Two PDF Printers
nekbmm
DBs Used: DBF,SQLite
Two PDF Printers
Post by nekbmm »
I need two PDF printers with different page layouts A4 and A3, portrait and landscape.
Is it possible ?
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: Two PDF Printers
Post by dragancesu »
Why not? In report program I use
   mPrinter := GetPrinter()
   IF Empty ( mPrinter )
      MsgExclamation( "Printer not selected" )
      dbcloseall()
   SELECT PRINTER mPrinter ;
      ORIENTATION PRINTER_ORIENT_PORTRAIT ;
      PAPERSIZE PRINTER_PAPER_A4 ;
      PREVIEW
   START PRINTDOC NAME "report"
GetPrinter() replace with "YourPrinterName", it's still easy
nekbmm
Post by nekbmm »
Štampam M4 obrazac u PDF. Može li direktno u registry da se menja format,( A4 portrait - A3 landscape i obratno).
Problem je što je vrednost PDF default štampača u reg_binary formatu !
Pozdrav NEX.
dragancesu
Ne koristim direktno kreiranje PDF jer ne stampa dobro nasa slova
Stampac je jedan, velicina stane A4/A3 i orjentacija portret/landscape se definise, a pdf stampac ce to da prihvati,
to ne bi trebalo da bude problem
Tako da, samo si nepotrebno komplikovao
nekbmm
Post by nekbmm »
Štampao sam iz xbase++, problem rešen.
Hvala dragancesu.
