Trap error with Begin Sequence
hmgchang
Post by hmgchang »
Dear Friends,
I need help on the error trapping,
This works with no errors
error is not trapped
the code,
20180504_hmbk2find.zip
(7.79 KiB) Downloaded 329 times
TIA
best rgds,
Chang
Just Hmg It !
KDJ
Re: Trap error with Begin Sequence
Post by KDJ »
Chang
Missing BREAK in SEQUENCE. Try this:
FUNCTION Main_List_1_OnChange()
  LOCAL bErrHandler
  LOCAL uResult
  LOCAL cEditValue
  LOCAL nValue := GetProperty( "Main", "List_1", "Value")
  LOCAL cDisplayItem := ALLTRIM( GetProperty( "Main", "List_1", "Item", nValue))
  // cDisplayItem := "getStartupFolder()"
  LOCAL cCode := "{|x| " + cDisplayItem + "}"
  bErrHandler := ErrorBlock({|| Break(NIL)})
  BEGIN SEQUENCE
    bCode := &cCode
    uResult := EVAL( bCode)
  RECOVER
    msgDebug( "undefined function :", cCode)
  END
  ErrorBlock(bErrHandler)
  IF VALTYPE( uResult) == 'C'
    cEditValue := uResult + HB_EOL() + GetProperty( "Main", "Edit_1", "Value")
    SetProperty( "Main", "Edit_1", "Value", cEditValue)
    msgDebug( cDisplayItem, uResult)
    msgDebug( uResult)
hmgchang
Post by hmgchang »
Thank you KDJ...
It works
:D
Next question :
Why is hb_dskspacd() not recognise as a build in function while hb_eol() works ?
Best rgds
chang
Just Hmg It !
KDJ
Post by KDJ »
hmgchang wrote: Sun May 06, 2018 6:25 am Why is hb_dskspacd() not recognise as a build in function while hb_eol() works ?
Because HB_EOL() function is used in HMG code and HB_DiskSpace() function is nowhere used.
You need use REQUEST statement for this function, eg:
#define ZFMAIN Main
#define ZMFILE "&File"
#define ZMFILE01 "&Open"
#define ZSTTBAR01 "hfManager"
REQUEST HB_DiskSpace
REQUEST HB_BuildDate
FUNCTION Main()
hmgchang
Post by hmgchang »
Thanks Sir,
in my case, should I REQUEST all available functions at the beginning of the program ?
or can I do the REQUEST at runtime ( when the function name is clicked/List onChange) ?
TIA
best rgds
Chang
Just Hmg It !
KDJ
Post by KDJ »
hmgchang wrote: Sun May 06, 2018 9:40 pm in my case, should I REQUEST all available functions at the beginning of the program ?
Yes, all that will be called by the macro and are not explicitly used in the program code.
hmgchang wrote: Sun May 06, 2018 9:40 pm or can I do the REQUEST at runtime ( when the function name is clicked/List onChange) ?
No. REQUEST is an instruction for the linker.
Read here: http://www.itlnet.net/programming/progr ... 0da82.html
hmgchang
Post by hmgchang »
Thank you very much Sir,
:D
Just Hmg It !
