Internet connected or not
Is there any reliable function to know computer is connected with Internet or not
edk
Re: Internet connected or not
Post by edk »
KDJ
Post by KDJ »
This is another way how to detect internet connection:
FUNCTION Main()
  // https://msdn.microsoft.com/en-us/library/windows/desktop/aa384702(v=vs.85).aspx
  LOCAL nFlags      := 0
  LOCAL lIsInternet := If(HMG_CallDLL("Wininet.dll", 0, "InternetGetConnectedState", @nFlags, 0) == 1, .T., .F.)
  MsgBox("Is internet: " + HB_ValToStr(lIsInternet) + CRLF + CRLF + "Flags: 0x" + HB_NumToHex(nFlags, 4))
Kryszstof,
Thanks, this would be a great 'standard' HMG function!
Kryszstof,
Thank you, but still I am not satisfied, you will get .t. / Internet available even after we switch off the router, subject to LAN cable/status is connected
I am searching for perfect function, I think any function based on PING command will be perfect
PeteWG
Post by PeteWG »
bpd2000 wrote: Mon Jun 19, 2017 3:28 am I am searching for perfect function, I think any function based on PING command will be perfect
Well, not exactly the "perfect" function ;)
but may want to give it a try...
 IsInternet.prg
 Check Internet connection
      NOTE: needs hbtip library. (use hbtip.hbc)
      BUILD: hbmk2 IsInternet hbtip.hbc
PROCEDURE Main()
   ? "IConnect() says: you're " + IF( IConnect(), "connected!", "NOT connected!" )
FUNCTION IConnect( cUrl )
   LOCAL oCon, oUrl
   LOCAL lRet := .F.
   hb_Default( @cUrl, "http://www.google.com" )
   oUrl := tURL():New( cUrl )
   oCon := TipClientHttp():New( oUrl )
   oCon:nConnTimeout := 20000
   IF ( lRet := oCon:Open( cUrl ) )
      oCon:Close()
   oCon := oUrl := NIL
   RETURN lRet
regards,
Pete
KDJ
Post by KDJ »
Is there an effective method to check the availability of the Internet without using PING?
KDJ
Post by KDJ »
This is probably the simplest way with PINGing:
FUNCTION Main()
  // https://msdn.microsoft.com/en-us/library/windows/desktop/aa384346(v=vs.85).aspx
  LOCAL lIsInternet := If(HMG_CallDLL("Wininet.dll", 0, "InternetCheckConnection", "http://www.google.com", 1 /*FLAG_ICC_FORCE_CONNECTION*/, 0) == 1, .T., .F.)
  MsgBox("Is internet: " + HB_ValToStr(lIsInternet))
Thank you Pete and KDJ
I had tested all the function and found that result from PING command is perfect
I request other user to post their result
Check Connectivity of Internet based on the result of PING command
You can also use this function to check computer IP in LAN before performing any action to avoid program crash
Check Internet connectivity through PING command and it is reliable
From bpd2000
Expert help from KDJ
FUNCTION MAIN()
   Local xerrdescription , xurl := "www.google.com"
   xerrdescription := HB_PING(xurl)
   Do Case
      Case xerrdescription = 0
       MSGINFO("Ping to " + xurl + " Succesful", "Internet Connection Available")
      Case xerrdescription = 11001
       MSGINFO("The reply buffer was too small.")
      Case xerrdescription = 11002
       MSGINFO("The destination network was unreachable.")
      Case xerrdescription = 11003
       MSGINFO("The destination host was unreachable.")
      Case xerrdescription = 11004
       MSGINFO("The destination protocol was unreachable.")
      Case xerrdescription = 11005
       MSGINFO("The destination port was unreachable.")
      Case xerrdescription = 11006
       MSGINFO("Insufficient IP resources were available.")
      Case xerrdescription = 11007
       MSGINFO("A bad IP option was specified.")
      Case xerrdescription = 11008
       MSGINFO("A hardware error occurred.")
      Case xerrdescription = 11009
       MSGINFO("The packet was too big.")
      Case xerrdescription = 11010
       MSGINFO("The request timed out." + hb_osnewline() +"Internet Connection Not Available")
      Case xerrdescription = 11011
       MSGINFO("A bad request.")
      Case xerrdescription = 11012
       MSGINFO("A bad route.")
      Case xerrdescription = 11013
       MSGINFO("The time to live (TTL) expired in transit.")
      Case xerrdescription = 11014
       MSGINFO("The time to live expired during fragment reassembly.")
      Case xerrdescription = 11015
       MSGINFO("A parameter problem.")
      Case xerrdescription = 11016
       MSGINFO("Datagrams are arriving too fast to be processed" + hb_osnewline() + ;
       " and datagrams may have been discarded.")
      Case xerrdescription = 11017
       MSGINFO("An IP option was too big.")
      Case xerrdescription = 11018
       MSGINFO("A bad destination.")
      Case xerrdescription = 11050
        MSGINFO("A general failure" + hb_osnewline() + ;
          "This error can be returned for some malformed ICMP packets.")
      Otherwise
        msginfo("Internet Connection Not Available")
    ENDCASE
//https://groups.google.com/forum/#!topic/harbour-users/Jag2rPxWK_U
#pragma BEGINDUMP
#include <hbapi.h>
#include <winsock2.h>
#include <iphlpapi.h>
#include <icmpapi.h>
int hb_Ping( const char * cp )
    HANDLE hIcmpFile;
    unsigned long ipaddr = INADDR_NONE;     // corrected by KDJ
    DWORD dwRetVal;
    char SendData[32] = "Data Buffer";
    LPVOID ReplyBuffer;
    DWORD ReplySize;
    if( isalpha( cp[0] ) )      //host address is a name
       WSADATA wsaData;
       int     iResult;
       iResult = WSAStartup( MAKEWORD(2, 2), &wsaData );
       if( iResult == 0 )
          struct hostent *remoteHost = gethostbyname( cp );
          if( remoteHost != NULL )
             ipaddr = *(unsigned long *) remoteHost->h_addr_list[0];
          WSACleanup();
       ipaddr = inet_addr( cp );
    if (ipaddr == INADDR_NONE)
        return 1;
    hIcmpFile = IcmpCreateFile();
    if (hIcmpFile == INVALID_HANDLE_VALUE)
        return 2;
    ReplySize = sizeof(ICMP_ECHO_REPLY) + sizeof(SendData);
    ReplyBuffer = (VOID*) malloc(ReplySize);
    if (ReplyBuffer == NULL)
        IcmpCloseHandle(hIcmpFile);
        return 3;
    dwRetVal = IcmpSendEcho(hIcmpFile, ipaddr, SendData, sizeof(SendData),
        NULL, ReplyBuffer, ReplySize, 1000);
    free(ReplyBuffer);
    if (dwRetVal == 0)
        return GetLastError();
    return 0;
HB_FUNC( HB_PING )
   hb_retni( hb_Ping( hb_parc( 1 ) ) );
#pragma ENDDUMP
