HMGSCRIPT R42
Re: HMGSCRIPT R42
I'm afraid I can't help (change database to mysql because of series of disasters with XML files, I understand!)
Re: HMGSCRIPT R42
hello guys need something else in the browser to generate the pdfs? is not generating the pdf I should have installed some extension in the browser, I found out what is the file myapp.cgi makes the connection of the user but I am trying to login and does not accept
Re: HMGSCRIPT R42
Hi guys need an example with mysql connection with grid, do we have this possibility?
Re: HMGSCRIPT R42
Yes, it is possible:
Just try something like this:
To compile your source.
SET HMGWEB=c:\hmgweb\jairsources
SET HBPATH=C:\hmgweb\harbour\bin
SET HMGINCPATH=c:\hmgweb\include
SET APACHECGIPATH=C:\hmgweb\apache\cgi-bin
%HBPATH%\hbmk2 %HMGWEB%\your_source -i%HMGINCPATH% -shared hbhpdf.hbc hbmysql.hbc hbct.hbc hbmisc.hbc
IF ERRORLEVEL 0 MOVE your_source.exe %APACHECGIPATH%\your_source.cgi
Re: HMGSCRIPT R42
I need connection via hmgscript I will not use cgi files I chose hmgscript has this example here but I do not use php and yes mariadbserge_girard wrote: ↑Wed Feb 06, 2019 8:26 am Yes, it is possible:
To compile your source.Code: Select all
SET HMGWEB=c:\hmgweb\jairsources SET HBPATH=C:\hmgweb\harbour\bin SET HMGINCPATH=c:\hmgweb\include SET APACHECGIPATH=C:\hmgweb\apache\cgi-bin %HBPATH%\hbmk2 %HMGWEB%\your_source -i%HMGINCPATH% -shared hbhpdf.hbc hbmysql.hbc hbct.hbc hbmisc.hbc IF ERRORLEVEL 0 MOVE your_source.exe %APACHECGIPATH%\your_source.cgi
// MySQLBROWSE DEMO
function MySQLBrowse( oParent , nRow , nCol , nWidth , nHeight , cHost, cUser, cPassword, nPort, cDB, cQuery, nInnerWidth )
var cId = 'control' + (nControlCount).toString() ; nControlCount++ ;
var query = 'cHost=' + cHost + '&'
+ 'cUser=' + cUser + '&'
+ 'cPassword=' + cPassword + '&'
+ 'nPort=' + nPort + '&'
+ 'cDB=' + cDB + '&'
+ 'cQuery=' + cQuery + '&'
+ 'cId=' + cId + '&'
+ 'nInnerWidth=' + nInnerWidth + '&';
var control = document.createElement( "div" ) ;
var panel = cId + '_panel';
control.className = "browse" ;
control.style.position = "absolute" ;
control.style.top = nRow ;
control.style.left = nCol ;
control.style.width = nWidth ;
control.style.height = nHeight ;
control.id = panel ;
control.innerHTML = "Loading..." ;
control.style.border = "solid 1px rgb(200,200,200)" ;
control.style.overflow = "scroll" ;
document.getElementById( oParent.getId() ).appendChild( control ) ;
xmlHttp=new XMLHttpRequest();
xmlHttp.open( "POST" , "/php/mysql.php" , false ) ;
xmlHttp.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded');
xmlHttp.send( query );
document.getElementById(panel).innerHTML = xmlHttp.responseText;
this.getPageSize = function()
return nPageSize ;
this.getSelectedRowCount = function()
var i, n ;
n = 0 ;
for ( i=1 ; i < document.getElementById(cId).rows.length ; i++ )
if ( document.getElementById(cId).rows[i].cells[0].getElementsByTagName("input")[0].checked == true )
n++ ;
return n;
this.getSelectedRows = function()
var selectedRows=new Array();
var i, code, first, last, n ;
n = 0 ;
selectedRows[n] = i ;
n++ ;
return selectedRows;
this.getRowCount = function()
return document.getElementById(cId).rows.length;
this.getCell = function( nRow , nCOl )
return trim(document.getElementById(cId).rows[nRow].cells[nCOl].childNodes[0].data);
