pdf grid
jairpinho
pdf grid
Post by jairpinho »
I need to do a grid with scales in pdf, I followed an example of harupdf but I can not close the grid border and position it in x, y in pdf I do not know where to modify to happen
Function Drawtext1()
Local i
SELECT HPDFDOC "sample.pdf" PAPERLENGTH 300 PAPERWIDTH 300 LOG
cArquivo:= DiskName()+ ":\"+CurDir() + "\sample"+ ".pdf"
   SELECT HPDFDOC cArquivo TO lSuccess ORIENTATION HPDF_ORIENT_LANDSCAPE PAPERSIZE HPDF_PAPER_A4
   SET HPDFDOC  COMPRESS ALL
   SET HPDFDOC  PAGEMODE TO OUTLINE
   SET HPDFINFO AUTHOR      TO 'Jair Pinho'
   SET HPDFINFO CREATOR     TO 'Jair Pinho'
   SET HPDFINFO TITLE      TO 'Relaório'
   SET HPDFINFO SUBJECT     TO 'Criado com LibHaru/HPDF Library'
   SET HPDFINFO KEYWORDS    TO 'HMG, HPDF, Documentation, LibHaru, Harbour, MiniGUI'
   SET HPDFINFO DATECREATED TO date() TIME time()
START HPDFDOC
    START HPDFPAGE
	SET HPDFDOC PAGEOUTLINE TITLE "Sample"
		//@ 10,10 HPDFPRINT "Rotate Demo"
		//@ 10,10 HPDFPRINT LINE TO  10, 100 PENWIDTH 0.15 COLOR RED
        HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 90 )
		HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 180)
        HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 270)
		HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 0 )
	FOR i=100 TO 300 STEP 10
		@i,10 HPDFPRINt "Happy HMG"
	NEXT i
	FOR i=0 To 345 STEP 15
		@ i,_HMG_HPDF_Pixel2MM(150) HPDFPRINT LINE TO  150, 10 PENWIDTH 0.15 COLOR RED
		HPDF_RotateText( 150, 150, "Happy HMG", Nil, 10, i )
	NEXT i
//print_grid( nRow,nCol, height, width, nSpaceLine_X,nSpaceLine_Y,nSpaceText_X,nSpaceText_Y, nTag_x,nTag_Y )
	print_grid( 50,150, 160, 200, 5, 5, 20 , 20 , 10 , 10 )
    END HPDFPAGE
END HPDFDOC
Execute File 'sample.pdf'
Function print_grid( nRow,nCol, height, width, nScaleLine_X,nScaleLine_Y,nScaleText_X,nScaleText_Y, nTag_x,nTag_Y )
   Local  font,x,y
   Local Pdf        := _HMG_SYSDATA[ 150 ][ 1 ]
   Local Page       := _HMG_SYSDATA[ 150 ][ 7 ]
    font = HPDF_GetFont (pdf, "Helvetica", Nil)
    HPDF_Page_SetFontAndSize (page, font, 5)
    HPDF_Page_SetGrayFill (page, 0.5)
    HPDF_Page_SetGrayStroke (page, 0.8)
    /* Draw horizontal lines */
    y := 0 // distabcia inicio primeira linha
    while (y < height)
        if  (y % (nScaleLine_Y*2) == 0)
            HPDF_Page_SetLineWidth (page, 0.5)
           if (HPDF_Page_GetLineWidth (page) != 0.25)
              HPDF_Page_SetLineWidth (page, 0.25)
           Endif
        Endif
        HPDF_Page_MoveTo (page, 0, y)
        HPDF_Page_LineTo (page, width, y)
        HPDF_Page_Stroke (page)
        if (y % nTag_Y == 0 .and. y > 0)
            HPDF_Page_SetGrayStroke (page, 0.5)
            HPDF_Page_LineTo (page, nScaleLine_Y, y)
        Endif
        y += nScaleLine_Y
    End
    /* Draw vertical lines */
    x := 0 //distabcia inicio primeira linha
    while (x < width)
        if (x % (nScaleLine_X*2) == 0)
            Endif
        Endif
        HPDF_Page_MoveTo (page, x, 0)
        HPDF_Page_LineTo (page, x, height)
        if (x % nTag_X == 0 .and. x > 0)  // linha de referencia com a tag texto linha mais forte
            //tag esquerda
            HPDF_Page_LineTo (page, x, nScaleLine_X )
            //tag direita
			HPDF_Page_MoveTo (page, x, height)
            HPDF_Page_LineTo (page, x, height - nScaleLine_X)
        Endif
        x += nScaleLine_X
    End
    /* Draw horizontal text */
    y := 0 //distabcia inicio texto
    while (y < height)
        if (y % (nScaleText_Y) == 0 .and. y > 0)
            HPDF_Page_BeginText (page)
            HPDF_Page_MoveTextPos (page, 5, y - 2)
            HPDF_Page_ShowText (page, ltrim(str(Y)))
