
  PARENT Date_1
  ROW 150
  COL 10
  width 300
  height 50
  FONTNAME 'ARIAL'
  FONTSIZE 12
  autosize .T.
 END LABEL
   PARENT Date_1 ;
   WIDTH 120 ;
   HEIGHT 30 ;
   value nil ;
   date  ;
   On Enter showdat()
            PARENT date_1
            ROW 200
            COL 140
            CAPTION 'F-10'
            ONCLICK showdat()
			Fontname 'ARIAL'
			FontSize 14
            WIDTH 60
            HEIGHT 30
      END BUTTON
 function showdat
 if empty(cDat)
//	MsgInfo(cDat)
//	MsgInfo(cDatum)
 Date_1.release
return
Robert
How can I remove the previous post, bbcode was wrong.
