Communication via http
Other General Resources like icon sets, sound files etc.,
Hi guys!
I've realised my first Arduino project. It will switch on/off lamp indicators depend on barcode scanner read in the warehouse.
Barcode scanner sends barcode to computer, computer sends info to my arduino which lamp should be switched on.
I've created http server which wait for info from computer via http.
I can control lamps via internet browser, calling arduino server: http://192.168.20.190/BRAMKA=3
I want to create simple application, which can call such a page.
Second problem is to act as http server to read info from wifi barcode reader.
Can anybody provide simplest http server application?
regards, Marek
Re: Communication via http
Marek,
Can you please explain more about what you want?
I have a NETIO server but I don't think you mean that.
I need to build app, which will wait for transmision at eg. 80 port.
I remember your work. But, I need minimum solution
I've simplified my procedure to control lamps:
PROCEDURE SendRequestViaWWW
	param cURL
	local lSilent := .f.
	LOCAL oCon, i
	local ret := .f.
	local cOdp:=""
	for i:=1 to 3
		// number of tries
		oCon := TipClientHttp():New( cUrl )
		IF oCon:Open()
			cOdp := oCon:ReadAll()
			msgdebug("Connected?", cOdp)
			oCon:close()
			ret := .t.
			exit
	next i
	if !ret
		MsgBox("Error in connection " + oCon:lastErrorMessage())
RETURN ret
I can switch on/off 32 sending www request:
SendRequestViaWWW("http://192.168.20.190/BRAMKA=16")
Now, I need to create server, which will wait for request from codebar scanner
edk
Post by edk »
Marek, maybe this will be helpful: micro web server on hb (uhttpd)
https://github.com/harbour/core/tree/ma ... as/httpsrv
and
https://github.com/vszakats/harbour-cor ... ib/hbhttpd
I've created my solution. It's very small and it's doing what I want.
A month ago, I even didnt dream I'll be able to control some devices from harbour app via wifi.
I'll present my app later.
edk
Post by edk »
So I'm waiting impatiently 8-)