            HPDF_Page_EndText (page)
        Endif
        y += nScaleText_Y
    End
    /* Draw virtical text */
    x := 0
    while (x < width)
        if (x % (nScaleText_X) == 0 .and. x > 0)
            //tag em baixo
            HPDF_Page_MoveTextPos (page, x, 5)
            HPDF_Page_ShowText (page, ltrim(str(x)))
            //tag em cima
            HPDF_Page_MoveTextPos (page, x, height - 10)
        Endif
        x += nScaleText_X
    End
    HPDF_Page_SetGrayFill (page, 0)
    HPDF_Page_SetGrayStroke (page, 0)
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
edk
Re: pdf grid
Post by edk »
Here you are, anything else :?:
Function Main()
Local i, lSuccess
SELECT HPDFDOC "sample.pdf" TO lSuccess ORIENTATION HPDF_ORIENT_LANDSCAPE PAPERSIZE HPDF_PAPER_A4
START HPDFDOC
    START HPDFPAGE
	print_grid( 0, 0, HPDF_Page_GetHeight (_HMG_SYSDATA[ 150 ][ 7 ]), HPDF_Page_GetWidth (_HMG_SYSDATA[ 150 ][ 7 ]), 5, 5, 50 , 50 , 10 , 10 )
	@10,10 HPDFPRINT "Grid Demo Page 1"
    END HPDFPAGE
    START HPDFPAGE
	@10,10 HPDFPRINT "Grid Demo Page 2"
	print_grid( 400, 150, 160, 200, 5, 5, 20 , 20 , 10 , 10 )
    END HPDFPAGE
END HPDFDOC
IF lSuccess
Function print_grid( nRow, nCol, height, width, nScaleLine_X, nScaleLine_Y, nScaleText_X, nScaleText_Y, nTag_x, nTag_Y )
   Local  font,x,y, cLabel, nLabWidth
   Local nFontSize   := 5
    HPDF_Page_SetFontAndSize (page, font, nFontSize)
    while (y <= height )
           Endif
        Endif
        HPDF_Page_MoveTo (page, nCol, y + nRow)
        HPDF_Page_LineTo (page, width + nCol, y + nRow)
            HPDF_Page_LineTo (page, nScaleLine_Y + nCol , y + nRow)
        Endif
        y += nScaleLine_Y
    End
    while (x <= width)
            Endif
        Endif
        HPDF_Page_MoveTo (page, x + nCol, nRow)
        HPDF_Page_LineTo (page, x + nCol, height + nRow)
            //tag esquerda
            HPDF_Page_LineTo (page, x + nCol, nScaleLine_X + nRow )
            //tag direita
	    HPDF_Page_MoveTo (page, x + nCol, height + nRow)
            HPDF_Page_LineTo (page, x + nCol, height - nScaleLine_X + nRow)
        Endif
        x += nScaleLine_X
    End
    while (y < height)
	    cLabel:=ltrim(str(y))
            HPDF_Page_MoveTextPos (page, nScaleLine_Y + nCol, y + nRow - (nFontSize/2) + .75  /* Middled Label */)
            HPDF_Page_ShowText (page, cLabel)
        Endif
        y += nScaleText_Y
    End
    x := 0
    while (x < width)
            cLabel:=ltrim(str(x))
	    nLabWidth:=HPDF_Page_TextWidth( page, cLabel )
            //tag em baixo
            HPDF_Page_MoveTextPos (page, x + nCol - (nLabWidth/2)  /* Centered label */, nScaleLine_X + nRow + 1)
            //tag em cima
            HPDF_Page_MoveTextPos (page, x + nCol - (nLabWidth/2)  /* Centered label */, height - (nScaleLine_X * 2) + nRow)
        Endif
        x += nScaleText_X
    End
jairpinho
Re: pdf grid
Post by jairpinho »
edk wrote: Tue Oct 03, 2017 5:24 pm Here you are, anything else :?:
Function Main()
Local i, lSuccess
START HPDFDOC
    START HPDFPAGE
    END HPDFPAGE
    START HPDFPAGE
    END HPDFPAGE
END HPDFDOC
IF lSuccess
           Endif
        Endif
        Endif
        y += nScaleLine_Y
    End
    while (x <= width)
            Endif
        Endif
            //tag esquerda
            //tag direita
        Endif
        x += nScaleLine_X
    End
    while (y < height)
        Endif
        y += nScaleText_Y
    End
    x := 0
    while (x < width)
            //tag em baixo
            //tag em cima
        Endif
        x += nScaleText_X
    End
exactly that edk, only one doubt (nRow = 400) and the sheet is A4 has 210mm nRow = 400 (pixel)?
