HMG 3.4.4
Re: HMG 3.4.4
Hola Nikko, bienvenido al foro
Una pregunta, ejecutaste "c:\hmg_344\Build.bat pagodil.prg"
o solo "c:\hmg_344\hbmk2 pagodil.prg"
Hello Nikko, welcome to the forum
One question, you ran "c:\hmg_344\Build.bat pagodil.prg"
or just "c:\hmg_344\hbmk2 pagodil.prg"
Re: HMG 3.4.4
Hi Guys!
I'm trying to add RichEditBox control to the Tab.
It causes IDE error:
Error BASE/1081 Argument error: +
Called from GENCODE(28201)
Called from SAVE(26902)
Called from (b)NEW(2164)
Called from _DOWINDOWEVENTPROCEDURE(6091)
Called from EVENTS(3523)
Called from DOMESSAGELOOP(0)
Called from DOMETHOD(9003)
Called from _OPEN(26326)
Called from EDITFILE(30306)
Called from (b)MAIN(1077)
Called from EVENTS(2015)
Called from HMGMAKE(39542)
Called from BUILDPROJECTM(36907)
Called from RUNAPPLICATION(31697)
Called from (b)NEWBUILD(39615)
Called from EVENTS(828)
Called from (b)SHOWLOG(43070)
Called from SHOWLOG(43239)
Called from NEWBUILD(39637)
Called from (b)HMGMAKE(39528)
Called from _PROCESSINITPROCEDURE(5876)
Called from _ACTIVATEWINDOW(5691)
Called from (b)MAIN(623)
Called from MAIN(1253)
edk
Re: HMG 3.4.4
Post by edk »
Sorry Marek, but I can not reproduce this issue :? .
Bez tytułu.png (98.36 KiB) Viewed 40439 times
Re: HMG 3.4.4
Try to add richeditbox on second tab
PS. I'm using ANSI version of IDE
edk
Re: HMG 3.4.4
Post by edk »
On second tab is also OK, but... if I load the form to IDE-ANSI, all RichEditBoxes disappears!
While saving the form occurs errors as you report.
Re: HMG 3.4.4
When I add RichEditBox to second Tab, it disappears - it looks like RichEditBox is placed under the Tab.
When I try to save form - error occurs.
koke
DBs Used: DBF, mySql, mariaDB
Re: HMG 3.4.4
Post by koke »
Hola mol
Estoy trabajando en un programa con RICHEDITBOX y no puedo hacer que funcione, lo e compilado con varias versiones y no sé qué está pasando, no me marca ningún error al compilar pero no aparece en mi aplicación tengo que utilizar la versión 3.2 de HMG para que me aparezca estoy trabajando con IDE-ANSI y la versión 3.4.3.
Tengo que incluir alguna librería?
Gracias
Traducción por google
Hello mol
I'm working on a program with RICHEDITBOX and I can not make it work, I've compiled it with several versions and I do not know what's happening, I do not mark any errors when compiling but it does not appear in my application I have to use version 3.2 of HMG so that I appear I am working with IDE-ANSI and version 3.4.3.
Do I have to include a library?
Thank you.
,___,
[O.o]
/)__)
KoKe
Re: HMG 3.4.4
Hi Koke!
I didn't attach any additional library.
Error, which I've reported is bounded with IDE.
My application works OK with few richeditboxes.
Maybe you can prepare small sample?
koke
Re: HMG 3.4.4
Post by koke »
En el adjunto agrego dos exes compilados en diferentes versiones de HMG
traducción por google
In the attachment I add two exes compiled in different versions of HMG
rich.zip
incluye 2 exes / 2 exes included
(2.89 MiB) Downloaded 874 times
,___,
[O.o]
/)__)
KoKe
Re: HMG 3.4.4
I think the problem is with IDE Ansi version. I didn't test UNICODE version.
But, we can not try to resolve it while we have no access to source code of IDE.
