label at runtime
Re: label at runtime
Can be used BT_DrawText or BT_DrawTextEx function.
Sample is in: ...\hmg\SAMPLES\BosTaurus\Demo3.prg.
Thank you, KDJ, exactly.
nTypeText := BT_TEXT_OPAQUE + BT_TEXT_BOLD + BT_TEXT_ITALIC + BT_TEXT_UNDERLINE
nAlingText := BT_TEXT_CENTER + BT_TEXT_BASELINE
nOrientation := 90
BT_DrawText (hDC, 300, 400, " The Power of HMG 1", "Comic Sans MS", 42, WHITE, BLACK, nTypeText, nAlingText, nOrientation)
this is the result, now I just need to do this in pdf.
- GRAPH-OK.png (88.85 KiB) Viewed 17078 times
I hope this will be helpful:
Function Main()
Local i
SELECT HPDFDOC "sample.pdf" PAPERLENGTH 300 PAPERWIDTH 300 LOG
START HPDFDOC
START HPDFPAGE
@10,10 HPDFPRINT "Rotate Demo"
HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 90 )
HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 180)
HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 270)
HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 0 )
FOR i=100 TO 300 STEP 10
@i,10 HPDFPRINt "Happy HMG"
NEXT i
FOR i=0 To 345 STEP 15
HPDF_RotateText( 150, 150, "Happy HMG", Nil, 10, i )
NEXT i
END HPDFPAGE
END HPDFDOC
Execute File 'sample.pdf'
PROCEDURE HPDF_RotateText( nRow, nCol, cTxt, cFont, nFontSize, nAngle )
* Rotating text
Local nRad, nTextWidth
Local hPdf := _HMG_SYSDATA[ 150 ][ 1 ]
Local hPage := _HMG_SYSDATA[ 150 ][ 7 ]
Local nWidth := _HMG_SYSDATA[ 150 ][ 4 ]
Local nHeight := _HMG_SYSDATA[ 150 ][ 5 ]
Local nxPos := _HMG_HPDF_MM2Pixel( nCol )
Local nyPos := nHeight - _HMG_HPDF_MM2Pixel( nRow )
DEFAULT cFont := "Helvetica"
DEFAULT nFontSize := 12
DEFAULT cTXt := ""
DEFAULT nAngle := 0
nTextWidth := HPDF_Page_TextWidth( hPage, cTxt )
nRad := nAngle / 180 * 3.141592 //radian value
HPDF_Page_SetFontAndSize( hPage, HPDF_GetFont( hPdf, cFont, NIL ), nFontSize )
HPDF_Page_BeginText( hPage )
HPDF_Page_SetTextMatrix ( hPage, cos ( nRad ), sin ( nRad ), -sin ( nRad ), cos ( nRad ), nxPos , nyPos - nFontSize)
HPDF_Page_ShowText( hPage, cTxt )
HPDF_Page_EndText( hPage )
EDK thanks for the function you created to rotate the text in pdfedk wrote: ↑Thu Sep 07, 2017 7:20 pm I hope this will be helpful:pdf.JPGCode: Select all
#include "hmg.ch" Function Main() Local i SELECT HPDFDOC "sample.pdf" PAPERLENGTH 300 PAPERWIDTH 300 LOG SET HPDFDOC ENCODING TO "WinAnsiEncoding" START HPDFDOC START HPDFPAGE @10,10 HPDFPRINT "Rotate Demo" HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 90 ) HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 180) HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 270) HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 0 ) FOR i=100 TO 300 STEP 10 @i,10 HPDFPRINt "Happy HMG" NEXT i FOR i=0 To 345 STEP 15 HPDF_RotateText( 150, 150, "Happy HMG", Nil, 10, i ) NEXT i END HPDFPAGE END HPDFDOC Execute File 'sample.pdf' Return Nil ******************************* PROCEDURE HPDF_RotateText( nRow, nCol, cTxt, cFont, nFontSize, nAngle ) * Rotating text Local nRad, nTextWidth Local hPdf := _HMG_SYSDATA[ 150 ][ 1 ] Local hPage := _HMG_SYSDATA[ 150 ][ 7 ] Local nWidth := _HMG_SYSDATA[ 150 ][ 4 ] Local nHeight := _HMG_SYSDATA[ 150 ][ 5 ] Local nxPos := _HMG_HPDF_MM2Pixel( nCol ) Local nyPos := nHeight - _HMG_HPDF_MM2Pixel( nRow ) DEFAULT cFont := "Helvetica" DEFAULT nFontSize := 12 DEFAULT cTXt := "" DEFAULT nAngle := 0 nTextWidth := HPDF_Page_TextWidth( hPage, cTxt ) nRad := nAngle / 180 * 3.141592 //radian value HPDF_Page_SetFontAndSize( hPage, HPDF_GetFont( hPdf, cFont, NIL ), nFontSize ) HPDF_Page_BeginText( hPage ) HPDF_Page_SetTextMatrix ( hPage, cos ( nRad ), sin ( nRad ), -sin ( nRad ), cos ( nRad ), nxPos , nyPos - nFontSize) HPDF_Page_ShowText( hPage, cTxt ) HPDF_Page_EndText( hPage ) RETURN
now and the graph in pdf the text is ok
HI EDK
Great job.- This expands HMGPDFPRINT possibilities.-
