How do i call a procedure
ROBROS
Re: How do i call a procedure
Post by ROBROS »
I googled and found:
Range("B4").End(xlUp).Select
This example selects the cell at the top of column B in the region that contains cell B4.
Robert
And I found this:
Describes how to use VBA macros or procedures to select cells, ranges, and named ranges in Excel. ... Count to count the number of columns in the specified item. Rows. .... Column lastRow = ActiveSheet.Cells(65536, lastCol).End(xlUp).Row
KDJ wrote: Tue Sep 05, 2017 4:54 am
ROBROS wrote: Mon Sep 04, 2017 6:53 pm ...
oExcel:Selection:End(xlUp):Select()
What is the value of xlUp ?
xlUp is defined in excel.ch as:
#DEFINE xlUp   -4162
ROBROS
Post by ROBROS »
Now the problem is solved:
I simply added Mol's #define
and left out the line oExcel:Cells:Item(65536, nColumn).Select()
Now it works.
Thank you for your answers.
Robert
ROBROS
Post by ROBROS »
Sorry, my answer was given too quick, not all rows are appended,
but when I insert:
I get a syntax error.
I will search the net for a solution (VBA), if I find it I will post it here.
Thx again
Robert
change:
oExcel:Cells:Item(65536, nColumn).[/b]Select()
to
oExcel:Cells:Item(65536, nColumn):Select()
ROBROS
Post by ROBROS »
Hi Marek,
the syntax error is gone, but I still get a runtime error (tole)
As a workaround i did the following:
manually open worksheet, find the last row with ctrl end, type this in a cell above the range to be imported and read it into nLastRow.
But I will search for an automatic solution.
Why do you want to go to the last row?
ROBROS
Post by ROBROS »
mol wrote: Tue Sep 05, 2017 10:00 am Why do you want to go to the last row?
to get the number of the last row for the for next loop.
You have to know which row is occupied by data?
I'm testing first cell in row while importing data if it's not empty. If it doesn't contain any value, I'm finishing process.
		nRow := 1
		do while .t.
			DO EVENTS
			xCell :=oXLSSheet:Cells( nRow, 3 ):Value
			if empty(xCell)
				exit
			nRow++
		enddo
ROBROS
Post by ROBROS »
The problem is: the xls-sheet is provided by a report generator from another company and there are empty lines before the last line with data.
