The last novice
Re: The last novice
Welcome home Sir.
Re: The last novice
BPD, ASESORMIX, Daniel, Esgici, Mol, Anand, Luis, Sri... everybody .
Thank you very much for this kind welcome.
Where have you been these years?
I had the intuition that you existed, but I did not know where to look. I searched badly, blinded. But at last I have found you.
I want to raise my first question, but in a more appropriate place.
Re: The last novice
BeGeS : So I found Lazarus for my applications Pascal found Harbour and then HMG \ Harbour and gave a graphic touch to my app thanks to Roberto ..
If you have the need to ask something do it fast we do not have much time we are all almost from the last century
- Roberto Lopez
- HMG Founder
Re: The last novice
Bienvenue dans le monde merveilleux de HMG comme le dit si bien notre très cher ami Esgici
L'Algerie vous salut
Y.TABET
Y.TABET
Re: The last novice
Hi Beges:
Wellcome from Argentina.
Re: The last novice
Muchas gracias, don Roberto (para mí, usted siempre será don Roberto aunque en el futuro el tratamiento sea de tuteo).
Jamás pensé que un día podría conversar con el creador de una de las herramientas que utilizo para desarrollar software... Mejor dicho, "que utilizaré", pues aún ando en el parvulario.
Todo un placer saludarle. Gracias por estar ahí.
Re: The last novice
Quartz, Tonton2, Eduardo: Thank you very much for your welcome.
- Roberto Lopez
- HMG Founder
Re: The last novice
Soy mayor que vos, así que el tratamiento de 'Don' es el correctoBeGeS wrote: ↑Sun Jul 23, 2017 2:19 pmMuchas gracias, don Roberto (para mí, usted siempre será don Roberto aunque en el futuro el tratamiento sea de tuteo).
I'm older than you, so the use of 'Don' is the correct thing
