Mysterious counting of the INT() function
edk
Post by edk »
To all.
Do you also get the number 5 instead of the expected 6 as a result of
msgdebug( INT( ( 129.6 - 129 ) * 10 ) )
:?: :!: :shock:
Edward.
apais
Re: Mysterious counting of the INT() function
Post by apais »
floating point issues !
Angel Pais
Yes, me too...
SALINETAS24
Post by SALINETAS24 »
msgdebug( INT( VAL(STR(( 129.6 - 129 ) * 10 ) )))
Raro, raro .., raro
Anand
Post by Anand »
We are using str() with default values of decimal points and again val() to convert it, so problem can come up at random times. I am not sure when and why, but have faced such situation in Clipper and Xbase++ many times.
If it can be avoided then use int((129.6-129)*10), else use round(x,n) to keep the decimals at known places.
Anand
Anand
edk
Post by edk »
As Angel points out
apais wrote: Tue Apr 10, 2018 1:31 pm floating point issues !
this is a problem with the binary format of floating point numbers: https://harbour.github.io/the-oasis/clipper-5.html
Using integers in the calculations performed, solves the problem.
msgdebug( INT( ( 129.6 - 129 ) * 10 ) )   vs.   msgdebug( INT(  129.6*10 - 129*10 ) )