Tranks for your contribution and for share with us.-
With regards
Eduardo
With regards
Eduardo
I am doing other tests with drawtext and found problems only creates the texts when initialized in the window onpaint if create in another window triggered by a button is also not generated the text follows the project example:
declare window main
declare window Form_Label
Load Window Main
Main.Center
Main.Activate
Function FORM_LABEL()
Load Window Form_Label
Form_Label.Center
Form_Label.Activate
PROCEDURE Proc_ON_PAINT_Main()
LOCAL hDC, BTstruct
hDC := BT_CreateDC ("Main", BT_HDC_INVALIDCLIENTAREA, @BTstruct)
nTypeText := BT_TEXT_TRANSPARENT + BT_TEXT_BOLD
nAlingText := BT_TEXT_RIGHT + BT_TEXT_BASELINE
nOrientation := 90
BT_DrawText (hDC, 50, 100, " The Power of HMG ", "Comic Sans MS", 12, BLACK ,WHITE, nTypeText, nAlingText, nOrientation)
BT_DeleteDC (BTstruct)
PROCEDURE Proc_ON_PAINT_Modal()
LOCAL hDC, BTstruct
nOrientation := 90
edk, if you do not use HPDFPRINT with some text of your HPDF_RotateText function the pdf file is not generated if you use apanes a line HPDF_RotateText (50, 80, "ABCxyz123", Nil, Nil, 90) will not generate the file. when to do the test delete the existing .pdf file
Function Main()
Local i
START HPDFDOC
START HPDFPAGE
//@ 10,10 HPDFPRINT "Rotate Demo" do not create pdf file
NEXT i
NEXT i
END HPDFPAGE
END HPDFDOC
Corrected. I added font attributes, and colors.
By the way, I found a bug in the source h_HMG_HPDF.Prg
If you want to use the Bold and/or Italic attributes you need to add in h_HMG_HPDF.Prg at line #1812: cFnt := cFont (after "Otherwise"). Otherwise, cFnt variable for declared cFont: "Courier" and "Helvetica" is Nil value, which results in an error.
After the change, of course, you have to rebuild the HMG.
Function Main()
Local i
START HPDFDOC
START HPDFPAGE
// @10,10 HPDFPRINT "Rotate Demo"
HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 180, .T.)
HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 270, .T., .T.)
HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 0 , , .T.)
FOR i=0 TO 250 STEP 10
HPDF_RotateText( i, 10, "Happy HMG", "Courier", 15, 5, .T. , .T. , {200, i, 75})
NEXT i
HPDF_RotateText( 150, 150, "Happy HMG", Nil, 10, i, , , {255 , 255, 0} )
NEXT i
END HPDFPAGE
END HPDFDOC
PROCEDURE HPDF_RotateText( nRow, nCol, cTxt, cFont, nFontSize, nAngle, lBold, lItalic, aColors)
* Rotating text
Local nRad, nTextWidth, oFont, cFnt
Local cPdfEnc := _HMG_SYSDATA[ 150 ][ 10 ]
DEFAULT cTXt := ""
DEFAULT nAngle := 0
DEFAULT lBold := .F.
DEFAULT lItalic := .F.
DEFAULT aColors := { 0, 0, 0}
If _HMG_SYSDATA[ 150 ][ 1 ] == Nil // PDF object not found!
_HMG_HPDF_Error( 3 )
If _HMG_SYSDATA[ 150 ][ 7 ] == Nil // PDF Page object not found!
_HMG_HPDF_Error( 5 )
// set color
If VALTYPE( aColors )#'A' .OR. LEN( aColors )#3 .OR. ;
VALTYPE( aColors[1] )#'N' .OR. VALTYPE( aColors[2] )#'N' .OR. VALTYPE( aColors[3] )#'N' .OR. ;
aColors[1]<0 .OR. aColors[1]>255 .OR. ;
aColors[2]<0 .OR. aColors[2]>255 .OR. ;
aColors[3]<0 .OR. aColors[3]>255
Endif
HPDF_Page_SetRGBFill( hPage, aColors[1]/255, aColors[2]/255, aColors[3]/255 )
// set font
If HMG_LEN( AllTrim( cFont ) ) == 0
cFont := _HMG_HPDF_SetFont( cFont, lBold, lItalic )
oFont := HPDF_GetFont( hPdf, cFont, cPdfEnc )
cFont := AllTrim(_HMG_HPDF_SetFont( cFont, lBold, lItalic ))
if HMG_UPPER (cFileExt (cFont)) == '.TTF' // load ttf font
cFnt := HPDF_LOADTTFONTFROMFILE( hPdf, cFont, .t. )
If HMG_LEN( Alltrim( cFnt ) ) == 0
_HMG_HPDF_Error( 6 , cFont )
oFont := HPDF_GetFont( hPdf, cFnt, cPdfEnc )
If HMG_UPPER( alltrim( cFont ) ) == "SYMBOL" .or. HMG_UPPER( alltrim( cFont ) ) == "ZAPFDINGBATS"
oFont := HPDF_GetFont( hPdf, cFont, Nil )
endIf
endIf
If oFont == Nil
Endif
HPDF_Page_SetFontAndSize( hPage, oFont, nFontSize )