Jair Pinho
edk
Re: pdf grid
Post by edk »
Haru Pdf is based on pixels for default resolution 72dpi. Also note the coordinates that are different from HMG HPDF.
http://libharu.sourceforge.net/graphics.html
So 210mm is: 210/25.4 * 72 = 595,275591 px
and 297mm is: 297/25.4 * 72 = 841,889764 px
Look at grid on page 1.
At sample on page 2, value 400 corresponds lower-left corner of the grid in pixels (nRow), so 400/72 * 25.4 = 141,111111 mm, counting from bottom of the page.
jairpinho
Re: pdf grid
Post by jairpinho »
edk wrote: Tue Oct 03, 2017 8:59 pm Haru Pdf is based on pixels for default resolution 72dpi. Also note the coordinates that are different from HMG HPDF.
Thank you for the answers, it helped my projects a lot.
Jair Pinho
jairpinho
Re: pdf grid
Post by jairpinho »
edk, text along with the grid is not accentuating, I already added _HMG_HPDF_SetEncoding ("WinAnsiEncoding") but it does not work
Jair Pinho
edk
Re: pdf grid
Post by edk »
You need to do:
HPDF_GetFont gets the handle of a corresponding font object by specified name and encoding.
Local cEncoding := _HMG_SYSDATA[ 150 ] [ 10 ]       //Value of "SET HPDFDOC ENCODING TO".   "SET HPDFDOC ENCODING TO" set _HMG_HPDF_SetEncoding
font := HPDF_GetFont (pdf, "Helvetica", cEncoding)
Good luck to you.
jairpinho
Re: pdf grid
Post by jairpinho »
edk wrote: Thu Oct 05, 2017 7:59 pm You need to do:
Good luck to you.
it does not work so I need the horizontal text to be right-aligned just with HPDF_Page_SetTextMatrix? But the accent does not work.
MÃ-nimo: 119 -> "Mínimo: "
ofont := HPDF_GetFont (Pdf, cFont, cEncoding)
HPDF_Page_SetFontAndSize (Page, ofont, nFontSize)
nAngle := 0
nRad := nAngle / 180 * 3.141592 //radian value
nTextWidth := HPDF_Page_TextWidth( page ,"Mínimo: " +alltrim(str(nMim) ))
nxPos:= 85 - (nTextWidth* cos (nRad)) // posição coluna do texto
nyPos := nRow + nMim
HPDF_Page_SetTextMatrix ( page , cos ( nRad ), sin ( nRad ), -sin ( nRad ), cos ( nRad ), nxPos , nyPos - nFontSize/2 + .75 ) // nyPos = posicao Linha(Row)
HPDF_Page_ShowText (page, "Mínimo: "+alltrim(str(nMim)))
Jair Pinho
edk
Re: pdf grid
Post by edk »
I don't see the problem with accents:
Function Main()
Local i
SELECT HPDFDOC "sample.pdf" ORIENTATION HPDF_ORIENT_LANDSCAPE PAPERSIZE HPDF_PAPER_A4
START HPDFDOC
    START HPDFPAGE
     HPDF_RotateTextPx( 510, 200, 'MĂ-nimo: 119 -> "Mínimo: "', Nil, 7, 90 , , , , 'T' )  //units: pixels
    END HPDFPAGE
END HPDFDOC
PROCEDURE HPDF_RotateTextPx( nRow, nCol, cTxt, cFont, nFontSize, nAngle, lBold, lItalic, aColors, cAlign)
* Rotating text
   Local nRad, nTextWidth, oFont, cFnt
   Local hPdf        := _HMG_SYSDATA[ 150 ][ 1 ]
   Local hPage       := _HMG_SYSDATA[ 150 ][ 7 ]
   Local cPdfEnc     := _HMG_SYSDATA[ 150 ][ 10 ]
   Local nWidth      := _HMG_SYSDATA[ 150 ][ 4 ]
   Local nHeight     := _HMG_SYSDATA[ 150 ][ 5 ]
   Local nxPos       := nCol
   Local nyPos       := nRow
   DEFAULT cFont       := "Helvetica"
   DEFAULT nFontSize   := 12
   DEFAULT cTXt        := ""
   DEFAULT nAngle      := 0
   DEFAULT lBold       := .F.
