Harbour MiniGUI Extended Edition build 17.11 is published
Hi Friends,
I am glad to announce a new version of Harbour MiniGUI Extended Edition.
A setup of the build 17.11 for Borland C++ 5.5.1 is published at
the following URL:
There are also an extra xHarbour.org-based archive for this build and
Minigui Ex build for the free Embarcadero C++ 10.1 Berlin compiler at
the Minigui's download page.
It is a regularly scheduled maintenance release.
It is possible to prepare the Minigui Ex builds also for the following
C-compilers by your request:
- MinGW 7.2.0 32-bit and Harbour 3.2.0dev;
- MinGW 7.2.0 64-bit and Harbour 3.4.0dev;
- MS VisualC 2017 32-bit and Harbour 3.2.0dev.
Thank's for your attention and support!
Best Regards,
[MiniGUI Team]
the following URL:
Best Regards,
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 17.11 is published
Thanks Grigory !
Thank you Grigory
Anand
Anand
As usual, great job.
Thank you Mr Grigory.
Said, Algiers
Said, Algiers
Thank you Grigory !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
Thanks Grigory !
- luisvasquezcl
Thanks Grigory.
Congratulation.
best regards,
Luis Vasquez
Congratulation.
best regards,
Luis Vasquez
Excellent, Filatov.
Thank you very much.
- apais
I tried HMG extended. But...
I did not find how to compile it with gcc.
I could not use .png files from resources.
Any clues ?
Is there any forum like this for HMGE ?
PS: I like tsbrowse A LOT !
Any clues ?
Angel Pais