this.select = function( nRow )
document.getElementById(cId).rows[nRow].cells[0].getElementsByTagName("input")[0].checked = true ;
changeState( document.getElementById(cId).rows[nRow].cells[0].getElementsByTagName("input")[0] );
this.unSelect = function( nRow )
document.getElementById(cId).rows[nRow].cells[0].getElementsByTagName("input")[0].checked = false ;
this.refresh = function( )
this.getId = function ()
return cId;
function test_0()
oWin = new Form( "MySQLBrowse Test", 590 , 480 );
Button( oWin , 390 , 40 , "Refresh" , "oBrowse.refresh()" );
Button( oWin , 390 , 170 , "Show Selected" , "ShowSelected(oBrowse)" );
Button( oWin , 390 , 300 , "Append" , "AppendTest( oBrowse )" );
Button( oWin , 430 , 40 , "Delete Selected" , "DeleteTest(oBrowse)" );
Button( oWin , 430 , 170 , "Select All" , "SelectAll( oBrowse )" );
Button( oWin , 430 , 300 , "UnSelect All" , "UnSelectAll( oBrowse )" );
Button( oWin , 430 , 430 , "Close" , "oWin.release()" );
oBrowse = new MySQLBrowse( oWin ,
050 , 050 , 510 , 340 , 'localhost', 'root', '401375', '3306', 'techworks', 'select * from clientes', 250 );
function ShowSelected( oBrowse )
if ( oBrowse.getSelectedRowCount() == 0 )
alert('No Rows Selected!');
return;
var aSelection = oBrowse.getSelectedRows();
for ( var i = 0 ; i < aSelection.length ; i++ )
nRow = aSelection [i] ;
code = oBrowse.getCell( nRow , 1 );
first = oBrowse.getCell( nRow , 2 );
last = oBrowse.getCell( nRow , 3 );
alert ( code + ' ' + first + last );
Re: HMGSCRIPT R42
Hello everyone, could someone help me in an example of connection via .js from hmgscript I am developing system but I still could not connect to the bank in the forum example need arqruivo mysql.php I use mariadb how should I do?jairpinho wrote: ↑Thu Feb 07, 2019 9:17 pmI need connection via hmgscript I will not use cgi files I chose hmgscript has this example here but I do not use php and yes mariadbserge_girard wrote: ↑Wed Feb 06, 2019 8:26 am Yes, it is possible:
/////////////////////////////////////////////////////////////////////////////////////////////// // MySQLBROWSE DEMO /////////////////////////////////////////////////////////////////////////////////////////////// function MySQLBrowse( oParent , nRow , nCol , nWidth , nHeight , cHost, cUser, cPassword, nPort, cDB, cQuery, nInnerWidth ) { var cId = 'control' + (nControlCount).toString() ; nControlCount++ ; var query = 'cHost=' + cHost + '&' + 'cUser=' + cUser + '&' + 'cPassword=' + cPassword + '&' + 'nPort=' + nPort + '&' + 'cDB=' + cDB + '&' + 'cQuery=' + cQuery + '&' + 'cId=' + cId + '&' + 'nInnerWidth=' + nInnerWidth + '&'; var control = document.createElement( "div" ) ; var panel = cId + '_panel'; control.className = "browse" ; control.style.position = "absolute" ; control.style.top = nRow ; control.style.left = nCol ; control.style.width = nWidth ; control.style.height = nHeight ; control.id = panel ; control.innerHTML = "Loading..." ; control.style.border = "solid 1px rgb(200,200,200)" ; control.style.overflow = "scroll" ; document.getElementById( oParent.getId() ).appendChild( control ) ; xmlHttp=new XMLHttpRequest(); xmlHttp.open( "POST" , "/php/mysql.php" , false ) ; xmlHttp.