Form main is locking application close (not responding)
jairpinho
Post by jairpinho »
Form main is locking application close (not responding). I use hmg 3.4.4 in previous versions I did not have this problem and I close the main so main.release run the application as adminitrator
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: Form main is locking application close (not responding)
Can you please give a small sample?
jairpinho
Post by jairpinho »
Rathinagiri wrote: Mon Jul 03, 2017 2:43 am Can you please give a small sample?
All applications that use mysql connection is locking when closing, even if I terminate the connections before, I use local mysql bank
Jair Pinho
I use mysql for years and I never had any problens of such as described.
Please, send us a small sample.
jairpinho
Post by jairpinho »
Follows a test created ide ansi, if closing the main window by the button the application freezes is locked, if it closes by the "X" of the main window it closes fast
teste.zip
(1.48 MiB) Downloaded 260 times
Jair Pinho
jairpinho
Post by jairpinho »
I discovered the application crash created in 32bit system runs on 64bit system but crashes when closing how to generate executable in 64bit I try to make and error
erro 64bit.gif (36.65 KiB) Viewed 5649 times
Jair Pinho
Ola Jair: necesita Harbour 64 y MinGw64 para generar las librerías HMG en modo 64bits...
jairpinho
Post by jairpinho »
Já fiz download mas como faço para instalar
Jair Pinho
Hola jairpinho
Mira esto haber si te sirve
viewtopic.php?f=43&t=5198&hilit=Rathinagiri
For 64 Bit developers, you have to download and install Harbour64 and MingW64 from here (15 MB) and here (71 MB)respecitvely.
by mustafa
www.hmgforum.com/viewtopic.php?f=46&t=4 ... its#p45648
jairpinho
Post by jairpinho »
Full install now does not compile ide ansi menu 64 bits
build.log
hbmk2: Compilando...
hbmk2: Linkando... teste.exe
gcc.exe: error: .hbmk/win/mingw64/_hbmkaut_Main.o: No such file or directory
hbmk2[teste]: Erro: Executando linkeditor. 1
gcc.exe .hbmk/win/mingw64/Main.o .hbmk/win/mingw64/_hbmkaut_Main.o "E:/@Prog-Xbase/@Projetos/@MySQL/SISTEMAS/teste/_temp.o" -pthread -static-libgcc -static-libstdc++ -static -lpthread -mwindows -Wl,--start-group -l"hmg-64" -l"crypt-64" -l"edit-64" -l"editex-64" -l"graph-64" -l"ini-64" -l"report-64" -l"hfcl-64" -lmsvfw32 -lvfw32 -l"hbvpdf-64" -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oteste.exe -L"C:/hmg.3.4.4_x64/harbour-64/lib/win/mingw64" -L"C:/hmg.3.4.4_x64/lib-64"
Removed the line in config inc = yes compiled but it takes the same delay to close the main window
Jair Pinho
