Combobx control
Combobx control
Function does not accept the HEIGHT parameter
records must be more than just going into the window
I used a standard demo
and canceled the array with images
d:\hmg344\SAMPLES\Controls\ComboBox\COMBO_8\
used OS W7 Profi 32bit
in win XP SP3 works well
- COMBO_8.ZIP
- source with a greater dbf
- (16.59 KiB) Downloaded 295 times
- correct viewing
- Screenshot_2.jpg (35.22 KiB) Viewed 8269 times
- inorrect viewing
- Screenshot_1.jpg (40.34 KiB) Viewed 8269 times
Re: Combobx control
Probado en W7 PRO 32bits y funciona OK.
Pareciera que tu archivo de indices está mal.
el HEIGHT solo muestra las ciudades que hay en el dbf, pudieras añadir mas.
Tested on W7 PRO 32 bit and works OK.
It looks like your index file is wrong.
The HEIGHT only shows the cities that are in the dbf, you could add more.
- Combo82.jpg (57.63 KiB) Viewed 8246 times
- Combo8.jpg (138.07 KiB) Viewed 8248 times
Re: Combobx control
Thank you for your response
Bust please use the database I sent
It will not be in the index, I deleted it before running it.
Re: Combobx control
Hi, Georg_BA,
Would you, please, try this (from my humble experience with COMBOs):
Kind regards,
Marin
DEFINE COMBOBOX Combo_2
ROW 10
COL 250
// ITEMSOURCE CIDADES->CODIGO , CIDADES->DESCRICAO
ITEMSOURCE CIDADES->CODIGO + " " + CIDADES->DESCRICAO
VALUE 2
WIDTH 200
HEIGHT 100
IMAGE aImages
DROPPEDWIDTH 350
ONDROPDOWN PlayBeep()
ON CLOSEUP PlayAsterisk()
END COMBOBOX
Marin
Re: Combobx control
Thank you for your interest
Problem is not in combo 2
Screenshot_1.jpg -corect view
There is no problem in not seeing the field, but it places the displayed values
Screenshot_1.jpg top Windows
Combo 1 and cobmo 2 should be displayed as well
In combo 1 I canceled the images to fake the bug
Can I try to compile the example I sent?
Re: Combobx control
George,
It must be some bug when using it with IMAGE.
This will give about the same result:..
Very strange indeed.
DEFINE COMBOBOX Combo_1
ROW 10
COL 10
ITEMSOURCE CIDADES->DESCRICAO
VALUE 5
WIDTH 200
HEIGHT 50
DROPPEDWIDTH 200
END COMBOBOX
ROW 10
COL 250
VALUE 2
WIDTH 200
HEIGHT 500
IMAGE aImages
DROPPEDWIDTH 200
END COMBOBOX
Re: Combobx control
Sorry, Georg,
I didn't understand your question right.
As far as I remember, there was somewhere in our forum a clarification, that the HEIGHT property applies to the height of the initial box of the combobox only and not to the height of the expanded dropdown list.
Unfortunately, I can not give here the exact link.
Marin
Marin
Re: Combobx control
Re: Combobx control
I went through the forum, there were more complaints, but no problem solving
viewtopic.php?f=24&t=4797&p=45556&hilit ... ght#p45556
viewtopic.php?f=24&t=4205&p=39783&hilit ... ght#p39783
Re: Combobx control
viewtopic.php?f=24&t=4797&p=45556&hilit ... GHT#p45556
The same problem, but not the solution
I use hmg 3.4.4 /ANSI