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded'); xmlHttp.send( query ); document.getElementById(panel).innerHTML = xmlHttp.responseText; this.getPageSize = function() { return nPageSize ; } this.getSelectedRowCount = function() { var i, n ; n = 0 ; for ( i=1 ; i < document.getElementById(cId).rows.length ; i++ ) { if ( document.getElementById(cId).rows[i].cells[0].getElementsByTagName("input")[0].checked == true ) { n++ ; } } return n; }; this.getSelectedRows = function() { var selectedRows=new Array(); var i, code, first, last, n ; n = 0 ; for ( i=1 ; i < document.getElementById(cId).rows.length ; i++ ) { if ( document.getElementById(cId).rows[i].cells[0].getElementsByTagName("input")[0].checked == true ) { selectedRows[n] = i ; n++ ; } } return selectedRows; }; this.getRowCount = function() { return document.getElementById(cId).rows.length; } this.getCell = function( nRow , nCOl ) { return trim(document.getElementById(cId).rows[nRow].cells[nCOl].childNodes[0].data); } this.select = function( nRow ) { document.getElementById(cId).rows[nRow].cells[0].getElementsByTagName("input")[0].checked = true ; changeState( document.getElementById(cId).rows[nRow].cells[0].getElementsByTagName("input")[0] ); } this.unSelect = function( nRow ) { document.getElementById(cId).rows[nRow].cells[0].getElementsByTagName("input")[0].checked = false ; changeState( document.getElementById(cId).rows[nRow].cells[0].getElementsByTagName("input")[0] ); } this.refresh = function( ) { xmlHttp=new XMLHttpRequest(); xmlHttp.open( "POST" , "/php/mysql.php" , false ) ; xmlHttp.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded'); xmlHttp.send( query ); document.getElementById(panel).innerHTML = xmlHttp.responseText; } this.getId = function () { return cId; } } function test_0() { oWin = new Form( "MySQLBrowse Test", 590 , 480 ); Button( oWin , 390 , 40 , "Refresh" , "oBrowse.refresh()" ); Button( oWin , 390 , 170 , "Show Selected" , "ShowSelected(oBrowse)" ); Button( oWin , 390 , 300 , "Append" , "AppendTest( oBrowse )" ); Button( oWin , 430 , 40 , "Delete Selected" , "DeleteTest(oBrowse)" ); Button( oWin , 430 , 170 , "Select All" , "SelectAll( oBrowse )" ); Button( oWin , 430 , 300 , "UnSelect All" , "UnSelectAll( oBrowse )" ); Button( oWin , 430 , 430 , "Close" , "oWin.release()" ); oBrowse = new MySQLBrowse( oWin , 050 , 050 , 510 , 340 , 'localhost', 'root', '401375', '3306', 'techworks', 'select * from clientes', 250 ); } //---------------------------------------------------------------------------------------------// function ShowSelected( oBrowse ) { if ( oBrowse.getSelectedRowCount() == 0 ) { alert('No Rows Selected!'); return; } var aSelection = oBrowse.getSelectedRows(); for ( var i = 0 ; i < aSelection.length ; i++ ) { nRow = aSelection [i] ; code = oBrowse.getCell( nRow , 1 ); first = oBrowse.getCell( nRow , 2 ); last = oBrowse.getCell( nRow , 3 ); alert ( code + ' ' + first + last ); } }
xmlHttp = new XMLHttpRequest ();
xmlHttp.open ("POST", "/php/mysql.php", false);
xmlHttp.setRequestHeader ('Content-Type', 'application / x-www-form-urlencoded');
xmlHttp.send (query);
document.getElementById (panel) .innerHTML = xmlHttp.responseText;
Re: HMGSCRIPT R42
Jair,
Can you send complete sources?
Re: HMGSCRIPT R42
added mysql button and example, add the folder harbour, I retired to get smaller file size
Re: HMGSCRIPT R42
Jair,
File is probably damaged!
