How do i call a procedure
ROBROS
Re: How do i call a procedure
Post by ROBROS »
OK, I'll be back.
Robert
ROBROS
Post by ROBROS »
I have zipped 2 files: main. prg with all procedures and main.fmg, which is not used, it was created by choosing new project from the IDE.
Robert
Main_prg.7z
(1.88 KiB) Downloaded 293 times
Robert,
See this sample:
CLOSE ALL
SET DATE TO GERMAN
SET CENTURY ON
SET DATE FORMAT TO "DD.MM.YYYY"
SET TOOLTIPSTYLE BALLOON
cJahr    := "2017"
dDat     := date()
dDATE_1  := date() + 10
DEFINE WINDOW Win_1 ;
   WIDTH 1200 ;
   HEIGHT 300 ;
   TITLE 'Fahrerspesen by RS 2017' ;
   DEFINE MAIN MENU
      DEFINE POPUP 'D&atei'
         ITEM "E&nde" ACTION Win_1.Release
      END POPUP
      DEFINE POPUP 'D&aten'
         ITEM 'Tagesdaten bereitstellen' ACTION woche()
         ITEM 'Tagesdaten einlesen' ACTION filltag()
         ITEM 'Enter date' ACTION datum()
      END POPUP
      DEFINE POPUP 'F&ahrerstamm'
         ITEM 'Suchen' ACTION suchen()
      END POPUP
   END MENU
   @ 80,10 DATEPICKER date_1 ;
      TOOLTIP 'Datum '	;
      SHOWNONE ;
      VALUE dDATE_1;
      ON CHANGE fill_Label_date_1()
   @ 100,10 LABEL Label_date_1 ;
      VALUE "" ;
      WIDTH 175 ;
      HEIGHT 35 ;
      FONT 'Arial' SIZE 09
SetProperty('Win_1', 'date_1','Visible', .F.)
SetProperty('Win_1', 'Label_date_1','Visible', .F.)
ACTIVATE WINDOW Win_1
FUNCTION datum()
SetProperty('Win_1', 'date_1','Visible', .T.)
return
FUNCTION fill_Label_date_1()
SetProperty('Win_1', 'Label_date_1','Visible', .T.)
SetProperty('Win_1', 'Label_date_1','Value', dtoc(GetProperty('Win_1', 'date_1','Value')))
dDATE_1 := GetProperty('Win_1', 'date_1','Value')
MSGINFO(dDATE_1)
FUNCTION woche()
// YOU CAN USE DATE ALS HERE:
close all
nCnt:=0
use wochesdf exclusive
zap
append from woche.prn sdf
delete for empty(line) .or. substr(line,1,4)="Mita"
pack
use woche
zap
close all
use woche alias wo new exclusive
use wochesdf alias wosdf new
select wosdf
go top
do while !eof()
   select wo
   dbappend()
   replace persnr with substr(wosdf->line,1,4),;
           zeit   with substr(wosdf->line,119,5),;
           koge   with substr(wosdf->line,125,5),;
           kza    with substr(wosdf->line,135,1),;
           datum  with ctod(substr(wosdf->line,110,6)+cJahr)
   nCnt++
   select wosdf
   skip
enddo
MsgInfo(ltrim(str(ncnt))+ " records aufbereitet")
nCnt:=0
CLOSE ALL
procedure filltag
close all
cFehler:="N"
//dDatum:=ctod("")
dDat:=ctod("")
cPersnr:=space(4)
set cursor on
set confirm on
cName:=space(30)
cName1:=space(30)
use spesen alias spesen new
index on datum to datum
use woche alias woche new
go top
dDat:=woche->datum
select spesen
seek dDat
if found()
   MsgInfo(dtoc(dDat)+" bereits verarbeitet")
   return
close all
go top
astruct:={{"PERSNR","C",4,0},{"DATUM","D",8,0},{"KOMMT","C",5,0},{"GEHT","C",5,0},{"KZA","C",5,0}}
dbcreate("SPESENA",astruct,"dbfntx")
use spesena alias spa exclusive new
use bbpers alias pers new
index on persnr to persnr
select woche
do while !eof()
   if !empty(woche->persnr)
      cPersnr=woche->persnr
   select pers
   seek cPersnr
//   if found()
      do dazu
//   endif
   select woche
   skip
enddo
do fillspes
astruct:={{"DATUM","D",8,0},{"PERSNR","C",4,0},{"GRUND","C",30,0},{"KOMMT","C",5,0},{"GEHT","C",5,0}}
dbcreate("FEHLER",astruct,"dbfntx")
use FEHLER alias FEHLER exclusive new
select spesen
dDat:=spesen->datum
//?dDat,spesen->datum
//wait
go top
do while !eof()
   if empty(spesen->kommt) .or. empty(spesen->geht)
