pdf grid
Re: pdf grid
It should be in Ansi.
I think Jair was about the word "Mínimo:" as UTF8 in prg, which show as "MÃ-nimo" in PDF Ansi.
In the example I showed both words.
If you save prg in UTF8, then in PDF you will see MÃ-nimo instead of Mínimo (second word)
Maybe this will be helpful for PDF in UTF8 https://github.com/libharu/libharu/issues/27
Re: pdf grid
rotatetext () is okay the problem and in print_grid () follows new codeedk wrote: ↑Fri Oct 06, 2017 2:21 pm I don't see the problem with accents:Code: Select all
#include "hmg.ch" Function Main() Local i SELECT HPDFDOC "sample.pdf" ORIENTATION HPDF_ORIENT_LANDSCAPE PAPERSIZE HPDF_PAPER_A4 SET HPDFDOC ENCODING TO "WinAnsiEncoding" START HPDFDOC START HPDFPAGE print_grid( 400, 150, 160, 200, 5, 5, 20 , 20 , 10 , 10 ) HPDF_RotateTextPx( 510, 200, 'MĂ-nimo: 119 -> "Mínimo: "', Nil, 7, 90 , , , , 'T' ) //units: pixels END HPDFPAGE END HPDFDOC Execute File 'sample.pdf' Return Nil ******************************* PROCEDURE HPDF_RotateTextPx( nRow, nCol, cTxt, cFont, nFontSize, nAngle, lBold, lItalic, aColors, cAlign) * Rotating text Local nRad, nTextWidth, oFont, cFnt Local hPdf := _HMG_SYSDATA[ 150 ][ 1 ] Local hPage := _HMG_SYSDATA[ 150 ][ 7 ] Local cPdfEnc := _HMG_SYSDATA[ 150 ][ 10 ] Local nWidth := _HMG_SYSDATA[ 150 ][ 4 ] Local nHeight := _HMG_SYSDATA[ 150 ][ 5 ] Local nxPos := nCol Local nyPos := nRow DEFAULT cFont := "Helvetica" DEFAULT nFontSize := 12 DEFAULT cTXt := "" DEFAULT nAngle := 0 DEFAULT lBold := .F. DEFAULT lItalic := .F. DEFAULT aColors := { 0, 0, 0} DEFAULT cAlign :="" //Empty - Left and bottom, R - Right, C - Center, T - Top, M - Middle If _HMG_SYSDATA[ 150 ][ 1 ] == Nil // PDF object not found! _HMG_HPDF_Error( 3 ) Return Nil endif If _HMG_SYSDATA[ 150 ][ 7 ] == Nil // PDF Page object not found! _HMG_HPDF_Error( 5 ) Return Nil endif IF VALTYPE(cAlign)#'C' cAlign := '' //Left as default ENDIF // set color If VALTYPE( aColors )#'A' .OR. LEN( aColors )#3 .OR. ; VALTYPE( aColors[1] )#'N' .OR. VALTYPE( aColors[2] )#'N' .OR. VALTYPE( aColors[3] )#'N' .OR. ; aColors[1]<0 .OR. aColors[1]>255 .OR. ; aColors[2]<0 .OR. aColors[2]>255 .OR. ; aColors[3]<0 .OR. aColors[3]>255 aColors := { 0, 0, 0} Endif HPDF_Page_SetRGBFill( hPage, aColors[1]/255, aColors[2]/255, aColors[3]/255 ) // set font If HMG_LEN( AllTrim( cFont ) ) == 0 cFont := _HMG_HPDF_SetFont( cFont, lBold, lItalic ) oFont := HPDF_GetFont( hPdf, cFont, cPdfEnc ) else cFont := AllTrim(_HMG_HPDF_SetFont( cFont, lBold, lItalic )) if HMG_UPPER (cFileExt (cFont)) == '.TTF' // load ttf font cFnt := HPDF_LOADTTFONTFROMFILE( hPdf, cFont, .t. ) If HMG_LEN( Alltrim( cFnt ) ) == 0 _HMG_HPDF_Error( 6 , cFont ) Return Nil endif oFont := HPDF_GetFont( hPdf, cFnt, cPdfEnc ) else If HMG_UPPER( alltrim( cFont ) ) == "SYMBOL" .or. HMG_UPPER( alltrim( cFont ) ) == "ZAPFDINGBATS" oFont := HPDF_GetFont( hPdf, cFont, Nil ) else oFont := HPDF_GetFont( hPdf, cFont, cPdfEnc ) endIf endif endIf If oFont == Nil _HMG_HPDF_Error( 6 , cFont ) Return Nil Endif HPDF_Page_SetFontAndSize( hPage, oFont, nFontSize ) nTextWidth := HPDF_Page_TextWidth( hPage, cTxt ) nRad := nAngle / 180 * 3.141592 //radian value //calculate nxPos IF 'R'$HMG_UPPER(cAlign) //Right nxPos:=nxPos - (nTextWidth* cos (nRad)) ELSEIF 'C'$HMG_UPPER(cAlign) //Center nxPos:=nxPos - ((nTextWidth* cos (nRad))/2) ENDIF //calculate nyPos IF 'T'$HMG_UPPER(cAlign) //Top nyPos:=nyPos - (nTextWidth* sin (nRad)) ELSEIF 'M'$HMG_UPPER(cAlign) //Middle nyPos:=nyPos - ((nTextWidth* sin (nRad))/2) ENDIF HPDF_Page_BeginText( hPage ) HPDF_Page_SetTextMatrix ( hPage, cos ( nRad ), sin ( nRad ), -sin ( nRad ), cos ( nRad ), nxPos , nyPos) HPDF_Page_ShowText( hPage, cTxt ) HPDF_Page_EndText( hPage ) RETURN *------------------------------------------------------------------------* Function print_grid( nRow, nCol, height, width, nScaleLine_X, nScaleLine_Y, nScaleText_X, nScaleText_Y, nTag_x, nTag_Y ) *------------------------------------------------------------------------* Local font,x,y, cLabel, nLabWidth Local Pdf := _HMG_SYSDATA[ 150 ][ 1 ] Local Page := _HMG_SYSDATA[ 150 ][ 7 ] Local cPdfEnc := _HMG_SYSDATA[ 150 ][ 10 ] Local nFontSize := 5 font := HPDF_GetFont (pdf, "Helvetica", cPdfEnc) HPDF_Page_SetFontAndSize (page, font, nFontSize) HPDF_Page_SetGrayFill (page, 0.5) HPDF_Page_SetGrayStroke (page, 0.8) /* Draw horizontal lines */ y := 0 // distabcia inicio primeira linha while (y <= height ) if (y % (nScaleLine_Y*2) == 0) HPDF_Page_SetLineWidth (page, 0.5) else if (HPDF_Page_GetLineWidth (page) != 0.25) HPDF_Page_SetLineWidth (page, 0.25) Endif Endif HPDF_Page_MoveTo (page, nCol, y + nRow) HPDF_Page_LineTo (page, width + nCol, y + nRow) HPDF_Page_Stroke (page) if (y % nTag_Y == 0 .and. y > 0) HPDF_Page_SetGrayStroke (page, 0.5) HPDF_Page_MoveTo (page, nCol, y + nRow) HPDF_Page_LineTo (page, nScaleLine_Y + nCol , y + nRow) HPDF_Page_Stroke (page) HPDF_Page_SetGrayStroke (page, 0.8) Endif y += nScaleLine_Y End /* Draw vertical lines */ x := 0 //distabcia inicio primeira linha while (x <= width) if (x % (nScaleLine_X*2) == 0) HPDF_Page_SetLineWidth (page, 0.5) else if (HPDF_Page_GetLineWidth (page) != 0.25) HPDF_Page_SetLineWidth (page, 0.25) Endif Endif HPDF_Page_MoveTo (page, x + nCol, nRow) HPDF_Page_LineTo (page, x + nCol, height + nRow) HPDF_Page_Stroke (page) if (x % nTag_X == 0 .and. x > 0) // linha de referencia com a tag texto linha mais forte HPDF_Page_SetGrayStroke (page, 0.5) //tag esquerda HPDF_Page_MoveTo (page, x + nCol, nRow) HPDF_Page_LineTo (page, x + nCol, nScaleLine_X + nRow ) HPDF_Page_Stroke (page) //tag direita HPDF_Page_MoveTo (page, x + nCol, height + nRow) HPDF_Page_LineTo (page, x + nCol, height - nScaleLine_X + nRow) HPDF_Page_Stroke (page) HPDF_Page_SetGrayStroke (page, 0.8) Endif x += nScaleLine_X End /* Draw horizontal text */ y := 0 //distabcia inicio texto while (y < height) if (y % (nScaleText_Y) == 0 .and. y > 0) cLabel:=ltrim(str(y)) HPDF_Page_BeginText (page) HPDF_Page_MoveTextPos (page, nScaleLine_Y + nCol, y + nRow - (nFontSize/2) + .75 /* Middled Label */) HPDF_Page_ShowText (page, cLabel) HPDF_Page_EndText (page) Endif y += nScaleText_Y End /* Draw virtical text */ x := 0 while (x < width) if (x % (nScaleText_X) == 0 .and. x > 0) cLabel:=ltrim(str(x)) nLabWidth:=HPDF_Page_TextWidth( page, cLabel ) //tag em baixo HPDF_Page_BeginText (page) HPDF_Page_MoveTextPos (page, x + nCol - (nLabWidth/2) /* Centered label */, nScaleLine_X + nRow + 1) HPDF_Page_ShowText (page, cLabel) HPDF_Page_EndText (page) //tag em cima HPDF_Page_BeginText (page) HPDF_Page_MoveTextPos (page, x + nCol - (nLabWidth/2) /* Centered label */, height - (nScaleLine_X * 2) + nRow) HPDF_Page_ShowText (page, cLabel) HPDF_Page_EndText (page) Endif x += nScaleText_X End HPDF_Page_SetGrayFill (page, 0) HPDF_Page_SetGrayStroke (page, 0) Return Nil
sample.7z
Do you have a .prg file saved in UTF-8? Perhaps this is a problem.
Prg in ANSI works fine: Demo.7z
Function print_grid( nRow_pdf, nCol, height, width, nScaleLine_X, nScaleLine_Y, nScaleText_X, nScaleText_Y, nTag_x, nTag_Y,nMim,nMax )
Local ofont, x , y , yMin_max, cLabel, nLabWidth
Local cEncoding := _HMG_SYSDATA[ 150 ] [ 10 ] //Value of "SET HPDFDOC ENCODING TO". "SET HPDFDOC ENCODING TO" set _HMG_HPDF_SetEncoding
Local nHeigth_pdf := HPDF_Page_GetHeight (_HMG_SYSDATA[ 150 ][ 7 ])
Local nCinza := 0.90 // 1 igual a branco total
Local nRow := nHeigth_pdf - nRow_pdf
Local nyPos := 0
Local cFont := "Helvetica"
Local nFontSize := 10
Local lBold := .F.
Local lItalic := .F.
Local aColors := { 0, 0, 0}
Local cAlign :="" //Empty - Left and bottom, R - Right, C - Center, T - Top, M - Middle
ofont := HPDF_GetFont (Pdf, cFont, cEncoding)
HPDF_Page_SetFontAndSize (Page, ofont, nFontSize)
HPDF_Page_SetGrayFill (page, 0.25)
HPDF_Page_SetGrayStroke (page, nCinza)
As cores são especificadas usando três números reais (ou seja, com um ponto decimal) na forma R G B onde cada número define a quantidade de vermelho (R), verde (G) e azul (B) em uma cor.