   DEFAULT lItalic     := .F.
   DEFAULT aColors     := { 0, 0, 0}
   DEFAULT cAlign      :=""		//Empty - Left and bottom, R - Right, C - Center, T - Top, M - Middle
   If _HMG_SYSDATA[ 150 ][ 1 ] == Nil // PDF object not found!
      _HMG_HPDF_Error( 3 )
   If _HMG_SYSDATA[ 150 ][ 7 ] == Nil // PDF Page object not found!
      _HMG_HPDF_Error( 5 )
   IF VALTYPE(cAlign)#'C'
      cAlign := ''		//Left as default
   // set color
   If VALTYPE( aColors )#'A' .OR. LEN( aColors )#3 .OR. ;
      VALTYPE( aColors[1] )#'N' .OR. VALTYPE( aColors[2] )#'N' .OR. VALTYPE( aColors[3] )#'N' .OR. ;
      aColors[1]<0 .OR. aColors[1]>255 .OR. ;
      aColors[2]<0 .OR. aColors[2]>255 .OR. ;
      aColors[3]<0 .OR. aColors[3]>255
   Endif
   HPDF_Page_SetRGBFill( hPage, aColors[1]/255, aColors[2]/255, aColors[3]/255 )
   // set font
   If HMG_LEN( AllTrim( cFont ) ) == 0
      cFont := _HMG_HPDF_SetFont( cFont, lBold, lItalic )
      oFont := HPDF_GetFont( hPdf, cFont, cPdfEnc )
      cFont := AllTrim(_HMG_HPDF_SetFont( cFont, lBold, lItalic ))
      if HMG_UPPER (cFileExt (cFont)) == '.TTF' // load ttf font
         cFnt := HPDF_LOADTTFONTFROMFILE( hPdf, cFont, .t. )
         If HMG_LEN( Alltrim( cFnt ) ) == 0
            _HMG_HPDF_Error( 6 , cFont )
         oFont := HPDF_GetFont( hPdf, cFnt, cPdfEnc )
         If HMG_UPPER( alltrim( cFont ) ) == "SYMBOL" .or. HMG_UPPER( alltrim( cFont ) ) == "ZAPFDINGBATS"
            oFont := HPDF_GetFont( hPdf, cFont, Nil )
         endIf
   endIf
   If oFont == Nil
   Endif
   HPDF_Page_SetFontAndSize( hPage, oFont, nFontSize )
   nTextWidth := HPDF_Page_TextWidth( hPage, cTxt )
   //calculate nxPos
   IF 'R'$HMG_UPPER(cAlign)		//Right
      nxPos:=nxPos - (nTextWidth* cos (nRad))
   ELSEIF 'C'$HMG_UPPER(cAlign)	//Center
   	 nxPos:=nxPos - ((nTextWidth* cos (nRad))/2)
   //calculate nyPos
   IF 'T'$HMG_UPPER(cAlign)		//Top
      nyPos:=nyPos - (nTextWidth* sin (nRad))
   ELSEIF 'M'$HMG_UPPER(cAlign)	//Middle
   	 nyPos:=nyPos - ((nTextWidth* sin (nRad))/2)
   HPDF_Page_BeginText( hPage )
   HPDF_Page_SetTextMatrix ( hPage, cos ( nRad ), sin ( nRad ), -sin ( nRad ), cos ( nRad ), nxPos , nyPos)
   HPDF_Page_ShowText( hPage, cTxt )
   HPDF_Page_EndText( hPage )
    font := HPDF_GetFont (pdf, "Helvetica", cPdfEnc)
           Endif
        Endif
        Endif
        y += nScaleLine_Y
    End
    while (x <= width)
            Endif
        Endif
            //tag esquerda
            //tag direita
        Endif
        x += nScaleLine_X
    End
    while (y < height)
        Endif
        y += nScaleText_Y
    End
    x := 0
    while (x < width)
            //tag em baixo
            //tag em cima
        Endif
        x += nScaleText_X
    End
sample.7z
(1.07 KiB) Downloaded 500 times
Do you have a .prg file saved in UTF-8? Perhaps this is a problem.
Prg in ANSI works fine:
Demo.7z
(2.12 KiB) Downloaded 517 times
Re: pdf grid
Hi Kryzstof,
Is this text right: MĂ-nimo ?
And should the prg be save ad UTF-8 ? I think it must.
I download both and they show "MĂ-nimo".
