PDF Viewer DLL?
Re: PDF Viewer DLL?
Thanks a lot, every time this tool is more usefull
Re: PDF Viewer DLL?
PdfView version 2017-11-27 released.
Added:
- ability to translate of selected text in PDF document using Google (MainMenu -> Document -> Translate selected text).
Added in SumatraPDF.prg library:
- function Sumatra_SelectAll,
- function Sumatra_GetSelText.
Added:
Re: PDF Viewer DLL?
Dzięki Krzysztof.
Re: PDF Viewer DLL?
PdfView version 2018-05-02 released.
Added:
- show/hide files panel (Main menu -> View -> Files panel),
- opening file(s) via GetFile() function (Main menu -> File -> Open in ...),
- terminate all SumatraPDF child processes when an error occurs (PdfView_ErrorSys.prg),
- "Options" dialog (Main menu -> Settings -> Options),
- ability to set maximum tabs width,
- ability to drag and drop the tabs,
- ability to close all documents (Main menu -> Document -> Close all).
Fixed minor bugs.
Translations into Spanish and Portuguese are implemented only in about 30 percent (by Pablo César).
Can anyone translate the remaining 70 percent of the strings?
In the opposite case, I will have to remove Spanish and Portuguese translations from the project.
Added:
Fixed minor bugs.
Re: PDF Viewer DLL?
Thanks Edward, great job!
Re: PDF Viewer DLL?
Serge, you mean Krzysztof rather than Edward.
KDJ = Krzysztof
edk = Edward
@ Krzysztof.
Wspaniale, dzięki.
