Form main is locking application close (not responding)
Form main is locking application close (not responding). I use hmg 3.4.4 in previous versions I did not have this problem and I close the main so main.release run the application as adminitrator
Re: Form main is locking application close (not responding)
Can you please give a small sample?
All applications that use mysql connection is locking when closing, even if I terminate the connections before, I use local mysql bank
I use mysql for years and I never had any problens of such as described.
Please, send us a small sample.
Follows a test created ide ansi, if closing the main window by the button the application freezes is locked, if it closes by the "X" of the main window it closes fast
- teste.zip
- (1.48 MiB) Downloaded 260 times
I discovered the application crash created in 32bit system runs on 64bit system but crashes when closing how to generate executable in 64bit I try to make and error
- erro 64bit.gif (36.65 KiB) Viewed 5648 times
Ola Jair: necesita Harbour 64 y MinGw64 para generar las librerías HMG en modo 64bits...
Já fiz download mas como faço para instalar
- mustafa
Hola jairpinho
Mira esto haber si te sirve
viewtopic.php?f=43&t=5198&hilit=Rathinagiri
For 64 Bit developers, you have to download and install Harbour64 and MingW64 from here (15 MB) and here (71 MB)respecitvely.
by mustafa
www.hmgforum.com/viewtopic.php?f=46&t=4 ... its#p45648
by mustafa
Full install now does not compile ide ansi menu 64 bits
build.log
hbmk2: Compilando...
hbmk2: Linkando... teste.exe
gcc.exe: error: .hbmk/win/mingw64/_hbmkaut_Main.o: No such file or directory
hbmk2[teste]: Erro: Executando linkeditor. 1
gcc.exe .hbmk/win/mingw64/Main.o .hbmk/win/mingw64/_hbmkaut_Main.o "E:/@Prog-Xbase/@Projetos/@MySQL/SISTEMAS/teste/_temp.o" -pthread -static-libgcc -static-libstdc++ -static -lpthread -mwindows -Wl,--start-group -l"hmg-64" -l"crypt-64" -l"edit-64" -l"editex-64" -l"graph-64" -l"ini-64" -l"report-64" -l"hfcl-64" -lmsvfw32 -lvfw32 -l"hbvpdf-64" -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oteste.exe -L"C:/hmg.3.4.4_x64/harbour-64/lib/win/mingw64" -L"C:/hmg.3.4.4_x64/lib-64"
Removed the line in config inc = yes compiled but it takes the same delay to close the main window
build.log
