Main Menu Setting
Main Menu Setting
I have one question: how is possible to set drop side for main menu?
Now menu drop to left. I wish drop do the right.
On picture is actual situation.
Thanks in advance
Thanks in advance
Re: Main Menu Setting
I believe it is set by the size of the window the menu is in. If you move it to the left and make it bigger, the drops will be to the right.
Hope this helps ... Franco
All The Best,
Franco
Canada
Franco
Canada
- dragancesu
It's like ...\samples\controls\menu\menu_1
It works fine except when the program window is moved to the right that there is no place to display a submenu
Send your code
Send your code
That's right. If the window is set to the full screen or if the left edge of the window is on the left edge of the screen, then everything is fine.
However, this is not the case for standard windows apps.
My code is:
My code is:
Komentar funkcije
REQUEST DBFCDX, DBFFPT
RDDSETDEFAULT( "DBFCDX" )
SET DATE GERMAN
SET CENTURY ON
DEFINE WINDOW Main ;
WIDTH 900 ;
HEIGHT 700 ;
TITLE 'DBF Test' ;
DEFINE MAIN MENU
POPUP 'File'
ITEM 'Open' ACTION MsgInfo ('File:Open')
ITEM 'Save' ACTION MsgInfo ('File:Save')
ITEM 'Print' ACTION MsgInfo ('File:Print')
ITEM 'Save As...' ACTION MsgInfo ('File:Save As')
ITEM 'HMG Version' ACTION MsgInfo (HMGVersion())
SEPARATOR
ITEM 'Exit' ACTION MsgInfo ('File:Exit')
END POPUP
POPUP 'Test'
ITEM 'Item 1' ACTION MsgInfo ('Item 1')
ITEM 'Item 2' ACTION MsgInfo ('Item 2')
POPUP 'Item 3' name test
ITEM 'Item 3.1' ACTION MsgInfo ('Item 3.1')
ITEM 'Item 3.2' ACTION MsgInfo ('Item 3.2')
POPUP 'Item 3.3'
ITEM 'Item 3.3.1' ACTION MsgInfo ('Item 3.3.1')
ITEM 'Item 3.3.2' ACTION MsgInfo ('Item 3.3.2')
POPUP 'Item 3.3.3'
ITEM 'Item 3.3.3.1' ACTION MsgInfo ('Item 3.3.3.1')
ITEM 'Item 3.3.3.2' ACTION MsgInfo ('Item 3.3.3.2')
ITEM 'Item 3.3.3.3' ACTION MsgInfo ('Item 3.3.3.3')
ITEM 'Item 3.3.3.4' ACTION MsgInfo ('Item 3.3.3.4')
ITEM 'Item 3.3.3.5' ACTION MsgInfo ('Item 3.3.3.5')
ITEM 'Item 3.3.3.6' ACTION MsgInfo ('Item 3.3.3.6')
END POPUP
ITEM 'Item 3.3.4' ACTION MsgInfo ('Item 3.3.4')
END POPUP
END POPUP
ITEM 'Item 4' ACTION MsgInfo ('Item 4')
END POPUP
POPUP 'Help'
ITEM 'About' ACTION MsgInfo ('Help:ABout')
END POPUP
END MENU
Main.Center
Main.Activate
Hi bobgen,
I am getting this 'left-side" main menu effect in Win10, it was all 'right-side" in WinXp. The same code / exe shows different side menu drop in these Win version (may be also in others).
So I conclude that this is OS effect and HMG has nothing to do with it. Also can not force left or right for the drop menu, through codes.
Anand
Anand
I still think that this is a problem with HMG, not WIN 10. I use some other tools to develop WIN applications, but they work equally to all win versions.
Bobgen
Bobgen
Well this indeed looks like Win10 issue, which seems to be fixed in latest update !
Below is the sample screen from c:\hmg.3.4.3\SAMPLES\Controls\Menu\MENU_1\
This was showing left-side drop menu earlier. But today it is showing correct i.e. right-side drop menu. Also my other application developed in Xbase++ are showing right-side drop menu.
My current Win10 version is as below,
I can only confirm that the same code is used and same exe is showing different than earlier, i.e. now in correct way.
Anand
EDIT: Screen shot attachments are showing incorrect position in this message , somehow.
Anand
- 2017-06-28_145523.png (600.02 KiB) Viewed 7599 times
Something strange. My installation and demo:
Figure 1 is a win 10 setting. Figure 2 menu_1 from the Sample Folder. Figure 3 when I move the application window to the left edge. Best Regards.
I have the same OS build as bobgen and on my computer the popup menu is displayed correctly.
If there is not enough space to display the next popup menu on the right side, it is displayed on the left side.