Os números válidos são de 0,0 a 1,0 inclusive ou divide por 255
yMin_max := 0 // linhas de tolerancias
while (yMin_max <= height )
if yMin_max == nMim
HPDF_Page_SetDash (page, {3}, 1, 1)
//HPDF_Page_SetGrayStroke(page, 0,0,0)
HPDF_Page_SetRGBStroke (page, 0 , 0 , 0 ) // (page, 0.0 , 255/255, 0.0 )
HPDF_Page_MoveTo (page, nCol, yMin_max + nRow)
HPDF_Page_LineTo (page, width + nCol, yMin_max + nRow)
nAngle := 0
nTextWidth := HPDF_Page_TextWidth( page ,"Mínimo: " +alltrim(str(nMim) ))
nxPos:= 85 - (nTextWidth* cos (nRad)) // posição coluna do texto
nyPos := nRow + nMim
HPDF_Page_SetTextMatrix ( page , cos ( nRad ), sin ( nRad ), -sin ( nRad ), cos ( nRad ), nxPos , nyPos - nFontSize/2 + .75 ) // nyPos = posicao Linha(Row)
HPDF_Page_ShowText (page, "Mínimo: "+alltrim(str(nMim)))
HPDF_Page_SetDash (page, NIL, 0, 0)
elseif yMin_max == nMax
HPDF_Page_SetRGBStroke (page, 0 , 0, 0 ) // (page, 0.0 , 255/255, 0.0 )
nAngle := 0
nTextWidth := HPDF_Page_TextWidth( page , "Máximo: "+alltrim(str(nMax)))
nxPos:= 85 - (nTextWidth* cos (nRad)) // // posição coluna do texto
nyPos := nRow + nMax
HPDF_Page_ShowText (page, "Máximo: "+alltrim(str(nMax)))
yMin_max += 1
End
Re: pdf grid
Hi colleagues:
Edk last code works fine, i've tested.-
Jaipirinho, you must convert prg from UTF8 to ansi, replace ma nimo with Máximo, and save your prg.-
With regards.
Eduardo
With regards.
Eduardo
Re: pdf grid
Thx Eduardo and Kryzstof ! This works fine.
Re: pdf grid
thank you all really my prg file was like utf8 converted to ansi it worked perfectly, it follows the complete design including all the requested topics in a single project, if anyone needs this ready, it was very useful in my project.
Related Posts
http://www.hmgforum.com/viewtopic.php?f=39&t=5404
http://www.hmgforum.com/viewtopic.php?f=40&t=5406
Project
Related Posts
Project
- Relatoriojpg_Page2jpg_Page1.jpg (83.18 KiB) Viewed 22485 times
- Relatoriojpg_Page1.jpg (79.39 KiB) Viewed 22486 times
Re: pdf grid
You were important in this project, without your help you would not be able to
Re: pdf grid
Hi everyone, I did some tests with grid in pdf where I can customize the herders size of the lines and data in a vector, I am providing the result so that you need
Function teste()
Local i, lSuccess
LOCAL aSize_Col := {25,90,15,15}
LOCAL aSize_Row := {5,10,10,20,20}
Local aDados := {}
SELECT HPDFDOC "sample.pdf" TO lSuccess ORIENTATION HPDF_ORIENT_LANDSCAPE PAPERSIZE HPDF_PAPER_A4
START HPDFDOC
START HPDFPAGE
//msgdebug(HPDF_Page_GetHeight (_HMG_SYSDATA[ 150 ][ 7 ]))
//msgdebug(HPDF_Page_GetWidth (_HMG_SYSDATA[ 150 ][ 7 ]))
@10,10 HPDFPRINT "Grid Demo Page 1"
AADD(aDados , {"A1","A2","A3","A4","A5"})
AADD(aDados , {"B1","B2","C3","C4","C5"})
AADD(aDados , {"C1","C2","D3","D4","D5"})
AADD(aDados , {"E1","E2","E3","E4","E5"})
AADD(aDados , {"F1","F2","F3","F4","F5"})
AADD(aDados , {"G1","G2","G3","G4","G5"})
//MSGDEBUG(LEN(aDados))
print_grid_A( 50, 50, 10 ,aSize_Col,{"col1","col2","col3","Col4"},aDados)
END HPDFPAGE
END HPDFDOC
IF lSuccess
Function print_grid_A( nRow_pdf, nCol_pdf, nSize_Row , aSize_Col, aHeaders, aDados )
Local font, cLabel, nLabWidth