      cName:="Zeitangabe fehlt"
      select fehler
	   dbappend()
	   replace persnr with spesen->persnr,kommt with spesen->kommt,geht with spesen->geht,datum with spesen->datum,grund with cName
      cFehler:="J"
   select spesen
   skip
enddo
if cFehler="J"
   select spesen
   delete for datum=dDat
   pack
   MsgInfo(dtoc(dDat)+" nicht gespeichert,siehe Tabelle Fehler")
   MsgInfo(dtoc(dDat)+" Daten eingelesen")
return
procedure dazu
select spa
dbappend()
replace persnr with cPersnr,datum with woche->datum,kza with woche->kza
if woche->koge="Kommt"
   replace kommt with woche->zeit
   replace geht with woche->zeit
PROCEDURE fillspes
use woche exclusive
delete for empty(koge)
pack
close all
dDatum:=ctod("")
cPersnr:=space(4)
set cursor on
set confirm on
//Tagesdaten in Spesendatei einlesen
use spesen alias spesen exclusive new
use spesena alias spa new
select spa
do while !eof()
   if !empty(spa->kommt)
      select spesen
      dbappend()
	   replace persnr with spa->persnr,datum with spa->datum,kommt with spa->kommt,kza with spa->kza
      select spa
	   skip // IS THIS CORRECT? WHAT ABOUT EOF() BY NEXT SKIP?
	   select spesen
      replace geht with spa->geht
   select spa
   skip
enddo
return
procedure suchen
return
The DATEPICKER is now defined in the WINDOW and when needed it is set to Visible (that's the way I useually do it)
Label LABEL Label_date_1 is not needed but it shows the content of the DATEPICKER (ONLY on CHANGE!)
Hope this helps!
ROBROS
Post by ROBROS »
Good Morning Serge,
I really appreciate your help, I just compiled it, it does exactly what it should an what you predicted, and thanks to your extended effort at such an early time of day , now I have a template that can be used in further apps.
Thank you so much.
Robert
You're welcome!
Normally I get up a bit later but today I have a visit coming: my grandchild
serge_girard wrote: Wed Aug 09, 2017 7:09 am ... today I have a visit coming: my grandchild
Congrats :)
IMO a grandchild is one of most happiness of the world
How many grandchild you have ( I have six )?
I wish you endless happiness together with your loved ones and your loved ones :D
Hi Esgici !
I have 4 children and 2 grandchildren. Ages 15 and 18 months, so both very little. I adore both and indeed one of most happiness of the world .
I actually have them each wednesday (now sleeping, so a minute free time!)
ROBROS
Post by ROBROS »
Hi Serge,
enjoy the free time!
I also have 3 grandchildren
one aged 15 years, the next 2 and a half, and little Anna is 4 months old.
Robert
Granddaddys all together!
ROBROS
Post by ROBROS »
Hi to all,
I'm just playing around with the windows of HMG, I got a lot of help from you (especially from Serge) Thank You again.
The following code shows how I call a second window via function win2(). Now I intend to split my yet to be programmed functions in their "own" windows. Are there any drawbacks doing this? The reason why I did so is to avoid to Define win_2 repeatedly and thus getting an error.
I would be glad to hear what you think about that.
CLOSE ALL
SET DATE TO GERMAN
SET CENTURY ON
cJahr := "2017"
dDATE_1 := date()
dDate_2 := date() + 10
WIDTH 1200 ;
HEIGHT 800 ;
DEFINE MAIN MENU
END POPUP
DEFINE POPUP 'WINDOW 2'
ITEM '2. WINDOW' ACTION win2()
END POPUP
END MENU
function win2()
if !IsWindowActive(win_2)
DEFINE WINDOW Win_2 ;
windowtype child;
AT 100,100 ;
WIDTH 800 ;
HEIGHT 400 ;
TITLE 'Test 2. WINDOW'
ACTIVATE WINDOW Win_2
MsgInfo('2. WINDOW already active')
return nil
