My First SQLite Project
Re: My First SQLite Project
Rathinagiri, Sudip,
Thanks for pointing me the benefits of SqLite.
I have not available time right now to do it myself, but I have an idea :)
A nice thing could be from the same source code, have local and client/server access changing only something like a SET command to specify that.
So, could be easy to make some sort of intermediate layer to unify functions to access SQL (local via SqLite or remote via MySql or PostgreSql).
Roberto.
Exactly what I have thought of. You are always many steps ahead.
sudip
Post by sudip »
Roberto Lopez wrote:Rathinagiri, Sudip,
Roberto.
Yes Master Roberto,
You always have an idea many times forward than rest of us :D
With best regards.
sudip
Post by sudip »
Hello Rathi,
rathinagiri wrote:IMHO the needs for SQLite:
1. Use of SQL queries.
2. Index would be done automatically every time.
3. Single file per database of numerous tables.
4. Mutli-user
5. Speed
6. Security (Password protection)
Thank you very much for your wish :D
Can you please tell me how can I password protect SQLite database?
Thanks in advance.
With best regards.
Roberto Lopez wrote: So, could be easy to make some sort of intermediate layer to unify functions to access SQL (local via SqLite or remote via MySql or PostgreSql).
Some years ago, I've created a small code layer called 'MiniSql'.
Perhaps, this code could be useful to you in some way.
I'm sure that I have a backup of it, but, I can't find it :)
So, if someone has it, please upload!
Roberto.
sudip
Post by sudip »
Hello Master Roberto,
Is the following code you are talking about?
 * HMG - Harbour Win32 GUI library
 * MiniSql (a Simple MySql Access Layer)
 * Copyright 2002-2005 Roberto Lopez <harbourminigui@gmail.com>
 * http://harbourminigui.googlepages.com/
Function SqlDoQuery( nHandle , cQuery )
Local nNumRows
Local nNumFields
Local nQueryResultHandle
Local aQuery := {}
Local aRow := {}
Local i
	if __mvexist ('SqlTrace')
		If SqlTrace == .T.
			MsgInfo (cQuery)
		EndIf
	SqlQuery ( nHandle , cQuery ) ; SqlErrorCheck ( nHandle )
	nQueryResultHandle := sqlStoreR( nHandle ) ; SqlErrorCheck ( nHandle )
	nNumRows := sqlNRows( nQueryResultHandle ) ; SqlErrorCheck ( nHandle )
	nNumFields := sqlNumFi( nQueryResultHandle ) ; SqlErrorCheck ( nHandle )
	For i := 1 To nNumRows
		aRow := sqlFetchR(nQueryResultHandle) ; SqlErrorCheck ( nHandle )
		aadd ( aQuery , aRow )
	Next i
Return aQuery
Function SqlDoCommand ( nHandle , cQuery )
Local ar
		If SqlTrace == .T.
			msginfo(cQuery)
		EndIf
	ar := SqlAffRows(nHandle)  ; SqlErrorCheck ( nHandle )
Return ar
Procedure SqlErrorCheck ( nHandle )
Local SqlCurrentError
	SqlCurrentError := SqlGetErr ( nHandle )
	If .Not. Empty ( SqlCurrentError )
		SqlQuery ( nHandle , 'UNLOCK TABLES')
		SqlClose( nHandle )
		MsgStop (SqlCurrentError ,"MiniSql")
	EndIf
#ifndef __XHARBOUR__
#pragma BEGINDUMP
#define HB_OS_WIN_32_USED
#include "hbapi.h"
HB_FUNC_EXTERN( MYSQL_GET_SERVER_VERSION      ); HB_FUNC( SQLVERSION      ) { HB_FUNC_EXEC( MYSQL_GET_SERVER_VERSION      ); }
HB_FUNC_EXTERN( MYSQL_REAL_CONNECT            ); HB_FUNC( SQLCONNECT      ) { HB_FUNC_EXEC( MYSQL_REAL_CONNECT            ); }
HB_FUNC_EXTERN( MYSQL_CLOSE                   ); HB_FUNC( SQLCLOSE        ) { HB_FUNC_EXEC( MYSQL_CLOSE                   ); }
HB_FUNC_EXTERN( MYSQL_COMMIT                  ); HB_FUNC( SQLCOMMIT       ) { HB_FUNC_EXEC( MYSQL_COMMIT                  ); }
HB_FUNC_EXTERN( MYSQL_ROLLBACK                ); HB_FUNC( SQLROLLBACK     ) { HB_FUNC_EXEC( MYSQL_ROLLBACK                ); }