Local nHeigth_pdf := HPDF_Page_GetHeight (_HMG_SYSDATA[ 150 ][ 7 ]) // pega altura da pagina em pixel
Local nWidth_pdf := HPDF_Page_GetWidth (_HMG_SYSDATA[ 150 ][ 7 ]) // pega comprimento da pagina em pixel
Local nRow_Y := nHeigth_pdf - _HMG_HPDF_MM2Pixel( nRow_pdf )
Local nCol_X := _HMG_HPDF_MM2Pixel( nCol_pdf ) //- nWidth_pdf
Local nRow := nRow_pdf
Local nCol := nCol_pdf
LOCAL nQt_Col := LEN(aSize_Col)
Local nSize_colunas := 0
Local nSize_Linhas := 0
Local y := 0// linhas na horizontal
Local i := 0
Local nSize_Header := 12
IF EMPTY(aHeaders)
MsgInfo("Cabeçalhos esta vazio")
Else
nQt_Col := Len(aHeaders)
IF EMPTY(nSize_Row)
MsgInfo("tamanho da linha esta vazio")
nQt_Row := Len(aDados)
IF EMPTY(aSize_Col)
MsgInfo("tamanho da coluna esta vazio")
font = HPDF_GetFont (pdf, "Helvetica", Nil)
HPDF_Page_SetGrayFill (page, 0) // cor da fonte = preto
HPDF_Page_SetGrayStroke (page, 0) // 0 == preto
nColuna := 1
nLinha := 1
i := 0
//* Draw vertical linhas montagem das colunas */
x := 0 //linhas na vertical ok
for x := 1 to len(aSize_Col)
nSize_colunas += _HMG_HPDF_MM2Pixel(aSize_Col[x])
next
nSize_Linhas += nSize_Row * nQt_Row
Size_Row := 0
y := 0 // linhas na horizontal
i := 0
//MONTA O HEADER nao mexer
x := 0
For Col := 1 to nQt_Col
cLabel:=aHeaders[Col]
IIF( Col == nQt_Col , 0 , Size_Col := _HMG_HPDF_MM2Pixel(aSize_Col[Col]) )
HPDF_Page_MoveTextPos (page, (x + nCol_X + (Size_Col/2)) - (nLabWidth/2) , nRow_Y - (nFontSize/2 - .75 ) - (nSize_Header/2) ) // headers
X += Size_Col
For Row := 0 to nQt_Row +1
// Draw horizontal lines
HPDF_Page_MoveTo (page, nCol_X, y + nRow_Y)
HPDF_Page_LineTo (page, nSize_colunas + nCol_X , y + nRow_Y)
//// DADOS NA GRID
IF Row > 0 .and. Row < nQt_Row +1
x := 0
cLabel:=aDados[Row,Col]
HPDF_Page_MoveTextPos (page, x + nCol_X + (Size_Col/2) - (nLabWidth/2 ) , nRow_Y + y - (nSize_Row/2) - (nFontSize/2 - .75 ) ) // headers
X += Size_Col
IF ROW < 1
y -= nSize_Header // tamanho padra para headers = nSize_Header
y -= nSize_Row //distancia entre linhas
/////////////////////////////COLUNAS////////////////////////
x := 0
For Col := 0 to nQt_Col
IIF( Col == nQt_Col , 0 , Size_Col := _HMG_HPDF_MM2Pixel(aSize_Col[Col+1]) )
HPDF_Page_MoveTo (page, x + nCol_X, nRow_Y)
HPDF_Page_LineTo (page, x + nCol_X , nRow_Y - nSize_Linhas - nSize_Header)
x += Size_Col // distancia entre colunas
next
- samplejpg_Page1.jpg (27.41 KiB) Viewed 21070 times
Re: pdf grid
Es una pregunta ?
Puedes cambiar los siguientes valores para cada columna...
It is a question ?
You can change the following values for each column ...
LOCAL aSize_Row := {5,10,10,20,20} // ************ Where do you use this array?
print_grid_A( 50, 50, 10 , aSize_Col,{"col1","col2","col3","Col4"},aDados)
Re: pdf grid
andyglezl wrote: ↑Tue Nov 27, 2018 4:39 amHi everyone, I did some tests with grid in pdf where I can customize the herders size of the lines and data in a vector, I am providing the result so that you need
Es una pregunta ?
It is a question ?
Hello Andrés, yes I had this option I also removed to be equal a window grid with the only option for all lines this vector should be disregarded, the value 10 equals for all lines after the header, the header has a fixed value of 12.
