We can see many applications having Meta Data like Company, File Version, Internal Name, Language, Original File Name, Product Name, Product Version, Description, Copyright etc when we right click and see the properties.
I wish to enter these meta data in HMG applications.
Are these facilities already in place?
Application Meta Data
Re: Application Meta Data
Hi,rathinagiri wrote:...
Yes, it is.
Simply add/adapt to your application.RC file the following lines:
and take a look for changes of the properties at the right mouse click1 VERSIONINFO
FILEVERSION 1,0,0,0
PRODUCTVERSION 1,0,0,0
FILEOS 0x4
FILETYPE 0x1
BLOCK "StringFileInfo"
BLOCK "040904b0"
VALUE "FileDescription", "Application Description\000"
VALUE "FileVersion", "1.0.0.0"
VALUE "InternalName", "Application Name\000"
VALUE "LegalCopyright", "My Copyright\000"
VALUE "LegalTrademarks", "Harbour"
VALUE "OriginalFilename", "AppName.exe"
VALUE "CompanyName", ""
VALUE "ProductName", "MiniGUI Utility"
VALUE "ProductVersion", "1.0.0.0"
VALUE "Comments", "Created by author\000"
BLOCK "VarFileInfo"
VALUE "Translation", 0x0409 0x04B0
Oh! Thanks a lot Grigory Filatov. I will try and revert back.
I've tried it in my resources, but doesn't work!
What's going on?
What's going on?
Hi,mol wrote:I've tried it in my resources, but doesn't work!
What's going on?
I confirm this problem with MinGW resource manager also
BTW I've got the following result by using freeware utility ResHaker 3.4.0.79 at http://angusj.com/resourcehacker (look at attached sample).
- test.zip
- Application with embedded Meta Data
- (623.2 KiB) Downloaded 494 times
Hello Grigory,
Thanks a lot for ResHacker
I downloaded it an tested with your sent example.
With best regards.
With best regards.
I've got good results with this http://hmgforum.com/viewtopic.php?p=34935#p34935