HB_FUNC_EXTERN( MYSQL_SELECT_DB               ); HB_FUNC( SQLSELECTD      ) { HB_FUNC_EXEC( MYSQL_SELECT_DB               ); }
HB_FUNC_EXTERN( MYSQL_QUERY                   ); HB_FUNC( SQLQUERY        ) { HB_FUNC_EXEC( MYSQL_QUERY                   ); }
HB_FUNC_EXTERN( MYSQL_STORE_RESULT            ); HB_FUNC( SQLSTORER       ) { HB_FUNC_EXEC( MYSQL_STORE_RESULT            ); }
HB_FUNC_EXTERN( MYSQL_USE_RESULT              ); HB_FUNC( SQLUSERES       ) { HB_FUNC_EXEC( MYSQL_USE_RESULT              ); }
HB_FUNC_EXTERN( MYSQL_FREE_RESULT             ); HB_FUNC( SQLFREER        ) { HB_FUNC_EXEC( MYSQL_FREE_RESULT             ); }
HB_FUNC_EXTERN( MYSQL_FETCH_ROW               ); HB_FUNC( SQLFETCHR       ) { HB_FUNC_EXEC( MYSQL_FETCH_ROW               ); }
HB_FUNC_EXTERN( MYSQL_DATA_SEEK               ); HB_FUNC( SQLDATAS        ) { HB_FUNC_EXEC( MYSQL_DATA_SEEK               ); }
HB_FUNC_EXTERN( MYSQL_NUM_ROWS                ); HB_FUNC( SQLNROWS        ) { HB_FUNC_EXEC( MYSQL_NUM_ROWS                ); }
HB_FUNC_EXTERN( MYSQL_FETCH_FIELD             ); HB_FUNC( SQLFETCHF       ) { HB_FUNC_EXEC( MYSQL_FETCH_FIELD             ); }
HB_FUNC_EXTERN( MYSQL_FIELD_SEEK              ); HB_FUNC( SQLFSEEK        ) { HB_FUNC_EXEC( MYSQL_FIELD_SEEK              ); }
HB_FUNC_EXTERN( MYSQL_NUM_FIELDS              ); HB_FUNC( SQLNUMFI        ) { HB_FUNC_EXEC( MYSQL_NUM_FIELDS              ); }
HB_FUNC_EXTERN( MYSQL_FIELD_COUNT             ); HB_FUNC( SQLFICOU        ) { HB_FUNC_EXEC( MYSQL_FIELD_COUNT             ); }
HB_FUNC_EXTERN( MYSQL_LIST_FIELDS             ); HB_FUNC( SQLLISTF        ) { HB_FUNC_EXEC( MYSQL_LIST_FIELDS             ); }
HB_FUNC_EXTERN( MYSQL_ERROR                   ); HB_FUNC( SQLGETERR       ) { HB_FUNC_EXEC( MYSQL_ERROR                   ); }
HB_FUNC_EXTERN( MYSQL_LIST_DBS                ); HB_FUNC( SQLLISTDB       ) { HB_FUNC_EXEC( MYSQL_LIST_DBS                ); }
HB_FUNC_EXTERN( MYSQL_LIST_TABLES             ); HB_FUNC( SQLLISTTBL      ) { HB_FUNC_EXEC( MYSQL_LIST_TABLES             ); }
HB_FUNC_EXTERN( MYSQL_AFFECTED_ROWS           ); HB_FUNC( SQLAFFROWS      ) { HB_FUNC_EXEC( MYSQL_AFFECTED_ROWS           ); }
HB_FUNC_EXTERN( MYSQL_GET_HOST_INFO           ); HB_FUNC( SQLHOSTINFO     ) { HB_FUNC_EXEC( MYSQL_GET_HOST_INFO           ); }
HB_FUNC_EXTERN( MYSQL_GET_SERVER_INFO         ); HB_FUNC( SQLSRVINFO      ) { HB_FUNC_EXEC( MYSQL_GET_SERVER_INFO         ); }
HB_FUNC_EXTERN( MYSQL_ESCAPE_STRING           ); HB_FUNC( DATATOSQL       ) { HB_FUNC_EXEC( MYSQL_ESCAPE_STRING           ); }
HB_FUNC_EXTERN( MYSQL_ESCAPE_STRING_FROM_FILE ); HB_FUNC( FILETOSQLBINARY ) { HB_FUNC_EXEC( MYSQL_ESCAPE_STRING_FROM_FILE ); }
#pragma ENDDUMP
#endif
If it is the program you are talking about, I am also uploading the folder containing this file also.
MiniSql.zip
(5.48 KiB) Downloaded 720 times
I found it from Minigui\Samples\Advansed\Minisql folder. And I hope this can be easily compiled with HMG official with some minor changes.
With best regards.
sudip wrote:Hello Master Roberto,
Yes it is.
You'll must find a '.ch' file, a sample and some little docs too.
Could be you so kind to upload all the files (if available) ?
Roberto.
sudip
Post by sudip »
Yes Master Roberto,
I am uploading it.
MiniSql.zip
(5.48 KiB) Downloaded 727 times
With best regards.
Oh! Nice. It is a treasure to dig in. :)
sudip wrote:Yes Master Roberto,
I am uploading it.
MiniSql.zip
With best regards.
OOPS!!!
Sorry, I've not seen it :)
Roberto.
